Flying airboats
- stroked470
- Site Supporter - III
Re: Flying airboats
I have personally flew a peanut gore haul ass boat back in 2001 and destroyed it, i have also put a deck over on its rudders, and had countless step boats flutter at 90+. This thread really dosnt apply to the average boat owner with the average round bottom boat do to the fact it isnt gonna run fast enough nor pack enough air to get it to lift...yes most of you guys boats act wierd at top speed of maybe 50mph and you think its gonna fly but it is going anywhere i promise you, the only thing you need to be concerned about is it taking a hard left when running that fast, not flying.
Re: Flying airboats
I think where you run along with hull style would apply too. Run down south and hit some of those patches of needle grass then transition back to the water pockets too fast and see what happens. The grass will give you a surprising amount of lift. And when you see a step hull chattering at a high rate of speed I think it is basically flying. Jmo
- John Fenner
- Southern Airboat Member
Re: Flying airboats
Dick Hoffman would fly his boat with a wing on the bow of his boat. DavieGSO480 could explain it better than me but tape short lengths of yarn to the inside of the grass rake and bow of the boat then run the boat and note any of the yarn standing straight up, then use a spoiler on the top edge of the rake to combat the lift and make the yarn lay flat.
Re: Flying airboats
Sounds like there's two options and two kinds of airboat operators. 1. Run slow enough to stay in control and be excited that you're not only a boat owner, but look at all the beauty and freedom. 2. Go like heck knowing in the back of your mind that at any moment it can all to go hell. And when it does, before you hit the water and get run over by your own boat, think to yourself, damn, I wish I had slowed down.
Re: Flying airboats
mscott, I,ll second that, the reason I got another boat was I missed the beauty of marsh and woods, I can,t enjoy if I,m going to fast to see it,besides I,m getting older and smarter.
- goldhunter_2
Re: Flying airboats
mscott that sounds like the perfect description
Re: Flying airboats
Sometimes there is an a$$ for every seat.
- Site Supporter - IV
Re: Flying airboats
Scarecrow Ive seen a few of those on the lake and trails
14'6" X 7'6" Diamond Back, ZZ502,
2-1 Century Drive 3 Blade 80" Power Shift
12 Hamant 0360 68" Sensinich
Glades Airboat & Buggy Association
Home of the Muck Boyz
- Bruce
- Contact:
Re: Flying airboats
mscott wrote:Sounds like there's two options and two kinds of airboat operators. 1. Run slow enough to stay in control and be excited that you're not only a boat owner, but look at all the beauty and freedom. 2. Go like heck knowing in the back of your mind that at any moment it can all to go hell. And when it does, before you hit the water and get run over by your own boat, think to yourself, damn, I wish I had slowed down.
Very well put
12 foot Mamba "The Underdog"
Re: Flying airboats
Whitebear wrote:Much of it has to do with hull shape, hull weight and speed. It seems to me that most boats cruise around the 30-40 MPH range. With that in mind if you regularly run at 50 MPH you wont have much fun cause you will constantly be running away from the folks you ride with. Now I am sure there are some light boats that will be getting squirrely at 50 MPH and some will still have a degree of stability.
Wind direction and speed have much to do with it too. If you are cruising at 50 MPH in a 20MPH headwind you got 70MPH wind into the bow of the boat. Theres a LOT of boats won't handle 70 MPH.
Also, water surface condition will have an input as well. If you are up on top in waves, the bow gets pushed up at every wave. the faster you run onto the waves the more the boat gets tossed upward.
When and where the boat is actually going to become airborne is anybodies guess. How fast over the water, how fast through the air, how much wave, what direction the wind is from, how much the boat weighs, what is the shape of the hull and probably a couple hundred other factors.
Knowing how a wing on an airplane works, I would think that a full deck boat would get airborne sooner than an open boat. I would think that a boat with a lengthwise crown or rounded bottom with turn chines will remain stable a little longer than a purely flat bottom. No matter it takes a low air pressure area over the boat and a high air pressure under the boat to get airborne.
I'm sure the air temperature will have a defined effect on when the hull heads skyward as well. Cold dense air produces more lift than hot humid air.
Just thinking out loud here. Probably most folks that have survived flying a hull have no clue about all the details that came together at that exact moment when it took to the air. If they do they are a genius at multitasking.
- SpencerMullins
Re: Flying airboats
- Attachments
- airboat jump.jpg (57.18 KiB) Viewed 5047 times
- Jumpin_Geehosephat.jpg (61.51 KiB) Viewed 5047 times
Camp Ramblin' Rose
Bob "Koon Dawg" McDonald Grandson
15' Rivermaster 350 2.12 gear box 79" Wisper tip
Re: Flying airboats
I ran with a guy that had one close to airborne. Buford ran Big Block Chevy gearbox and a 3 blade a few years ago on a cut down 11 foot Hamant hull. They had it at 90 something mph according to a handheld gps. They got scared but they did say it felt like it was fixing to take off.
Re: Flying airboats
The top pic looks like he trying to cross it up. lol
Holy crap that would be a ride.
- Whitebear
- Site Supporter - VIII
- Contact:
Re: Flying airboats
This is about not flying your boat not how to. Its not an un-safety thread.
Re: Flying airboats
I have went airborne a couple of times First time was with a quarter inch plywood boat With a flapper on the back when they come up its like the brakes. Come no it pushes you down in the deck because. It is slowing. Down. So quick and then the impact. Which I was always lucky The second time was in my tunnel. Hull. Yeah it was just like the unlimited Hydro's you see on TV was lucky again. I guess what I am trying to say A lot of going airborne is due to the terrain in which you are driving in open water is the most drag on the bottom whereas different types of vegetation or grass can make you lift sooner
