Compression on a 220 gpu
Msd78
Postby Msd78 » Fri May 05, 2017 1:24 pm
Does anyone know what the compression should be on a 220 gpu? I know the best thing to do is a leak down. Just trying to get an idea.
CypressHunter
Re: Compression on a 220 gpu
Postby CypressHunter » Fri May 05, 2017 11:32 pm
I don't know the exact numbers but if you go under the aircraft forum there are links for the service manuals for GPU's. Depends on what pistons you have
Postby kwanjangnihm » Sat May 06, 2017 7:27 am
check this link: viewtopic.php?f=47&t=52577
Bruce wrote:no less than 100lbs on a stock 220
skinny99 wrote: 100# is referring to a cranking cylinder compression test
Msd78 wrote: I know the best thing to do is a leak down
:thumbleft:
Msd78
Postby Msd78 » Sat May 06, 2017 7:04 pm
Thank you for all the info.
Users browsing this forum: Google [Bot] and 1 guest
