Prop speed RPM
JAMES
Prop speed RPM
Postby JAMES » Tue Jun 13, 2017 10:13 pm
All my power to this motor is 500+ on the DYNO
come in at 5400 RPM's I have a 79 in EX What I want to know and I forgot how to do it is where do I want that tip speed WW says 2000 to 2500 max how do I figure out my Tip speed i'm turning 5000 on ground set on 17 -17-1/2 I just want to make sure I'm in that speed range
Coastslider
Re: Prop speed RPM
Postby Coastslider » Tue Jun 13, 2017 10:38 pm
With your reduction you have listed it puts your prop rpm at 1865 at 5000engine rpm I believe
digginfool
Re: Prop speed RPM
Postby digginfool » Tue Jun 13, 2017 10:42 pm
Circumference is pi times diameter. So, 79" x 5400/12 = feet per minute. Divide again by 60 gives you feet per second. Or, multiply by 60 then divide by 5280 gives you mph. Pi = 3.14.
Sent from my SM-G950U using Southern Airboat mobile app powered by Tapatalk
Coastslider
Re: Prop speed RPM
Postby Coastslider » Tue Jun 13, 2017 10:43 pm
Ps tip speed is a totally different equation. WW is referring to propeller rpm
Re: Prop speed RPM
Postby Deano » Wed Jun 14, 2017 12:03 am
Here ya go James:
5400 Engine rpms is only turning the prop 2015 rpms. Got plenty of room.
Re: Prop speed RPM
Postby SWAMPHUNTER45 » Wed Jun 14, 2017 7:51 am
It appears that you may benefit from a 2.37 ratio
digginfool
Re: Prop speed RPM
Postby digginfool » Wed Jun 14, 2017 7:54 am
Coastslider wrote:Ps tip speed is a totally different equation. WW is referring to propeller rpm
You're correct. I did not figure in his gear ratio. You would have to divide RPM by gear ratio to get actual tip speed.
JAMES
Re: Prop speed RPM
Postby JAMES » Wed Jun 14, 2017 3:18 pm
I guess the big question is my prop is supposed to be 2000 to 2500 max in between that I guess is ideal correct ... too low I'm losing performance too high I'm taking a chance on catastrophic failure ? Also to high means a lot more noise I guess setting my motor at 5400 would be ideal I making over 500 hp at 5300
Re: Prop speed RPM
Postby One Eyed Gator » Wed Jun 14, 2017 4:20 pm
Sent ya a PM
Re: Prop speed RPM
Postby SWAMPHUNTER45 » Wed Jun 14, 2017 8:26 pm
5300rpm / 2.37 = 2236 rpm at prop
5400rpm / 2.37 = 2278 rpm at prop
Clearly that puts you in the props prime performance range
Coastslider
Re: Prop speed RPM
Postby Coastslider » Wed Jun 14, 2017 9:23 pm
SWAMPHUNTER45 wrote:It appears that you may benefit from a 2.37 ratio
X2
Re: Prop speed RPM
Postby One Eyed Gator » Fri Jun 16, 2017 12:14 pm
Just my 2 cents. Has more to do with tip speed than prop RPM.
To put the tip speed around 500mph which seems to be a good spot for R blades and other med width props
2.68 with a 79" prop takes 5700 motor rpm to be at the 500mph mark
2.55 " 5400 "
2.37 " 5050 "
2.68 with a 82" prop takes 5500 motor rpm to be at the 500mph mark
2.55 " 5200 "
2.37 " 4850 "
So get either a 2.55 box or an 82" prop set around 5400 and ride out. tweak it from there. Also I would more concern where it made its peak torque.
CarMotorBarge
Re: Prop speed RPM
Postby CarMotorBarge » Fri Jun 16, 2017 7:15 pm
One Eyed Gator wrote:Just my 2 cents. Has more to do with tip speed than prop RPM.
2.55 " 5400 "
2.37 " 5050 "
2.55 " 5200 "
2.37 " 4850 "
So let's assume the peak torque is at 4500. How would this change your recommendation above on the gearbox ratio and prop length?
Coastslider
Re: Prop speed RPM
Postby Coastslider » Fri Jun 16, 2017 9:32 pm
Manufacturers prop rpm has a lot to do with tip speed. Not to mention width and pitch. How does this change your theory ? The more width and pitch the more drag and vibration. This changes rpm recommendations. Propeller theory is deeper than this argument
Re: Prop speed RPM
Postby kwanjangnihm » Sat Jun 17, 2017 6:55 am
James here's a visual of the prop speed 2000-2500 (for the EX) with 3 different ratio's.
JAMES
Re: Prop speed RPM
Postby JAMES » Sat Jun 17, 2017 5:20 pm
2.55 not gonna happen i think im gonna try 238! 255 more for racing ive been told and noone ive seen really likes it compared to 268
ffjpowell
Re: Prop speed RPM
Postby ffjpowell » Sun Jun 18, 2017 9:18 pm
www.hoverhawk.com
Try this site. I went with a 84" R series and a 2.7 belt and am very happy with the results. U can teeek ur #'s accordingly. Out site temp is in Celsius so just figure out ur average temp for ur area and convert to C*.
Sent from my SM-N920P using Southern Airboat mobile app powered by Tapatalk
What the mind of man can conceive and believe, the mind of man can achieve.
Live today like theirs no tommorrow.
New build on the way!!!!!! Stay tuned.
J. Powell
Prototype
Re: Prop speed RPM
Postby Prototype » Thu Jun 22, 2017 9:04 pm
James,
I don't have a excel spreadsheet for you like some. That's what you asked for but since you seem lost with tip speed v performance of a ww blade, I can only imagine your still lost?
If not post what you did or bought to kick that sucker in the ass!
Normally I would never post to a ex 220 guy because they are a hint below a stock dd caddy!
I know you have the answers to your question but is that question correct? Is tip speed your major concern over performance or gear or number of blades? Of course you could be feeling out the census for what they know to a vague question? I highly doubt your power comes in at 5400 unless your looking for a 3 gear and have about 40 k into that motor
JAMES
Re: Prop speed RPM
Postby JAMES » Sun Jun 25, 2017 10:18 pm
Prototype wrote:James,
Unless the dyno lied it does i was their we changed cams multiple times and went with different lifts and Grinds im making @4700 490.7 and 440.1 my boat will break free at 36-3700
With 3 adults its a well built engine
Users browsing this forum: No registered users and 16 guests
