4.3 vs sbc
spooledup50
4.3 vs sbc
Postby spooledup50 » Mon Apr 30, 2007 8:52 pm
any one know the wieght difference between an iron headed sbc and a 4.3 want to try one on a 11 foot bout with a 2.38 box and prop combo
350ci wiskey drinking son of a b&$@ch.....E85!
mudkat
Postby mudkat » Mon Apr 30, 2007 9:49 pm
4.3 is 425 lbs
iron head sbc 575 lbs
Waterthunder
Postby Waterthunder » Mon Apr 30, 2007 9:59 pm
I weighed and posted all this info I will try and dig it up. To be honest the LS1,LS2,LS6 and LS7 are all lighter then the V6 and make ton's more torque! I was building alot of 4.3's up to the 400HP mark but I dropped that program when the LS1 came out! I would suggest a LS1 over both!
THE PROOF IS IN THE PROP!
http://waterthunder.com/
321-508-5316
Waterthunder
Postby Waterthunder » Mon Apr 30, 2007 10:18 pm
From an old post!
Posted: Thu Aug 17, 2006 10:49 pm Post subject: Engine block weights
I was weighing some parts out of curiosity because of some talk on the chat room Tuesday about V/6's. I have built a few 350HP and 400HP Vortec 4.3 V/6's and happen to be building one now. So here are some G.M. block and head weights. A stock .060 over 400 bare SBC block weighs 172.4lbs, a .030 over 4.3 Vortec V/6 block weighs 121.2 and a Truck LS1 block the heaviest of production aluminum LS blocks which is the block I prefer and use for all stroker LS1 motors weighs 114.6. I must admit I assumed the V/6 and LS1 blocks weighed the same but the LS1 block is a little lighter then a V/6 block. As for complete assemble heads a stock V/6 head weighed 34.8lbs and a LS1 head weighed 23.4 pounds. This also surprised me I weighed a bare O540 jug no valves, no springs, retainers or locks plus it was the light parallel valve O540 jug it weighed 17.2lbs. I bet an assembled O540 angle valve jug weighs close to 23 lbs and that’s what a complete LS1 head weighs and it’s for 4 cylinders.
321-508-5316
chuckitt@earthlink.net
Postby chuckitt@earthlink.net » Tue May 01, 2007 7:46 am
Hey Spool, I never considered the Wt. of the 4.3 compared to the LS engines. what
I considered was the cost. Some people can't afford an LS engine. I can sell the
4.3 complete ready to run for $2500.00 with a one year warranty. I can't do that
with any other engine. With a 2.37 gear and a 74 inch 2 blade Maximus Prop on
a 13 ft. Boat it makes a pretty nice ride. Thanks Chuck
