Rubber pads between rigging and deck
Seven3
Post by Seven3 »
What type of rubber are guys using to make the pads to separate the rigging from the boat deck? Last time I made a set I used some stuff from ACE Hardware and it didn't last. I'm thinking something like this? 1/8 thick neoprene rubber?
https://www.ebay.com/itm/1-8-thick-Neop ... rk:14:pf:0
mad_mike
Re: Rubber pads between rigging and deck
Post by mad_mike »
I used EPDM roofing for the isolation between my cage mounting to hull and seat stand to hull. It has held up well for eight years.
Gary S
Post by Gary S »
I just bolt it to the deck. Never had any problems. Deck has paint, rigging has paint. I haven't had any corrosion problems.I think if I did put something between them I would use some conveyor belt.
SeatCover
Post by SeatCover »
Sidewalls from an old tire
Post by John Fenner »
Bolt it direct as Gary said.
SuprchgedPalmBeach
Post by SuprchgedPalmBeach »
Directly to deck.
