Airboat Hull jet boat?
Nabagator
Post by Nabagator »
If anyone has pics, videos, or any advice for building a jetski powered hull please share. I moved to North Florida and want to build one to run shallow rivers in summer up here. I remember seeing one a few years ago on SA that a guy built and that's what give me the idea.
Sent from my E6810 using Southern Airboat mobile app powered by Tapatalk
bkmail
Re: Airboat Hull jet boat?
Post by bkmail »
Lots of mini jets using a jet ski motor.
Same idea I suppose.
Nabagator
Post by Nabagator »
I saw a small airboat Hull couple years back, maybe 10'6" with a jet motor glassed in the bottom and had two single seats built on rigging couple feet high. Does anybody have any pics or info on it?
rowdy1
Post by rowdy1 »
I saw one buried up in the bushes a few years ago! It was an old 11' Gore w/ a 1100cc motor and jet. It was a cobbled up mess but would haul ass in a straight line. It had zero control in the turns, and with the very low center of gravity it would break loose and slide. Once it started sliding there was no water to the pump, thus no control and the afore mentioned bushes! It was fun to watch though!
mojoe
Post by mojoe »
The are often referred to as jet-jons. Clint Rowe from On the Snap Fiberglass has made a few around here.
Basically he cuts the bottom out of a jet ski, motor, motor mount and all and glasses it in to the bottom of an airboat hull. Then makes a little rigging for seats and controls. Not rocket surgery and they get around good.
He is on FB Southernairboat if you wanted more info.
Mark 7:9
rowdy1
Post by rowdy1 »
The one I saw was not that technical. It had the motor inside the hull and the pump outside. It was all slide all the time! That flat bottom had zero grip in the turns.
Rick McC.
Post by Rick McC. »
Places we run, that intake would be plugged up in no time...
Rick
http://guntipsandtalk.com
SeatCover
Post by SeatCover »
I think you're referring to my jet jon rowdy1, it's a 12' with a yamaha 760 in it. Runs pretty good about 42 mph, but yes hes right it loves to slide, if it has a decent amount of weight in it and you slow down to turn it actually turns pretty good. I dont have any pics right now but will try to post some pics when I see the boat next time.
Nabagator
Post by Nabagator »
Love to see some pics or any do's and don'ts. I wonder if I jacked the hull and rounded it if that would help with the slide
Prototype
Post by Prototype »
I've played with tillers on an airboat hull up to a 25hp four stroke anchors and a person will need to attach either stacked or thick poly chines on it. Cutting water is pretty simple but not on a hull designed to drift from above with only outer turning chines.
SeatCover
Post by SeatCover »
I think keeping the bottom flat is important, I tried to make my bottom flat on my boat when we did the new stringers, and it still has a little hop to it, i opted to keep the poly on my hull ( for ginnie springs trips) so i just shimmied the poly and all good. Now if you bury the pump deep in the water like clints supercharged rig, it just plows the water and keeps the nose down and hook up better. My pump is only 1/4" below the poly. I also stuck the whole pump out the back, I think it helps steer better, and I'm the only rig that can just reach around the back of the hull to get grass and such out. That water gets chilly in the winter!
