Rudder Coated with Bed Liner
jrowan
Post by jrowan »
I have had great luck with bed liner on other projects. Do you believe that spray on bed liner would create enough drag to hurt the boats performance?
15' Fiberglass
500 Caddy DD
74" Whispertip
bkmail
Re: Rudder Coated with Bed Liner
Post by bkmail »
What is your reason for doing this?
Bk
jrowan
Post by jrowan »
I had to do some bodywork on my rudders and need to paint them. Bed liner would cover my mediocore bodywork skills better than paint. I am just concerned that the texture may create drag. I hope it would be so miner that I wouldn't notice. Looking for some advice.
Sent from my XT1585 using Southern Airboat mobile app powered by Tapatalk
15' Fiberglass
500 Caddy DD
74" Whispertip
Gary S
Post by Gary S »
Spend more time on body work and paint. It will look a whole lot better and you don't have to worry about drag.
Post by Deano »
I tend to agree, that wouldn't be my first choice either. However to answer your question . . .
jrowan wrote:. . . Do you believe that spray on bed liner would create enough drag to hurt the boats performance?
I do not believe the performance penalty would be measurably noticeable, though. Compared to other causes of puny performance, I wouldn't consider it as a source of heartburn until after everything else was perfect. 1/4" smaller squares on your cage wire would probably make a bigger difference.
Standard Disclaimer: If you have 5' rudders on an under powered mini,
or are putting a gallon on each rudder to create a knock down effect . . . . well, you know . . .
jrowan
Post by jrowan »
I'm just hoping to create a durable surface without hurting performance to much. Thanks Deano! I've picked up a lot of valuable information from your comments in the past so I'm very grateful that you took the time to answer my post.
15' Fiberglass
500 Caddy DD
74" Whispertip
THE NIGHT RIDER
Post by THE NIGHT RIDER »
We all learn when deano chimes in .
Sent from my SM-G935P using Southern Airboat mobile app powered by Tapatalk
!!! IM THE REAL NIGHT RIDER B!TCH !!! !!! AND A PROUD TO BE IN THE DIAMONDBACK FAMILY !!!!
skinnypockets
Post by skinnypockets »
Another thought, the demples in a golf ball reduces drag and allows the ball to travel futher, could the bed liner have the same effect on a rudder?
:rebel: :florida: :old_glory:
Lwells
Post by Lwells »
Have you thought about putting a little colored dye in some fiberglass and spraying or rolling it on the rudders. It would be slick after you sanded and buffed it. Or , what about polyurethane in something that would make them look like wood and be harder than a rock and slicker than snot.LOL Just some thoughts. But I have to agree with the above post to get better with your body work.LOL
jrowan
Post by jrowan »
I went back over the rudder with Bondoglass, sanded and painted. Smoothed them out nicely. Thanks
15' Fiberglass
500 Caddy DD
74" Whispertip
Gary S
Post by Gary S »
The right way.
KC5AKB
Post by KC5AKB »
What about a rudder wrap ?
Painterchicvinyl@gmail.com
Does good work and it's custom.
Sent from my SM-G900V using Southern Airboat mobile app powered by Tapatalk
BRAB45 RRAB 17
helicsher
Post by helicsher »
Cut them in half, then put them back together with flex tape!
"Success Requires No Excuses"
