oil coming from dipstik
dick2256
Post by dick2256 »
oil coming out of dickstick hole on my corvair
Gary S
Re: oil coming from dipstik
Post by Gary S »
Sounds like major blow by.
glades cat
Post by glades cat »
dick2256 wrote:oil coming out of dickstick hole on my corvair
Better get that checked by a urologist, regardless of the vehicle you're in. :lol:
swamper2
Post by swamper2 »
check your crank case breather. not sure on your set up but might have a stuck pvc valve or mud dauber nest in a breather pipe. last thing you want is a ring job
dick2256
Post by dick2256 »
problem all started when I decided to put no O-rings in the oil return tubes
you have to remove all of the rocker arms and then readjust when you put it back together
and I had several of the valves staying open I been adjusting and rechecking and finally got it down to low compression on 2 cylinders
going to try again this morning on 5those to low ones and see if I can get them closer to the other ones
if not I will have to pull both heads cause I have one low cylinder on each side
swamper2
Post by swamper2 »
fix the cylinders. you need all the power you can get with that/ any engine
dick2256
Post by dick2256 »
they must be a good engine as much as parts cost :P
