Carport/Garage
Duece
Carport/Garage
Post by Duece »
http://www.southeastportablebuildings.c ... rages.html
See these all the time in the magazines. Anyone ever get one of these setup for your airboat? What about permits, setup time, fees etc.? If you don't want to post on here about it, PM me. I'm very interested.
Duece
"Welcome to the Dark Side..."
Birddog247
Re: Carport/Garage
Post by Birddog247 »
Iam in the process of doing the same thing. From what I gather If your zoned agriculture you don't need a permit. Lots of diff companies advertising these which I believe come from one or two suppliers. Iam looking at installing a 12 x 40 x 10 and they are rangeing in price anywhere between 2500/3800 depending on how bad they need work I guess.
12ft Palm Beach
stock 350sbc
2.1 gear/80"NGR
"Save a tree; eat a beaver"!
farmboy
Re: Carport/Garage
Post by farmboy »
Duece, I bought a 20+31 for my boat with a 10+10 roll up door and a side door for $5000 installed. It took them about 5hours to put up. The permit wasn't any trouble to get. I have an extra $2000 in electricity.
KR23
Re: Carport/Garage
Post by KR23 »
I got one and it works great, mine i think is 30x30x16 but I wish I would of got bigger. I am adding another one behind it so I have 30x 60. Whatever you think you need get bigger they fill up quick. I did the concrete and they came and set up the building in a day. I love it, but like I said get bigger than you think you'll ever need
harley
Re: Carport/Garage
Post by harley »
Duece wrote:http://www.southeastportablebuildings.c ... rages.html
Duece
http://carolinacarportsinc.com/configurator/index
i bought one from SUPERIOR SHEDS , (321)636-7761 in cocoa , orderd a 16x20 by 9ft high side and the middle is 12ft high. the price was 2,100 that was with set up . it took like 2 weeks to get it and when they set it up 4 guys done the job in less than 3 hr.. you can build your own carport with the web site i sent you . mine was only 1,600 then i add the closed back and 2 side panels , that made it 2,100 . it is a perfect size for my 14x8 boat and other stuff. good luck bud .
14x8 Diamondback / SBC Power.
"ALL THROTTLE NO BOTTLE"
Duece
Re: Carport/Garage
Post by Duece »
If you're not going to do concrete is that an issue? I've already got a marl pad is why I'm asking. My issue is a bit strange, but my pad is long (maybe 20' x40') and I store my boat long ways, while I have a hunting truck I store short ways. Can you drive over those rails on the bottom, or can they be buried so you can drive over them? Guess that's a manufacturer's question. Thanks for the info.
Duece
atvracer16
Re: Carport/Garage
Post by atvracer16 »
I've been looking at many companies and can't decide which company to go with! I just bought a house and it came with a 24x40 slab! Let me know if you go through with them and how it is!
13' Aluminum w/ SBC 350 (440hp), 2.38 Stinger Soft Drive, & 2 Blade 76" R Series
chasinbytes
Re: Carport/Garage
Post by chasinbytes »
Hopefully you have better luck than I did if you permit it. Palm Beach County gave me a really hard time
harley
Re: Carport/Garage
Post by harley »
Duece wrote:If you're not going to do concrete is that an issue? I've already got a marl pad is why I'm asking. My issue is a bit strange, but my pad is long (maybe 20' x40') and I store my boat long ways, while I have a hunting truck I store short ways. Can you drive over those rails on the bottom, or can they be buried so you can drive over them? Guess that's a manufacturer's question. Thanks for the info.
Duece
mine is 2'' heavy duty square galv tube 5 ft apart if that helps.
Riverrunner32333
Re: Carport/Garage
Post by Riverrunner32333 »
I started out with a 32x36 from Panhandle salvage in Bonifay.
Saved up and and did the concrete.
Then started closing in the back 12x32
Decided I need more under roof
Found a guy over in Defuniak Springs that makes the trusses a good price http://jordantruss.com/ ALso found a good deal on CL for some 26' tin
Up they went
Mostly finished.....but still have room to do another lean too. :D
akblackdawg
Re: Carport/Garage
Post by akblackdawg »
Those metal buildings are a lot, lot cheaper down there then they are up here in Alaska. Sams club sells a metal single car carport for about $1000 here. Your buildings are also lower, but of course we have to have ours heavy insulated and we have to heat them in the winter, and they have to be stout enough to hold a 2-3 ft wet snowload all winter, plus the shipping by barge up from seattle area. mmmm, guess living is more expensive up here. Bud
Duece
Re: Carport/Garage
Post by Duece »
Duece
Yeah, I'd need them farther apart than that. Wide enough to drive a truck through.
Duece
harley
Re: Carport/Garage
Post by harley »
Duece wrote:
Duece
Duece
yea 10-4 , they can give you what you need , :thumbleft:
gso480jr
Re: Carport/Garage
Post by gso480jr »
$850 for 12x24 carport, $150 extra for side panels one side. delivered and set up.
gso480jr
Re: Carport/Garage
Post by gso480jr »
here is pic
gso480jr
Re: Carport/Garage
Post by gso480jr »
another look
heater17
Re: Carport/Garage
Post by heater17 »
gso480, what company did you use? Im down in homestead and looking to get one put up, thats a good price
gso480jr
Re: Carport/Garage
Post by gso480jr »
C&G enterprises in Hudson, Fl. 727 862-2430. He has local guys for set-up. Probably he would have shed drop shipped directly to you idk. Set up takes a couple hours.
Duece
Re: Carport/Garage
Post by Duece »
Duece
Harley,
How tall is your boat? Mine's pretty tall. That 9' is that what you put in the website when you're generating your building?
Duece
MJD291
Re: Carport/Garage
Post by MJD291 »
I did a 20X40 from Carolina carports with 2 each 10x10 doors on each end. I open both doors in the summer and it is really nice. I spent $8200 for the building. I had it spray foamed also.
I LOVE THE SMELL OF AV GAS IN THE MORNING. IT SMELLS LIKE..... VICTORY
MJD291
Re: Carport/Garage
Post by MJD291 »
Here is the front.
0470dog
Re: Carport/Garage
Post by 0470dog »
Never can build to big my pole.barn 40+50 full
