Airboat Cages
CenTexAirboater
Airboat Cages
Postby CenTexAirboater » Wed Jan 14, 2015 2:39 pm
Does anyone know of a shop/person in the Central Texas area that is capable of bending hoops for a cage build at a reasonable price. Or what would be the most desireable way to make some yourself? :fishing :violent1:
1980 15' Panther 383 Stroker 2.3:1 Century Belt Drive--4 Blade 78" Whisper Tip Whirlwind Prop--1/2" Polly Bottom and Sides
kpfishin
Re: Airboat Cages
Postby kpfishin » Thu Jan 22, 2015 1:57 am
Jason Allen @ lonestarboatworks.com in Baytown, TX.
281-667-6102
18x8 LSBW, 509BBC with 84" 3 blade NGR "FOWL HOOK II"
Chaseh
Re: Airboat Cages
Postby Chaseh » Thu Jan 22, 2015 11:50 pm
You wanting alum or stainless?
dean
Re: Airboat Cages
Postby dean » Sun Mar 01, 2015 1:46 pm
I know someone who bought hoops for livestock trailer tops and made them into a cage from tractor supply
1996 Classic BRAB 3, 16 x 8, zz3 corvette 345 hp k-way gear drive, 78in 6 blade warp drive prop , on the hill at Poverty Hill
Bdriller
Re: Airboat Cages
Postby Bdriller » Sun Mar 01, 2015 7:09 pm
4'x8'x3/4 plywood cut out the size arch you want, make total width on wood 4-6" less than final cage width, mark top center of wood and center of 20' stick of stainless tube , line up these two marks and roll it around ,works best if you can clamp plywood down on a flat table slightly larger than plywood , makes beautiful hoops!
aggiejim
Re: Airboat Cages
Postby aggiejim » Tue Jun 09, 2015 1:57 am
I have a roller several allready rolled 3/4 stainless
16 x 8 floral city ls2 6.0 aluminun block 2.3 ch3
can u say addicted
16.5 x8 alumintech new build
6.0 ls2 2.3 ch3 3 blade
the aggie
Return to “Texas Airboaters”
