Blue iron poly??
bowfish00
Blue iron poly??
Post by bowfish00 »
Wondering if blue iron poly is better than uhmw? And how thick?
Prototype
Re: Blue iron poly??
Post by Prototype »
What ever you do or decide, don't seam the bottom with the IRON products and expect your boat to act normal?
bowfish00
Post by bowfish00 »
Is it actually thicker?
Post by Deano »
You can typically buy the thickness your application calls for and/or what your wallet can stand.
While all manufacturers may not offer or have all sizes at all times, it is usually available in 1/4, 5/16, 3/8 and 1/2" afaik.
terrible ted
Post by terrible ted »
Blue iron is uhmw compare the additives.
lariat
Post by lariat »
I've had the Blue Iron for about 6 years now and it has held up very well.
terrible ted
lariat wrote:I've had the Blue Iron for about 6 years now and it has held up very well.
THE QUESTION.
IS HOW MUCH DO WE RUN DRY? I don't know how to gage that. I say you go by the material coefficient of friction.
My boat still has the same poly from 2009. I try not to just burn fuel and run dry every were. Man does it eat fuel running dry. I can say a spray rig saves fuel.
