Welding emt
diamondback0320
Welding emt
Postby diamondback0320 » Sat Jun 19, 2010 8:21 pm
k,guys i bought a little welder today 115 70 amp flux core or mig w/covergas attachment i don't have a bottle yet & haven't welded much i have the 30 & 35 flux core wire,tried on some scrap not really impressed it will def. blow a hole in the emt,& gettin alot of spatter,just wondering if using the shielding gas makes a difference a friend told me it would,i know 230 volt would be better but $$$ was the difference,just fixing some welds that are opening up,trying to get opinions,thanks Tony! It seemed that the 35mm wire was better as far as not burning holes,witht the 35 i could get a decent bead without burning any holes,but alot of spatter!
aherr520
Re: Welding emt
Postby aherr520 » Sat Jun 19, 2010 8:40 pm
first sand the coating off the ends where your welding. If your going to use flux core use a sheilding gas then it won't spatter so much. If your burning holes in it turn the amps down and keep tring till you get it right I weld emt with the same welder and does a good job I hope this helps,good luck
aaof member
mike007
Re: Welding emt
Postby mike007 » Sat Jun 19, 2010 8:41 pm
you will get alot of spatter on emt because of the galvanized coating. try some anti spatter dip. also make sure your using flux core wire when not using gas and solid core wire when using gas. as for burning holes try to go a little faster or turn your heat down a little bit.
jb34974
Re: Welding emt
Postby jb34974 » Sat Jun 19, 2010 9:46 pm
u need gas .020 wire throw away that flex cored wire use 7018 or equal with argon & CO2 or straight argon if u plan to weld aluminum. EMT is probably the hardest metal to learn how to weld
and remember your putting your life on the welds your just learning on. i would not even concider riding on apprentise welds. some things you do not cut corners on in building an airboat welding being the top on the list. hire someone who does it for a living.
So shall it be as in the days of Noah and then the end.
deepsea diver
Re: Welding emt
Postby deepsea diver » Sat Jun 19, 2010 9:46 pm
1. Go to gas. 2. Use the anti splater spray. 3 Play with it. (practice, practice). 4. Turn the heat down and go a little faster.
The machine was made for this!!
NotAGuide
Re: Welding emt
Postby NotAGuide » Sat Jun 19, 2010 9:57 pm
Has anyone tried dipping the ends of the EMT in muratic acid? Works well with chrome tubing by eating it clean.
Professional JB Welder
Old 18' American hull, 470CID S&S, Ch3 2:1, 3-blade Whirlwind Whisper Tip
boobidges
Re: Welding emt
Postby boobidges » Sun Jun 20, 2010 10:43 am
make sure your power supply for your welder is good.if your running a long extension cord or have low voltage those 110's suck.i have one that i built 2 boats with.use 030/035 solid core with 75/25% mix ,take your time.if youre touching up old welds make sure they're clean.good luck
rbjscott
Re: Welding emt
Postby rbjscott » Sun Jun 20, 2010 11:37 am
Use CO2 or C25 gass. Argon is not a recommended gas for MIG when welding steel. CO2 is "hotter" than C25. C25 weld are cleaner, less clean-up.
"The price of Freedom is high! And the sound of Freedom is loud!" (Jet fighter pilot)
gruprgetr
Re: Welding emt
Postby gruprgetr » Sun Jun 20, 2010 11:45 am
look at the chart inside the door and start there
(SWAMP GAS)
IF YOU PISS SOMEONE OFF MEANS THEY HEARD YOU
AIRBOATS DONT SPREAD HYDRILLA
AIRBOATS DONT CAUSE ANIMOSITY- PEOPLE DO!!
PROTECT YOUR FUTURE WEAR A PFD AND VOTE!!
on a dark calm night ya can hear the cryaker scratchin on your poly
Crazy Frog
Re: Welding emt
Postby Crazy Frog » Sun Jun 20, 2010 11:48 am
:usa2: I've used my Elcheapo fluxcore for a few years and get pretty good results, just tac your cuts and then clean with a wire wheel or what ever before you finish weld, as far as splatter if it's not to bad, I don't worry about it to much, because what ever you are fabricating will have to be prepped for Paint or Powder Coat anyway! 4" grinder with the fine sanding disc's work good for removing any residue.
YES...Watch your voltage supply, long cord vers short cord in the beginning, but you will overcome most of this with settings and practice. Once you get your heat and feed set close, you should be able to fill a 1/2'' hole , you really have to watch the color while doing the fill, get your bead started , stop and before it goes out hit it again (so on and so forth). Yes the gas conversion is good, but the Flux ain't bad if perfected. Sounds like your fixin some bad welds, just clean the crap out of them and make sure your not welding over some brazed joints??
Have fun!!! :occasion5: :usa2:
ffcracker
Re: Welding emt
Postby ffcracker » Sun Jun 20, 2010 2:50 pm
Buy a tank of 75/25 argon/co2 weldgas, run the regulator around 15 and use solid core wire, dont run the unit on an extension corde. It will be a night and day difference. By the time you buy a couple of spools of flux core wire you will have paid for the tank and gass with better results. Be carefull turning down the heat, sometimes you dont get good penetration or whats called a cold joint. Play with some scrap lying around and then try to break the welds by bending the pieces apart, if the conduit breaks or bends before the weld then you are going down the right road and all you have to do is make them look pretty I.E. 15 degree angle on the electrode and when welding vertical start form the top and move to the bottom.
A RESENTFULL CITIZEN OF A DICTATORSHIP CALLED alachua county
BIGJOHNSON
Re: Welding emt
Postby BIGJOHNSON » Thu Jun 24, 2010 9:32 pm
SPOT WELD YOUR EMT , 30% OVERLAP ON EACH SPOT , MAKE SURE YOUR HEAT IS HOT ENOUGH , I'VE NEVER HAD ANY OF MY WELDS BREAK IN 15 YRS ON BOATS , TRUCKS , TRAILERS ETC. NOT SAYING I SPOT WELD EVERYTHING BUT I DO WHEN I BUILD RIGGING AND CAGES.
Users browsing this forum: jayhoff and 9 guests
