Putting propellers back on.
wal1809
Post by wal1809 »
At minute 4:40 what is this guy doing. I am,going back with my props and I am at this stage right now. No clue what he is doing though.
https://youtu.be/iNIfu7bkd2E
nomad41
Re: Putting propellers back on.
Post by nomad41 »
DON'T DO ANYTHING THAT IDIOT IS DOING.
Treasurer FAA
Svcliche@yahoo.com
diesel250rr
Post by diesel250rr »
Just to help he is degreeing or angling the prop from what I can tell rather then just using the marks on the prop also when the guys said don't do anything this guy is doing I think he is referring to don't use and impact but u only skipped to the 440 mark
diesel250rr
Edit I only skipped to the 440 mark and that's not a level it's an angle finder I'm pretty sure
wal1809
Post by wal1809 »
So be it I used a red sharpy pen to mark the position of the blades, I don't have to use that thing, correct.
Also was I supposed to use red threadlocker on the 7 bolts inside the gear reduction unit? The ones bolting it to the rear of the engine.
diesel250rr
Don't know that part just saying ehat I saw in the video so you could keep going on your assembly
Bdriller
Post by Bdriller »
So impact ranem to 175 torque wrench only showed that they were more than 80
wal1809
Post by wal1809 »
Thank you guys. I got her back together. I will fire it up in the morning. I need a clear head and clear vision to do that. Right now I have neither.
wal1809
Post by wal1809 »
Return to “Texas Airboaters”
