0540 prop Q/A
Airboat propeller discussion.
mrbill
0540 prop Q/A
Post by mrbill » Wed Jul 30, 2014 7:37 am
I have a 2006 13' diamondback with a 0540 about 280+ hp running a 3 blade sec h 72" prop. Was thinking of a whisper tip 2 blade 74" been told this is a awesome prop for my boat but for I start messing with it.I thought id get some in put from others !!! What other props are as smooth with good push and nice cruise but still have some speed to hang with my friends that run big v8 motors !!!lol !!
mojoe
Re: 0540 prop Q/A
Post by mojoe » Wed Jul 30, 2014 1:04 pm
Buy one of each, try them all, and give me your 3blade to use as a spare!! :cheers: Thanks Bill!!
Mark 7:9
Re: 0540 prop Q/A
Post by kwanjangnihm » Wed Jul 30, 2014 4:31 pm
fl cracker
Re: 0540 prop Q/A
Post by fl cracker » Wed Jul 30, 2014 8:23 pm
A 3 blade H is one of the faster props out there. Going to a 74" whisper tip is only going to help on your low end grunt. Along with the Q it has nothing to offer on the top end. I'd try a 3 blade NGH, the blades are 1 1/2" wider than the H. You already have the 3 blade hub so it could be a inexpensive swap.
" I have two guns...
One for each of you "
2017 Hamant / SV540
mrbill
Re: 0540 prop Q/A
Post by mrbill » Wed Jul 30, 2014 10:08 pm
thanks for the info keep it coming please
ptr34
Re: 0540 prop Q/A
Post by ptr34 » Sun Aug 03, 2014 4:50 pm
2 blade 74" NGQ
tons videos on YouTube ptr34
Orion
Re: 0540 prop Q/A
Post by Orion » Sun Aug 03, 2014 5:39 pm
I have the same boat/engine as you. It came with a 74" Q series 2-blade prop. that made a lot of high end noise and was only fair I would say. I just upgraded to a 74" NGQ 2-blade prop. and the performance is much better; gets up on a plane faster, with faster cruise. Fuel economy about the same. The engine is pushing a little harder; seems to run a few degrees warmer, but only up to about 145 degrees with ambient temp 90 degrees, cruising. Hope that helps some.
Spent most of my money on women and rum; the rest I just wasted.
Diamondback 13'6"
Lycoming 0-540
mrbill
Re: 0540 prop Q/A
Post by mrbill » Sun Aug 03, 2014 9:43 pm
great info now thanks ///thoughts are running around in my head good now :bounce:
ptr34
Re: 0540 prop Q/A
Post by ptr34 » Sun Aug 03, 2014 9:46 pm
I have a ngq u can test also
mrbill
Re: 0540 prop Q/A
Post by mrbill » Tue Aug 05, 2014 7:03 am
yea i guess im asking for to much try to keep a three blade set up and get ----more low end ,a little snap and to keep some top end !!!!!!
ptr34
Re: 0540 prop Q/A
Post by ptr34 » Tue Aug 05, 2014 9:52 am
U can do a 3 blade" ngh
aherr520
Re: 0540 prop Q/A
Post by aherr520 » Tue Aug 05, 2014 6:11 pm
ptr34 wrote:U can do a 3 blade" ngh
I lost some top end speed when I went from a 72'' 3 blade H to a 72'' ngh, now I have a 74'' 2 blade Q and has great low end but no snap or top end so it's for sale and I will find something else
aaof member
ptr34
Re: 0540 prop Q/A
Post by ptr34 » Tue Aug 05, 2014 6:24 pm
Ngh is wider prop so topend may drop from h blade
aherr520
Re: 0540 prop Q/A
Post by aherr520 » Tue Aug 05, 2014 6:29 pm
ptr34 wrote:Ngh is wider prop so topend may drop from h blade
so what difference would a ngq be over a 74'' Q?
aaof member
fl cracker
Re: 0540 prop Q/A
Post by fl cracker » Tue Aug 05, 2014 7:52 pm
The NGQ is an 1 1/2" wider than the Q. Better lowend and better cruise! I had my wife, both kids and myself which is 685LB plus full take cruising deep at 1,650 rpm. That's impressive!
2017 Hamant / SV540
aherr520
Re: 0540 prop Q/A
Post by aherr520 » Tue Aug 05, 2014 7:58 pm
fl cracker wrote:The NGQ is an 1 1/2" wider than the Q. Better lowend and better cruise! I had my wife, both kids and myself which is 685LB plus full take cruising deep at 1,650 rpm. That's impressive!
how is top end?
aaof member
Tony480
Re: 0540 prop Q/A
Post by Tony480 » Tue Aug 05, 2014 8:00 pm
Your not going to go fast anyways Adam. LoL...speed will lie in the setup.
aherr520
Re: 0540 prop Q/A
Post by aherr520 » Tue Aug 05, 2014 8:32 pm
I'm looking for more snap to break loose on that green grass LOL
aaof member
Tony480
Re: 0540 prop Q/A
Post by Tony480 » Tue Aug 05, 2014 8:34 pm
You need jacks in your hull
mrbill
Re: 0540 prop Q/A
Post by mrbill » Tue Aug 05, 2014 9:01 pm
i have all that on my boat just dont want to lose to much speed but want to run green stuff and any where i want with the wife and kid on broad also i hang with some guys that have v8 boats and hate when they lose me lol lol
aherr520
Re: 0540 prop Q/A
Post by aherr520 » Tue Aug 05, 2014 9:16 pm
I'll get with a dealer when I go down south and figure it out
aaof member
aherr520
Re: 0540 prop Q/A
Post by aherr520 » Tue Aug 05, 2014 9:22 pm
mrbill wrote:i have all that on my boat just dont want to lose to much speed but want to run green stuff and any where i want with the wife and kid on broad also i hang with some guys that have v8 boats and hate when they lose me lol lol
you should try the ngq and let me know who it compares to your prop, I have 2 jacks and lost over 10 mph top speed when I bolted on the Q
aaof member
mrbill
Re: 0540 prop Q/A
Post by mrbill » Fri Aug 08, 2014 9:39 pm
does anyone have a 3 blade ngh i can try out ?
mrbill
Re: 0540 prop Q/A
Post by mrbill » Wed Aug 13, 2014 7:51 am
no one in the central fl area have one i can try out ?
mrbill
Re: 0540 prop Q/A
Post by mrbill » Fri Aug 29, 2014 6:45 am
still looking to try a prop out ?
Return to “Prop Talk”
