Engine stand Measurements for a csb and a stinger gear box
Roy.grohler
Postby Roy.grohler » Wed Nov 29, 2017 8:26 pm
I an setting up my new boat and need help with the engine stand 83 in prop ,stinger box and a small block Chevy. I need a drawing with Measurements please
Re: Engine stand Measurements for a csb and a stinger gear box
Postby SWAMPHUNTER45 » Thu Nov 30, 2017 9:19 am
Roy all the different type and length hulls tend to get a custom spec as stringers vary as does a customers desire for configuration.
It may prove beneficial to look a few boats over and determine what type rigging and features you would like. Take some pics and ask if you could get measurements. If you could find a sister hull with the same power this would really be the easiest way to be sure of what your building as some boats like hull jacks etc.
Postby kwanjangnihm » Thu Nov 30, 2017 10:12 am
some info to get you started :thumbleft:
link to photos of engine stands: https://www.google.com/search?q=engine+ ... 20&bih=951
post: viewtopic.php?f=48&t=42174
Roy.grohler
Postby Roy.grohler » Thu Nov 30, 2017 11:05 am
It's a 16x8.6 Alumitex hull. I got the picture I need the measurements to make the one in the picture above I live in ky and there not many air boats around .
Roy.grohler
Postby Roy.grohler » Thu Nov 30, 2017 2:18 pm
I have the engine and gear box and prop .the problem is getting a flat spot to put the hull and hang the engine I have a welder and access to all the steal to make it . The prop is a 83 in sinnitch r .trying to get measurements to make this a little easyer.
Users browsing this forum: No registered users and 10 guests
