sensenich NGH prop
Newbee79
sensenich NGH prop
Post by Newbee79 »
[vimeo][/vimeo]I bought a 14ft combee and it had a old 350dd with a 72 water walker when I first got it.. The 350 didn’t have enough HP to push that prop pitched almost flat so I bought the NGH 72” to try and solve that. Before I even put it on I built a 383 stroker and cammed it for low end. Questions is: If I swap my ww hub with sensenich hub (which add 1” each way) that will take this prop to a 74” total, will that help? I should have gotten the Q series but now I’m stuck with the H and just looking for tips on how to fine tune. And feel free to put your 2cents in what you think the best prop is for the power and boat combo
Return to “Texas Airboaters”
