Prop bolts
PM
Prop bolts
Post by PM »
What size and length bolts go with a sensenich saber and a lycoming 160?
Thanks in advance!
15' Rivermaster (Hoffman)
ptr34
Re: Prop bolts
Post by ptr34 »
Same as what was in wood prop
PM wrote:What size and length bolts go with a sensenich saber and a lycoming 160?
Thanks in advance!
tons videos on YouTube ptr34
PM
Re: Prop bolts
Post by PM »
I didn't have a wood prop on it. It is a boat I am putting together.
ptr34
Re: Prop bolts
Post by ptr34 »
Should be 4 1/2 " long 3/8 bolt
Bruce
Re: Prop bolts
Post by Bruce »
ptr34 wrote:Should be 4 1/2 " long 3/8 bolt
160 is 7/16 bolts thatd be 5/8 head
12 foot Mamba "The Underdog"
ptr34
Re: Prop bolts
Post by ptr34 »
It can have either right?
PM
Re: Prop bolts
Post by PM »
I ran a 3/8" into the hub it felt a little sloppy, that is why I was wondering.
Bruce
Re: Prop bolts
Post by Bruce »
O290s are 3/8 i believe i know every 320 ive ever fooled with that hadnt got 360 flange welded on was 7/16
ptr34
Re: Prop bolts
Post by ptr34 »
If u have a hub for 1/2" bolts then it will feel like that.
Larry
Re: Prop bolts
Post by Larry »
I have seen most older 150's used 3/8" bolts and some newer 150's and all the 160's had 7/16" bolts, lug outer diameter 5/8" with both sizes.
DAGWOOD0520
Re: Prop bolts
Post by DAGWOOD0520 »
We make plates for just about every application, but for the most part unless it is specified differently, the standard plates are cut for 1/2" bolts with 3/4" drive bushings. Also we make sleeve type bushings for the mount bolt spacers for engines with 5/8" drive bushings.
