Floral city hull opinions
Chrisco148
Post by Chrisco148 »
Looking to get some opinions on a hull I’m looking to buy, not sure of year 14’ floral city with poly, rake and walk boards. Seen some not so good opinions and great opinions with nothing in between!! Not looking for a $40k build, just a nice all around reliable boat. Any issues to be concerned with, areas of known failures to look for? As always thank you for your wisdom, Chris
:old_glory: 13’ cottonmouth , 472DD, buddy Branch cam, 72" WW sig. series. :florida:
barhopper
Re: Floral city hull opinions
Post by barhopper »
I believe that their bottoms were two piece, a seam down the middle under the t-bar.
Rick McC.
Post by Rick McC. »
My boat is a FC, an ‘07 built in late ‘06.
After 11 years of running exclusively in salt water, the hull is still in great shape, as is everything else.
Rick
http://guntipsandtalk.com
Chrisco148
Turns out to be an 07, with full rod boxes not walk boards. I will be buying it and hope for the best, looks like a very nice hull!! Thank you for the comments so far, any other opinions are welcomed since this seems to be a hull not discussed much for some reason... thanks again.
Chrisco148
Rick Mcc, what setup do you have and does it run dry ok? I know it’s more about the setup than anything just curious on how the hull reacts compared to another. Stay pretty flat in the turns? Plan on? Thanks again....
Post by One Eyed Gator »
Everyone I have ridden in except one rode hard on the nose.
Chrisco148
Could be countered by setup I would think?
Rick McC.
Post by Rick McC. »
Chrisco148 wrote:Rick Mcc, what setup do you have and does it run dry ok? I know it’s more about the setup than anything just curious on how the hull reacts compared to another. Stay pretty flat in the turns? Plan on? Thanks again....
Well I’ve never run it “dry” as most on here seem to mean; running through pastures, through the woods, etc., but it does fine for me when I need to run it up and over a key, marsh or mangrove patch to get back into the creek. It also does fine going over rock and oyster bars.
It’s 18X8 with a two foot solid catcher, high transom, all stainless rigging, 454CID/425HP Edelbrock crate motor, with 2/1 belt drive and three blade Whirlwind stump puller prop.
Rick
Rick McC.
Post by Rick McC. »
One Eyed Gator wrote:Everyone I have ridden in except one rode hard on the nose.
Mine does too, if I really get on it when loaded down.
When I’m by myself, only about the last three feet of the hull is touching the water when on the plane.
Rick
Chrisco148
Good stuff guys, I really appreciate the info. I’m gonna get the hull and see how it turns out..... thanks again!!!
Best of luck with it Chrisco and put a lot of thought into the balance point after hearing this info about being a boat that tends to go to it's nose.
What is ironic from my observations is most of the Floral City boats have a trim tab ???
My observations: Trim tab, belt drive, mid level modest engine power, frequently built with heavy accessories like power poles or fancy tops.
As history has shown the set up is a huge piece of the total performance of the boat. Some require more tuning than others but forethought goes a long way to getting the final ride quality your after.
I have been to their shop numerous times they are very helpful. Mike and Terry his wife run the place and are who to talk with if your over that way.
