Steering connecting rod for bell crank steering
CypressHunter
Postby CypressHunter » Fri Jul 28, 2017 5:48 pm
I want to make a new connecting rod that goes from my steering rod to my bell crank. It appears to me that whoever made it before just blazed a bolt into the end of 1/2 conduit to screw a heim joint on. The 1/2 is just too flimsy. Either way I need to know what kind of bolt is safe to braze. From so research I have read it looks like I need an A307 plain steel bolt. What is safe to braze with getting all the toxic fumes
glades cat
Re: Steering connecting rod for bell crank steering
Postby glades cat » Fri Jul 28, 2017 8:18 pm
I used a 1/2" EMT with the brazed on bolts and sleeved with 3/4" EMT.
CypressHunter
Postby CypressHunter » Sat Jul 29, 2017 6:42 am
Define sleeve... did you just slide it inside the 3/4 in? Or secure it some how?
glades cat
Postby glades cat » Sat Jul 29, 2017 7:02 am
You slide the 3/4 over the 1/2", leaving some of the 1/2" exposed, and brazing it to seal the ends.
hdsadey
Postby hdsadey » Sat Jul 29, 2017 9:53 pm
If you take standard zinc hardware and soak them in a little muriatic acid, it will eat the zinc coating off instantly. Fresh clean weldable steel is what is left. Whenever I have to weld a nut to a bracket that's what I do. No funny arcing or fumes. Just make sure to rinse thoroughly before welding.
02 Predator 12' 0320 Lycoming
92 Big O 12' 302 Ford DD
CypressHunter
Postby CypressHunter » Sun Jul 30, 2017 5:20 pm
glades cat wrote:You slide the 3/4 over the 1/2", leaving some of the 1/2" exposed, and brazing it to seal the ends.
How well does it's stiffin it up
pontoon outlaw
Postby pontoon outlaw » Sun Jul 30, 2017 6:25 pm
, that's how we did mine just brazed the bolt so you can screw the heim joint to been that way 15 years
Sent from my E6833 using Southern Airboat mobile app powered by Tapatalk
CypressHunter
Postby CypressHunter » Mon Jul 31, 2017 7:55 am
pontoon outlaw wrote:, that's how we did mine just brazed the bolt so you can screw the heim joint to been that way 15 years
That's what I have now but the 1/2 conduit is flimsy and has too much play for my liking
