Intercom system
scorbin
Intercom system
Postby scorbin » Sun Sep 20, 2009 7:42 pm
I was out looking for an VOX intercom system for the boat... On a tight budget.
Here's a quick review of what I purchased. It's not in the piratecom league for performance, but also doesn't come with the piratecom price either!
Basically it's a Pilot Avionics/AVCOM knock off (read that as made in China). 2 year warranty, 12 volt. About $90 on ebay.
VOX and manual squelch.
Also purchased 2 headsets with noise canceling mics. About $75 each on ebay. URL with the specs at http://www.worldwideproductinc.com. Can't purchase directly, at least I don't think so. If someone wants the seller's id on ebay, PM me.
Today the wife and I tried it out. Vox worked great. The only complaint, well not really a complaint, is that the squelch is manually adjusted. So, if you set the unit at cruise and nail it, it breaks squelch. I can live with that. The headsets I purchased are only 21db noise reduction. After I ordered I noticed they have sets which which are in 28-31db range.
Here's a pic of the intercom and headset.
Dan
Head Set.JPG (25.11 KiB) Viewed 2220 times
Avix Box.JPG (50.41 KiB) Viewed 2220 times
Whitebear
Re: Intercom system
Postby Whitebear » Sun Sep 20, 2009 7:54 pm
Price is great !
Did the intercom come with a schematic diagram?
I have tried to design a cost effective intercom and so far I cant come close to building one for what "I" think they are worth. Would love to see their schematic and see how they did it.
Is it battery powered or does it get power from the boat?
Looks sweet
RaisingHell
Re: Intercom system
Postby RaisingHell » Sun Sep 20, 2009 8:22 pm
Nice man.. I have the avcom original stuff and have put it all on my boat with the rerig I just did. Havent got to try it but hopefully it is as good as yours... I can live with the squelch thing..
Nobody Is Perfect.... But I Am Damn Close!!!!
scorbin
Re: Intercom system
Postby scorbin » Mon Sep 21, 2009 9:45 am
Whitebear,
No schematics. :( I could take some pictures of the circuit board when I take it apart to remove the 2 cables that would go to the transmitter. It doesn't look like there's a lot of components in the circuit. Did a quick glace at the bottom of the circuit board, looks like 2 or 3 ICs. Most likely op amps. I'll tear it apart tonight if I get time.
Powered by either 2 9 volt batteries or off the boat's 12 volt. I only used the 12 v.
BTW, if you check ebay from time to time you can find the AVCOM units for $20-$40 used.
Dan
bob500
Re: Intercom system
Postby bob500 » Mon Sep 21, 2009 10:53 am
Sounds like a good deal, I just recently found a steal on ebay for Piratecom equipment and ran it yesterday for the first time. I don't have any experience with any of it, but the Extreme system we ran yesterday was nothing short of awesome. The Piratecom rep Trevor Luce has been very accomadating with technical support even though the system was used and I did not buy it from him. (support like that is becoming a very uncommon) My family and I could not be happier with our Piratecom.
Bob
Whitebear
Re: Intercom system
Postby Whitebear » Mon Sep 21, 2009 1:57 pm
scorbin wrote:Whitebear,
Dan
Thanks man, I would love to see the pictures. I had used nearly a dozen op amps (741s I believe) in various configurations and quite a few pots for setting levels. The thing was getting expensive, but was going to be expandable to 8 in/outs. I'm intrigued by this one now. I'll keep an eye on Ebay for a used one. Hell I would nearly pay that much just to know what chips they used. LOL :)
Scotty
scorbin
Re: Intercom system
Postby scorbin » Thu Sep 24, 2009 9:09 am
Whitebear,
Bad news... This thing has alot more components in it than I thought. See crappy (cellphone) photo below. About 10 diodes, 30 resistors, caps etc. 2 op amps (Dumba$$ me forgot to write the numbers down before closing it up). The 2 pots are very high quality. To be honest, I think after you bought all the parts (connectors & electronics) you would have $30-40 invested.
In any case, I emailed the company asking for a schematic. Don't hold out much hope, but what the heck.
Dan
Whitebear
Re: Intercom system
Postby Whitebear » Thu Sep 24, 2009 1:14 pm
Thanks man, TI just introduced some low distortion very quiet OP Amps. Guess I'll go see how much they are. Looks like they broke each channel out with resistive dividers and diode isolation. Cheep but it works. Don't have to use so many op amps that way. That's a lot smaller than I was coming up with. Looks clean and neat as well.
If your into this stuff, check here:
http://www.electropages.com/viewArticle ... icle=13861
scorbin
Re: Intercom system
Postby scorbin » Thu Sep 24, 2009 8:42 pm
I had to take it back apart to plug up the holes from the cables I removed:
LM389 - Low-Voltage Audio Power Amplifier with NPN Transistor Array
LM386 - Low Voltage Audio Power Amplifier
Whitebear, I'm a 1's and 0's kind of guy. Analog never was my cup of tea. :)
Dan
Whitebear
Re: Intercom system
Postby Whitebear » Thu Sep 24, 2009 11:05 pm
Thanks Dan, Ill check them out when I get back to the intercom project.
Seems like I have always had to dance back and forth between digital and analog. The surge of being a Jack instead of the Master.
Scotty
warrior-p
Re: Intercom system
Postby warrior-p » Tue Mar 02, 2010 12:23 pm
Be carefule if you switch the op amps from TI to another brand, the grounding changes from chip to chip.
18 x 8 TEXOMA AIRBOAT, ZZ540 engine, 2.38 BALLISTIC DRIVE and an 82" 4 blade Whirlwind Whispertip EX prop
Southern Style
Re: Intercom system
Postby Southern Style » Tue Mar 02, 2010 2:30 pm
Scorbin... What all did you have to do to the unit to get it usable... This is the exact unit I chose for my boat... Did not know I had to open it up and cut wires... How difficult is it and is it worth it. Before I spend the money on the box and 4 headsets........
Thanks for the reply...................
KRVSA Member
SJRAA Member
KCCO
Buzzman
Re: Intercom system
Postby Buzzman » Thu Mar 04, 2010 10:10 am
I have been using an intercom that came from small aviation stuff for several years and love it. Everyone that rides with me loves the idea of being able to talk while we ride. I like it becaure is adds safety to boat. I can direct riders what not to do as we ride along.
I did learn some lessons in getting started using this gear. Most any of the intercoms seem to work pretty good. The real deal is in the sound canceling mic's on the headsets. No amount of foam will help when you turn you head towards the rear. I keep mine in one of those orange water tight boxes. I am building a new boat now and thinking of putting the intercom into the console and having ports to plug into. Im just not sure if the jacks will hold up to the weather. I am also working on patching in the radio to the intercom so I can talk to my buddy as we ride in two boats. Most all of the parts I got came from Ebay also. I did find a good headset that comes for an ebay store.
16' Jimmy White Hull, 500 caddy, 72" Stump puller, Stainless rigging, Five seater family boat
scorbin
Re: Intercom system
Postby scorbin » Thu Mar 04, 2010 7:47 pm
[quote="Southern Style"]Scorbin... What all did you have to do to the unit to get it usable... This is the exact unit I chose for my boat... Did not know I had to open it up and cut wires... How difficult is it and is it worth it. Before I spend the money on the box and 4 headsets........
Thanks for the reply...................[/quote]
You don't have to cut the wires. I removed the 2 cables that would normally go to the aircraft transmitter, just to make it neat. All I did was connect the cigarette adapter to my boat, plugged the headsets in, turned it on, adjusted the volume and squench. The wife and I use it everytime we take the boat out. Let me know if you need any more info.
Dan
scorbin
Re: Intercom system
Postby scorbin » Thu Mar 04, 2010 7:56 pm
Just thought of something... For the "pilot" and "co-pilot" connections, make sure you plug the the microphone jack (the smaller of the 2 on the head set) into the bottom socket. So:
Top socket is the head phone jack connector, the middle connector is the PUSH-TO-TALK connector (not used) and the bottom connector is the mike jack. Left side is the "pilot" connections, right the "co-pilot".
Hope this helps.
Dan
Southern Style
Re: Intercom system
Postby Southern Style » Fri Mar 05, 2010 9:06 am
Gotcha... May give you a PM in about a week when they come in.. Might have some specific questions for you. You sound knowledgable in the wireing/diode/capasitor/thingie majigie bobbie things.......
KRVSA Member
SJRAA Member
KCCO
glades cat
Re: Intercom system
Postby glades cat » Fri Mar 05, 2010 6:08 pm
Pieced this system together. Only time I used it was in the back yard on the trailer. :lol:
I might actually use it one day.
scorbin
Re: Intercom system
Postby scorbin » Sat Mar 06, 2010 6:40 pm
I would not go back to not having an intercom system. However, from time to time it gets a tad bit old hearing, "Look at that one (yet another gator)" or "did you see that? (something else that moved) coming from my wife. :)
I'm about to order 2 more headsets for passengers to use.
Dan
Southern Style
Re: Intercom system
Postby Southern Style » Mon Mar 08, 2010 10:56 am
That is the ticket scorbin.... That is what I am ordering for the new boat.... Thanks and keep us posted....
KRVSA Member
SJRAA Member
KCCO
Users browsing this forum: Google [Bot], jayhoff and 8 guests
