BBC Patriot heads - anyone running them?
warrior-p
Post by warrior-p » Mon Feb 14, 2011 8:57 pm
Was curious if anyone was running the Patriot heads fro a bbc? THe airflow on them seem to match the Brodrix BB-2 plus heads. The links show the flow rates.
https://www.patriot-performance.com/xca ... =33&page=1
http://www.brodix.com/heads/bb2.html
18 x 8 TEXOMA AIRBOAT, ZZ540 engine, 2.38 BALLISTIC DRIVE and an 82" 4 blade Whirlwind Whispertip EX prop
shiggs
Re: BBC Patriot heads - anyone running them?
Post by shiggs » Mon Feb 14, 2011 10:21 pm
Warrior--I think Felber was using Patriot heads on some of his 540s and 572s. You might call and ask him about them.
HOLESHOT
Post by HOLESHOT » Mon Feb 14, 2011 11:01 pm
THE BODIX RR-BB-O OVAL PORT HEAD IS THE ONE YOU WANT ON A 540 BBC YOU CAN EASILY GET 700HP ON A 502 WITH THE RIGHT CAM YOU SHOULD BE ABLE TO GET CLOSE TO THAT
OLD MAN JONES
Post by OLD MAN JONES » Mon Feb 14, 2011 11:08 pm
T O R Q U E I love em' :idea:
LIVING FOR THE FUTURE OF OUR EVERGLADES..
WWW.MACKSFISHCAMP.COM A traditional cultural Gladesman property.
Rich Andrews
Post by Rich Andrews » Tue Feb 15, 2011 6:47 am
i don't think Felber uses any heads out of the box,just a starting point
shiggs
Post by shiggs » Tue Feb 15, 2011 9:23 am
Rich Andrews wrote:i don't think Felber uses any heads out of the box,just a starting point
I did not mean to imply that he uses them straight out of the box, but he would be able to give you the skinny on them.
crowhater
Post by crowhater » Tue Feb 15, 2011 1:14 pm
Shigg it is go to hear from you! I started to wonder if you fell off the planet.
rost495
Post by rost495 » Tue Feb 15, 2011 3:13 pm
Steve has been posting on the Texas part of Southern Airboats quite a bit. Crab trap cleanups, grass plantings and such.
