putting more pitch in prop
cummins diesel power
Post by cummins diesel power » Sun Feb 06, 2011 6:48 pm
have a q series. Is it 55 ft lbs? I believe thats what i was told.
I got both blades on the same page. tracked them very carefully.
But i cant remember what to torque them.
15x7 1974 airgator,500 cadillac dd,74" q series sensenich prop, 1/2" uhmw poly.
18x8 2001 panther, 502 chevy, 2 to 1 century,3 blade 78" stump puller, 1/2" poly
Quackcephus
Re: putting more pitch in prop
Post by Quackcephus » Sun Feb 06, 2011 7:39 pm
cummins diesel power wrote:have a q series. Is it 55 ft lbs? I believe thats what i was told.
There oughta be some spec's on here somewhere... :wink:
http://www.sensenich.com/products/browse/12/5/418/0
:texas:
shiggs
Post by shiggs » Sun Feb 06, 2011 7:43 pm
Depends on what size bolts your hub has.
The 1/2" bolts are 60 +/- 2 ft-lbs The 9/16" bolts are +/- 2 ft-lbs. The bolt dimensions are the bolt size not the head size.
Hope that helps :D
Mitch James
Post by Mitch James » Sun Feb 06, 2011 7:48 pm
Cdp 60 +/- 2 ftlbs is what you want. Good luck. Sensenich's web site has install instructions in adobe reader if want to print them off.
2002 16X8 Airranger Rhino hull 502/502 2:1 belt with 3 blade WW Maximus prop
Post by cummins diesel power » Mon Feb 07, 2011 8:51 pm
well i got it done. it sounds good. i think she's goin to really move some air now :D
Return to “Texas Airboaters”
