pacemaker Ign.
pacemaker Ign.
I have a Pacemaker Ign. on a converted 470 one side is not hardly firing at all , seems to be firing good when I check plug wire to engine , changed plugs old plugs gap was .40 I only changed the one side that wasn't firing . after running for 30 min. I can grab one header pipe other two are a lot hotter , this is all just on right side as sitting on boat . Maybe Valves I'm thinking . But I'm just a old fart
Re: pacemaker Ign.
Are you saying you have good spark on both sides when you check by grounding each plug to the block? Or does one side have spark and the other no spark?riverrat1 wrote:one side is not hardly firing at all , seems to be firing good when I check plug wire to engine .
Mark 7:9
Re: pacemaker Ign.
good spark on both sides , compression on the both side is good the lowest is 110 psi
Re: pacemaker Ign.
Found the problem broken intake tube coupler,
Sent from my XT1635-01 using Southern Airboat mobile app powered by Tapatalk
