lycoming wrenches
toyman69
lycoming wrenches
Post by toyman69 »
Need to borrow wrenches to do a jug swap on a narrow deck 170. located in Citrus near Potts, thanks Sam 352-464-3410
chugalug
Re: lycoming wrenches
Post by chugalug »
THEY DON'T LIKE TO LOAN NARROW DECK WRENCHES, CAUSE THE END WEARS OUT IF NOT USED CAREFUL. TAKE A 1/2 IN. & A 3/8 ALLEN WRENCH CUT ABOUT A 1/2 PIECE OF EACH , AND USE BOX END WRENCH WORKS GREAT DONE IT FOR YEARS. KIND OF PAIN IN A$$ TO DO REAR CYLS. TORQUE ONE GRUNT ON 3/8 STUDS, TWO GRUNTS ON 1/2 STUDS.
goldhunter_2
Post by goldhunter_2 »
chugalug wrote:TORQUE ONE GRUNT ON 3/8 STUDS, TWO GRUNTS ON 1/2 STUDS.
:lol: :lol: :lol: :lol: :lol:
:rebel:
watersports7
Post by watersports7 »
German Torque Specification: *To be said with a German accent*
How tight did you torque down those lug nuts?
Good-N-Tight!
12' Predator / Lycoming 4 Cylinder / Old Skool 68x38 Stick Prop
Perfectly said by Lycoming: Some engines purr like kittens. These roar!
HuntingBigun
Post by HuntingBigun »
I never like to loan tools, boats or wife, they come back dirty, worn out or leaking something :D
Bigun
http://www.krvsa.com
Trav-azz
Post by Trav-azz »
Www.ustools.com
$20 apiece a buddy of mine just order one after trying to borrow one for the last week. Watch the shipping cost though.
toyman69
Post by toyman69 »
Thanks guys, i am a heavy equipment mechanic, so i know what tools cost and how to take care of them. made wrench to fit all but one jug, just want job done right! i will look into ustools, Thanks for the replys Sam.
nomad41
Post by nomad41 »
its www.ustool.com no s after tool
Treasurer FAA
Svcliche@yahoo.com
chugalug
Post by chugalug »
I WAS GOING TO GET MYSELF A SET, BUT NOT FOR 50 BUCKS APIECE. US TOOL $20 WIDE DECK, $50 NARROW DECK WRENCHES
josh_2562
Post by josh_2562 »
This is where I got mine. They work great.
http://www.aircraft-tool.com/shop/detai ... D=6494-SET
Paid $6.50 for shipping and got them in 3 days.
dusty burch
Post by dusty burch »
if u buy the cheap ones they dont last the good ones r around $100 each but they will last a long time
mwood7800
Post by mwood7800 »
get the 100$ ones, the cheap ones suck, you will be lucky to do 6 cylinders with one set of cheapo's. I been there and tried it...
mojoe
Post by mojoe »
I have heard a couple guys drill out the hex wrenches and weld on 12 point bolts. The question is: Where do you fing good quality steel 12 point bolts to attach?
Mark 7:9
bbstimey
Post by bbstimey »
I replaced with ARP 12pt nut works much easier
14'x8' JB hull w/Stingered GO-480 w/ electronic ignition and 3 blade 80" R
fhp6
Post by fhp6 »
bbstimey wrote:I replaced with ARP 12pt nut works much easier
Do you have a picture of the modified wrench you could post?
:old_glory: FHP6
Citrus County Airboat Alliance (Member)
"USMC"
:florida:
Cmcintosh721
Post by Cmcintosh721 »
I bought a set from the Snap On man when I had my 0360 and they were not bad priced.
mojoe
Post by mojoe »
Thanks. Perfect.
Mark 7:9
bbstimey
Post by bbstimey »
not a wrench changed nuts to arp they are 12pt on out side
fhp6
Post by fhp6 »
Roger that...thank you!
:old_glory: FHP6
"USMC"
:florida:
mojoe
Post by mojoe »
Summit had them reasonable. Shipping was actually more money than the nuts. My plan is to modify the wrench. Drill a small center hole in the hex. Then grind it flat. Then set the ARP 12 point nut in its place, use the hole to visually center it on there and weld up the inside of the nut.
Mine has female 12 point nuts over the studs. So the tool/wrench needs to be male.
Mark 7:9
terrible ted
Post by terrible ted »
HuntingBigun wrote:I never like to loan tools, boats or wife, they come back dirty, worn out or leaking something :D
Not replying to this is chewing on me Could have so much fun with this. :twisted:
mojoe
Post by mojoe »
Turned out great. From a 6 point to a 12 point and ARP says those nuts are a lot harder than grade 8 steel. Really felt snug and fit all the way to the bottom of the bolt when I tested it.
Only "trick" was making sure to cut the nut in half before welding it on. That way I saved the bevel on the top and didn't have to grind it down to fit.
Mark 7:9
