I'm Building 2 Stossel Boats with High Torque Motors
Post by Slidin Gator »
During my last ride at Mack's, the sled just didn't slide right. Climbed under it when I got home and found that the trailing edge of my poly is lifting off the rivets, time to take her out of service. Luckily I already had a plan, so it's time to implement.
I have two identical 14x7 High Side, open hulls originally built by Bob Stossel. They were called Marsh Master back in the day. These are light weight, riveted 0.100 aluminum hulls, originally built narrow to run ground with 6 cylinder Aviation power.
To date I have been running the Ugly Duck and I have been focused on the motor, running it for 3 seasons while upgrading as I went. It's finally time to get rid of all the God Awful, extra heavy rigging and get back to how these boats were supposed to be rigged. The boat is rigged with heavy square tube, easy to weld, not so easy on the scale. As she sits now she is 1,700 lbs full of gear and cooler, 1,880s full of 28 gallons of fuel, not including riders.
The new boat is a sister hull all done up. The bare hull as she sits weighs 440 lbs and is finished in Steelflex 2000 on the hull and Rapter on the topside, non-skid all around.
I dropped this hull off with Trevor Booth Saturday to get conduit rigging & cage, a solid aluminum grass rake, some seats and other odds and ends. If you value the paint job on your truck, I suggest avoiding Okeechobee County for another couple of weeks, damn they are thick this year.
It looks like Trevor & Michelle (Booth) have already hooked me up with the perfect seats!
I will be refurbishing the following from the present Ugly Duck and moving them over to the new boat "Ghost":
- Rudder
- 500 Ft-Lb O-540 Engine
- Engine Stand
- Prop & Hub
- Fuel system
- Gauges etc.
I can't wait to pull all that old square tube rigging off the old boat and weigh it. Between light weight 2 seat conduit rigging and deleting the poly, I am hopeful to get the Ghost boat well under 1,500 lbs without fuel. My plan is to have the Ghost up and running for Gator season.
Boat #2 is not yet named, but it is gonna be a rebuilt version of the Ugly Duck. The weight of the existing rigging will help guide my weight budget and power plant options for Boat #2. The engine for boat #2 is gonna out do Ghost for certain, but is not settled by a long shot. My baseline is a 600 ft-lb IO-540, but #2 is gonna be a no holds barred build, consider me call me CM curious at this point, any solution is gonna make some prop torque for sure. Both boats are gonna be 2 seater, front driver hunt style set ups. Both are gonna be outfitted with an add on jump seat in front of the driver. The plan at the moment is to have Boat #2 complete by summer 2020, but I'm not gonna stress over that one.
We all have to have goals. My goal is to haul 2 people and a dog or two anywhere I need to go, then add a deer and/or a hog and bring em all back to the launch in the heat of the day. Ghost should do all of that and the motor will be a lot happier than she is now with the Duck. My added goal for boat #2 is to haul all of this a minimum of 40 miles of solid dry on one load of fuel, starting fully loaded at the North end of Lake Washington in the dry season, that place is One Rank Marsh. :bom:
More as we go :thumbleft:
Seven3
Re: I'm Building 2 Stossel Boats with High Torque Motors
Post by Seven3 »
That’s cool. Are they older boats that were lightly used, or were they never rigged?
Seven3
Post by Seven3 »
And I have have a question for you, seeing as your new hull is painted inside. And even though I don’t know your background, judging from your prior posts you seem like a knowledgeable guy. What’s your opinion on painting the inside of the hull on a riveted boat? I just had a new riveted hull built, and initially I planned on painting the inside of the hull before it was decked over. But in the end, I decided not to.
Mainly because I was afraid of water leaking in from the bottom through the rivet holes and seams and getting trapped between the paint and the metal. I’ve had riveted boats since I was a kid...even the tightest ones still leak through some of the rivets when enough of the bottom paint gets knocked off. I was thinking that it would be a bad thing for water that leaked in from the bottom to get trapped once it got to the inside of the hull under the paint. Thoughts? And my boats are stored indoors, so I figured that’s another reason it wouldn’t be necessary.
radtech
Post by radtech »
Awesome brother! If the new one will be lighter and better than the old one, it ought to be a monster! I never saw you struggle anywhere...except when towing my barge. lol Look forward to riding with you next time I'm down
Post by kwanjangnihm »
Slidin Gator wrote: call me CM curious at this point
SG keep your man-card punched! don’t be drinkin that CM kool-aide, that’s all smoke n mirrors, high rev low torque blah blah, never see those guys deep in the sheet where the real AC guys hang, they’re all the time gettin towed in, rebuildin their junk, spewin ani-freeze and polishin their rudders. :stirpot: :toothy7:
flcracker9
Post by flcracker9 »
:lol: :lol: :lol:
Gary S
Post by Gary S »
I had to rebuild the cage on my latest boat after I stuck a frog gig in the prop. (I also had to get a new frog gig) The cage was DOM so I thats what I put back. It was the first time I used it and I was impressed. It welded easier and worked the same as conduit and was lighter in the end.
I was at a friends house that has started doing stainless cages and he was showing me a new cage they had built. It was off the boat sitting on the ground, he got on one side and I got on the other and lifted. I was surprised how light it was. Especially when we picked up original cage. You also don't have paint or powder coating to contend with.
Seven3 wrote:That’s cool. Are they older boats that were lightly used, or were they never rigged?
Both are 30 year old hulls, rode hard and put up wet. They were daily work boats at a gator farm in Louisiana. The Ugly Duck is on at least the second set of rigging because I know Bob Stossel didn't build that heavy setup. It was running, but just barely when I got hold of it. The Ghost hull was refurbished by Mike Stossel a couple of years ago.
Seven3 wrote:And I have have a question for you, seeing as your new hull is painted inside. And even though I don’t know your background, judging from your prior posts you seem like a knowledgeable guy. What’s your opinion on painting the inside of the hull on a riveted boat? I just had a new riveted hull built, and initially I planned on painting the inside of the hull before it was decked over. But in the end, I decided not to.
Seven,
I think you probably made the right choice going un-painted. Your thoughts are exactly right about water leaking under the paint, in particular on a deck over where you don't have good access. The Ugly Duck shows exactly the result, lot's of corrosion inside the hull with the old paint bubbling and lifting up off the corrosion. That hull is going to get a full strip down and blast, I don't really know what shape it is in until I get the poly off. For these old hulls, being open hulls, paint is about the only way to make them look good after all the blasting, which is really the primary reason for the paint job. All that said, 30 years of service in brackish water and still serviceable says paint isn't a deal killer either.
As a point of reference, note all the un-painted aluminum trailers. When left un-coated, aluminum uses all of it's surface area to dissipate electrical flow, which is driven by dis-similar metal joints, like rivets on the boat and steel hardware on a trailer, not to mention stray current from the boat electrical systems. When coated, corrosion accelerates at any breaks in the coating because there is less surface area to dissipate the electric flow. Without coating, corrosion is slower and more uniform. Coating just makes it look good, but it needs to be maintained.
Gary S wrote:I had to rebuild the cage on my latest boat after I stuck a frog gig in the prop. (I also had to get a new frog gig) The cage was DOM so I thats what I put back. It was the first time I used it and I was impressed. It welded easier and worked the same as conduit and was lighter in the end.
It will be conduit and DOM tubing. I was originally thinking aluminum, but Trevor convinced me the flex of an open hull will crack the aluminum, which makes sense to me, I want easy. 160 lbs for conduit & DOM, vs. 140 lbs in aluminum, not a deal killer. Ghost isn't gonna be fancy and certainly not shiny. Rust makes better camo than shiny SST.
I never said High Rev, Low Torque. But this is just the kind of trash talkin I was lookin for :salute:
Seven3
Post by Seven3 »
Slidin Gator wrote: Seven,
That makes sense, thanks for the info. I never even thought about it from an electrolysis stand point, but you make a good point with that. I’m not an engineer or a mechanic, but I try to look at things and figure things from an analytical point of view. This was my first new hull and it cost me over 10k, trying to do everything I can to make it last me a lifetime.
YOU CAN'T HIDE BIG MONEY GATOR !
I will take my HIGH REV...….LOW TORQUE junker and get to the back of the line...lmao
I will be well under the $70K bogey with 2 great running boats. It just takes 5 years total.
It is helpful that my youngest just Graduated college. Now I can focus on important stuff!
pipedog
Post by pipedog »
Lookin good Buddy!!
:salute:
Palm Beach open hull 13'9" with 6.0 F.I. LS - Ox Box and a 3bld "R"
I just got the ugly duck stripped, I used a digital fish scale and weighed every thing that came out/off the duck. I have a spreadsheet list of everything to post shortly just as soon as I get a crane scale for the major pieces to confirm my fish scale numbers. Regardless, holy crap, I've been hauling around 350 lbs of rigging and cage alone. The misc. crap list is interesting, start with 9 lbs of rope, just rope!
This first boat is gonna be so much lighter, it's gonna run like I added 100 ft-lbs more torque easy, but no changes to the motor.
Here is some history associated with these two hulls. Enjoy and thank Vickie for making it.
https://vimeo.com/111697453
https://southernairboat.com/phpBB3/view ... hp?t=64334
Vixter wrote:Check out this awesome documentary about a legendary airboat engineer from south Florida. It's based on a true story about the life of Bob Stossel, Airboat Engineer- Florida Pioneer. Enjoy!
Make sure you click on HD button to watch it in High Definition... it really makes a difference in the viewing quality.
- Vicki Gordon Dameron
Here is part of the crap I found up under all the weeds:
Yep, been hauling a 24 lb winch forever. The one time I needed it I had left it at home to keep weight down. A come a long will work just fine for emergency service going forward.
And yep, them's my socks, wool drys out a lot quicker than cotton in the summer, stays cool in the winter. Best wading socks going.
CarMotorBarge
Post by CarMotorBarge »
Slidin Gator,
You stated the following in other thread:
"I certainly did, no doubt higher HP produces higher static thrust. Thrust needed is a function of the hull, friction and the load. I spot you top thrust king on the thrust tester vs. my 500 ft-lb motor. I am interested in the thrust response comparison, time to 90% of max thrust for a given rig. 40 yard dash, climb the hill and follow the leader through the woods, that's what counts. We are gonna have to set up an obstacle course"
We definitely need to measure how the LOW TORQUE LS will compare to the HIGH TORQUE A/C engine on thrust response. How about doing the following:
1. Do a 40 yard dash in the water.
2. Do a 40 yard dash on the hill.
3. Climb Obama Ridge.
4. Run a timed obstacle course in Gardner's Marsh.
5. Measure on the thrust tester the time it takes to go from idle to 1200 foot lbs of thrust.
All of these tests are stacked in favor of the HIGH TORQUE A/C engine.
I said it, said I said it, now I am saying that I said I said it.
#'s 1-4 look like winners to me.
#5, I already said I would spot you thrust king, make #5 maximum thrust. If Boat #1 makes 1,100 lbs I will be smiling. Boat #2 will be at least 1,200 lbs thrust. These are 7 foot hulls, 76" prop diameter is maximum and will have to wait for Boat #2 and a new engine/stand.
#6, Quickest time to 90% of maximum static thrust (for each rig). Not which one snaps prop RPM the fastest, thrust vs. time.
#7, Slow competition, run a course without stopping, taking the longest time.
We can add top speed if you want, but this is gonna be a 45, maybe 50 mph boat. I'm not interested in speed
#8, 2 bonus points for whoever tows in the other.
CarMotorBarge
So we agree on items #1 thru #4. How about this for items #5 thru #9:
5. Measure on the thrust tester the time it takes to go from idle to 1000 foot lbs of thrust. If your BIG TORQUE A/C motor can't make 1000 foot lbs of thrust, we will drop to 900 foot lbs of thrust for the test.
6. Quickest time to 90% of maximum static thrust (for each rig). Not which one snaps prop RPM the fastest, thrust vs. time. Keep in mind that the LOW TORQUE LS might make twice the static thrust of the BIG TORQUE A/C. So I have to SNAP thru twice the prop resistance to get to 90% of max static thrust. So the LS has to do twice the work. Doesn't sound fair for the LOW TORQUE LS, but I will accept the challenge. Doubt I will win this, but lets see how close I come. 8)
7. Slow competition, run a course without stopping, taking the longest time. Not sure why we are doing this, but we can do this on the hill and in the water.
8. Tow a boat on plane. So the boat you are towing has to be on plane. 8)
9. Race in the water 400 feet. These short races are all about snap. The BIG TORQUE A/C should have an advantage here.
Does this sound acceptable for the LOW TORQUE LS vs BIG TORQUE A/C Challenge?
CMB,
All good for me, a couple thoughts.
Between #5 and #6 I say sure. I think you are sand bagging on #6. With 2.88 of gear your set up is gonna make more prop torque early on. The "Theory" that I am proposing is that thrust is going to be reasonably linear with the engine torque curve during prop acceleration. We need to measure thrust, RPM and time. We baseline a static thrust curve (thrust vs. RPM) for each rig. If my Theory is correct, thrust during prop acceleration at any given RPM will be greater than the thrust taken from the static curve. If I am wrong, thrust will be equal to or less than the static curve.
My point is that you don't have to spin the prop up before thrust comes in, you just have to spin up to the torque band. That is why I came up with the 90% (or 80 or 50%) of max thrust figure, it really measures the area under the torque curve while accounting for differences in the power level for each rig. At the end of the day, I am most interested in response in the operating range and do want to test thrust response from various steady state RPM's.
But no need to complicate all this, #5 and #6 combined is enough to call it agreed and we move on.
#7, Go slow in the water is stupid, no need for an idle competition, handy for docking and bow fishing I assume, but no a concern for me. The go slow competition is all about how I use my boat. Is the boat and power controllable to hold at the just break friction point while running ground, but able to light up when needed? The hill is OK, but doesn't really get to what I am looking for in a boat. I am looking for nasty swamp, maybe even some dry mud. Maybe we allow stopping (off the clock) and just say no stopping for longer than 15 minutes or longer (some folks call this stuck) :stirpot:
#8, I am sure that Barge Jr. will tow my boat and I am quite confident I will have no issues planning out Barge Jr. I am happy to leave this in, it's probably a wash. The 2 points bonus was for hauling in your rig when it sends a rod out of the block and through the prop. :stirpot:
#9, sure, race in the water, hopefully 1-2 inches deep so we can have some fun doing it!
Here is Hull #2, got everything stripped off. Time to chisel some poly rivets, this is why we have sons, he wants one of these boats, and I need lot's of rivet etc. work done.
Anyone with a keen eye will see that the rudder just had a run in with another trailer in the yard. Big "F" for me, I did that :violent1:
That's why we have sons, rivet work and all. The other rudder needs way more work anyhow.
Here are a couple of pictures showing the corrosion on the inside. The last paint job was right over the original, no prep. It's all coming up in chunks. Gonna use, ... I mean, my son is gonna use a water blaster with a sand blast attachment to clean it all up after pulling the poly off.
OK, on to the good stuff. Motor, engine stand and fuel tank are all going into the Ghost. Gonna put new gaskets on the motor, blast and paint the motor stand, get new motor mounts and paint the fuel tank.
Finally, got a trailer that should work just fine, all it needs is a bunch of blasting, steel, welding, paint etc. Nice Mags though!
Time to clean out the shop and make some room.
CarMotorBarge
Slidin Gator wrote:CMB,
Slidin Gator,
Here are my responses to your comments above:
6. I am not sandbagging. Here is a link that you need to read:
http://mae3.eng.ucsd.edu/machine-design/gear-ratios
We can discuss later tonight the law of energy conservation and why gear boxes don't make additional power (can't do additional work) despite multiplying shaft torque.
7. We can find some nasty swamp to run. I will just point out that the LOW TORQUE LS will have to turn at least 3500 RPMs with the 2.88 ratio to break loose on the ground. At 3500 RPMs the engine will be getting into the torque curve of the motor. So I am willing to bet that it will be able to light it up (snap) to break loose. 8)
8. We need to see if you can pull my 5 seat barge back on plane. :shock:
9. 1 to 2 inches of water sounds perfect. Just take it easy on me on the hole shot. This LS will have LOW TORQUE. :shock:
:lol: :lol: :lol: :lol: :lol:
:thumbleft:
CarMotorBarge wrote:We can discuss later tonight the law of energy conservation and why gear boxes don't make additional power (can't do additional work) despite multiplying shaft torque.
I have never said that they do. I think we are done discussing physics and energy equations, I already posted test data from a water thrust unit that shows exactly what I am predicting. We will just let it ride until we test actual airboats.
I have already bought test gear, including a data acquisition package. I have a load cell to make a thrust rig, my plan is a trailer hitch set up for testing on the trailer, but your original suggestion of Simpson's rig is probably is a good place for actual testing, assuming the test rig can output a signal to the DAQ. Just need to get RPM into the DAQ. I can pull a tach signal off my ignition, I assume the LS EFI can supply a digital tach signal too. Will have to fiddle with this.
So round out competition with an even #10.
If Thrust leads the RPM curve, one point to team Torque. If thrust matches or lags the RPM curve, one point to team HP.
Here are my weight figures from the last boat, I pulled it into the shop and weighed everything that I pulled off/out of the boat. It appears that I have been running loaded between 2,200 and 2,500 lbs, even higher with a 3rd rider. The old Sq. Tube, rigging is unbelievably heavy. The Ghost is gonna loose some weight for sure, probably 250 lbs in rigging and poly alone, let alone all the extra crap that piles up, look at how all the little things add up to 100 lbs of crap!
According to Kwan's calculator, 250 lbs times 7' hull width equates to 1,750 ft-lbs of additional torque, it's just free torque. 8)
The weight of the Ghost boat is gonna give me my weight budget for new motor on Boat #2. I don't want #2 to come in any heavier than the Duck has been running, preferably less.
