stock 0470 continental hrspower
fishslayer
Postby fishslayer » Mon May 10, 2010 8:18 pm
I have a stock 0470 continental GPU dies anyone have a idea how much horsepower this motor has
SouthRiver
Re: stock 0470 continental hrspower
Postby SouthRiver » Mon May 10, 2010 8:30 pm
I am sure that this will get answered pretty quickly, but I think that a stcok GPU is actually about 180 hp.
"It is what it is......and...... "Everything happens for a reason, whether you like it or not......."
New boat is in the works..............
BCAA Member
N.R.A. Lifetime Member
billybob
Postby billybob » Mon May 10, 2010 9:14 pm
220?
I do all my own stunts!!!!!!
Bruce
Postby Bruce » Mon May 10, 2010 9:41 pm
between 175 and 185 at 2450rpm ive read tags that said both but the old times said at 3000 they were 220 so who knows
12 foot Mamba "The Underdog"
PJC
Postby PJC » Mon May 10, 2010 10:34 pm
If they are fresh 220 if they are wore out I've seen a 180 spin the same prop
gpu rick
Postby gpu rick » Mon May 10, 2010 10:55 pm
per the manual at 2900rpm net brake horse power of 205 hp, based on ambient temperatures of 60 degree F.
Southern Style
Postby Southern Style » Tue May 11, 2010 8:38 am
I am confused.. Please help... Thread titled "Stock 0-470 Continental Horse Power"... I have a Continental 0-470-R and it is 230 horse... Now, he said "STOCK 0-470 GPU"... Isn't a GPU a Ground Power Unit and that is a 220? If it is, then the 0-470 is not stock... it is a modified 220 with 0-470 jugs... Am not trying to be technical, but just wondering if there is a 0-470 GPU that is stock... Thought ALL GPU's were continental 220's...
KRVSA Member
SJRAA Member
KCCO
bmg
Postby bmg » Tue May 11, 2010 9:06 am
Your over analyzin. A gpu is still 470ci Like an aircraft 0470 except that it is totally different lol. single mag different grade materials, pistons and on and on. A stock 220 or gpu is supposidly 220 hp at 3000 rpms or so it is said to be, these motors were made for generators to run around 2400 rpms constantly. I would guess by the prop I am turning and the pitch I can run my hp is 200 or a little better. Some people have higher compression pistons (dome topped instead of a cup) in their gpu's from a/c 0470 which gives you a little more. As far as a stock 180 turning the same prop... I doubt it unless its a tired 220 which most are :lol:
Southern Style
Postby Southern Style » Tue May 11, 2010 10:29 am
Gotcha... He just threw me at "Stock 0-470 GPU"... GPU's are 220's for generators and then modified to a 0-470... I am with you now.... Thanks for the info............
KRVSA Member
SJRAA Member
KCCO
fishslayer
Postby fishslayer » Tue May 11, 2010 7:14 pm
THANKS FOR THE HELP: I HAD A AIR CRAFT MECHANIC SAY THAT IT HAD APPROXIMATELY 300hp THIS IS MY FIRST AIRCRAFT MOTOR >>>> DOES ADDING AN ADITIONAL MAG GIVE IT ANYMORE HOSPOWER AND IS IT COMMON FOR GPU UNITS TO LEAK A LITTLE OIL....
flyin blind
Postby flyin blind » Tue May 11, 2010 9:49 pm
there like a detroit diesel if they dont leak they are out of oil
old school is what got us here today . the most important six inches on a battlefield is between your ears!!!! mad dog mattis
Southern Style
Postby Southern Style » Wed May 12, 2010 9:21 am
flyin blind wrote:there like a detroit diesel if they dont leak they are out of oil
I have heard that for years, If it aint seeping (not leaking) oil, then you might want to check the oil level... :lol: :lol: :lol: :lol: :lol: :lol: :lol:
KRVSA Member
SJRAA Member
KCCO
bmg
Postby bmg » Wed May 12, 2010 11:34 am
Adding a mag may add more power in the right application. Hotter spark can't be bad :P . I would think that the most gain for adding a mag would be to also add more fuel to the equation meaning different carb or bigger jets. Rememeber you would have to change jugs or get them machined for the second spark plug hole. They all leak oil. I would love to see a gpu that doesnt. I love my ground pounder but I eventually will get a straight valve 540 when I save some money. Which may never happen.
gpu rick
Postby gpu rick » Wed May 12, 2010 1:45 pm
Adding a second magneto with make 100 rpm difference. Also they dont all leak.
my gpu 5.JPG (229.52 KiB) Viewed 3752 times
CypressHunter
Postby CypressHunter » Wed May 12, 2010 2:12 pm
fishslayer wrote:THANKS FOR THE HELP: I HAD A AIR CRAFT MECHANIC SAY THAT IT HAD APPROXIMATELY 300hp THIS IS MY FIRST AIRCRAFT MOTOR >>>> DOES ADDING AN ADITIONAL MAG GIVE IT ANYMORE HOSPOWER AND IS IT COMMON FOR GPU UNITS TO LEAK A LITTLE OIL....
YES!!!!
MYDIXIEWRECKED
Postby MYDIXIEWRECKED » Wed May 12, 2010 2:17 pm
Just don't take a picture of a GPU or a detroit diesel and put it on your wall in your house if you don't want oil stains on you floor! :lol: They all leak even the pictures!
THOUGHT FOR THE DAY
Lifetime member NRA
Users browsing this forum: Keeth1123 and 7 guests
