Sprayer system
Bill H
Sprayer system
Post by Bill H »
I'm putting a sprayer system on my boat. Do I mount the spray nozzle straight out the front of the boat or do I turn it down to spray more on the boat. Thanks Bill
longshot123
Re: Sprayer system
Post by longshot123 »
have it spray at the hull-- so it run down the hull-- you may need more than one head
MacGyver
Re: Sprayer system
Post by MacGyver »
i mounted mine right up against the winch hook connection on my boat .That way it can protect it from whatever i run into :violent1: . You can buy a lot of different nozzles to try from Northern Tool. I got one from them and then i bought a few solid brass plugs and custom made a few to experiment with. The first one i drilled a 1/8 in hole and then made the hole obround and then i took a hacksaw and made a slot in it. Hope this helps
MacGyver
Tater Nutz
2012 15 x 8 ALum GTO w2ft grassrake
383 stroker 463 HP with stinger 255 to 1 soft drive
Sensenich 3 Blade 80" R series
Bill H
Re: Sprayer system
Post by Bill H »
Thanks guys that gave me some ideas.
Bill
fl cracker
Re: Sprayer system
Post by fl cracker »
Bill, let me know when you get it done. We are working on some biodegradable liquid to run in the sprayers. We should have the first batch ready soon and it will be cheap!
" I have two guns...
One for each of you "
2011 Al David / AV 540
nomad41
Re: Sprayer system
Post by nomad41 »
fl cracker lets hear a little more about this liquid.
Treasurer FAA
Svcliche@yahoo.com
fl cracker
Re: Sprayer system
Bob, send a pm and can tell you alittle about it!
PeaRiverOpossum
Re: Sprayer system
Post by PeaRiverOpossum »
I just did mine this week and have not even been able to check it out yet. One thing to keep in mind is where your bow hits the "stop" on your trailer. I had to put mine down on the poly so it would not hit. One other thing I will mention is that it hits on the roller at the end of my trailer when I unload dry. I bought the broadcast nozzle from Northern Tool for $20. You may be able to use a sprinkler head nozzle from Lowes or HD for less than $5. I dont know if it will put enough water out or not. If you can find one that puts out enough get the one with female threads so you cab get the right length nipple to reach through your poly and hull. I had to use a hole saw to cut through my poly so the the threads would reach through the FG enough to get a fitting on it. The one from Northern cost $20 but It looks like it will do a good job. Just be aware that the male threaded side is pretty short.
lorick
Re: Sprayer system
Post by lorick »
Please show picture if any.
swamp runner
Re: Sprayer system
Post by swamp runner »
just put one on my boat , gonna try it out tomorrow :!:
12' HAMANT ULTRALIGHT - 180 LYCOMING - 68" CYPRESS SERIES
