Buzzkill getting over hauled
JPerkins323
Postby JPerkins323 » Sat Aug 08, 2015 4:04 pm
Every one seems to enjoy a thread like this so figured I'd share with every one. The cage on buzzkill started rusting out so I decided to redo the cage. Didn't really want to but it never happens when your ready so I'm rolling with it. Here's what I've done so far. Doing more fabrication then I'm used to but I'm getting the hang of it. Wish I could take credit for the cage it's self but I had a friend do it. I'll be going with a totally new paint scheme too. I'll be updating pictures as I go. ImageImageImage
"BUZZ KILL"
12x6.8 .090 thousands 1/2 deck hunt boat with .125 backup plates and a lil' sheet of stainless. 0540 s/v spinning 5 blade sabers.....Ready to party.
Built by D&E Metal works in Homestead, FL: (786) 412-9018
JPerkins323
Re: Buzzkill getting over hauled
Postby JPerkins323 » Sat Aug 08, 2015 4:05 pm
Here's what it looked like before for those who don't remember
"BUZZ KILL"
Seven3
Postby Seven3 » Sat Aug 08, 2015 4:28 pm
With the new rigging drill a small hole at the base of the vertical legs on the stern side so the moisture has a place to escape. After every ride/wash stick the WD-40 straw inside the hole and shoot some WD up there. The new rigging shouldn't rust if you do that.
digginfool
Postby digginfool » Sat Aug 08, 2015 11:18 pm
Even better us BoeShield, if you can find it.
Gary S
Postby Gary S » Sun Aug 09, 2015 7:34 am
From the pictures I would say Wayne is his friend. The welds will be 100 percent and no moisture can enter. Nice boat.
Birddog247
Postby Birddog247 » Sun Aug 09, 2015 7:38 am
Is it brazed or miged
12ft Palm Beach
stock 350sbc
2.1 gear/80"NGR
"Save a tree; eat a beaver"!
PAINKILLER
Postby PAINKILLER » Sun Aug 09, 2015 7:38 am
:thumbleft: done a great on her looking good
Psalms 101:7 No one who practices deceit shall dwell in my house; no one who utters lies shall continue before my eyes.
JPerkins323
Postby JPerkins323 » Sun Aug 09, 2015 2:44 pm
Thanks guys... It's braised.
"BUZZ KILL"
mercracing
Postby mercracing » Mon Aug 10, 2015 11:33 am
Looking good Jake get it done water is coming up.
"TOTAL LOSS"
13' Al David (performance airboats) family boat with a old worn out junkyard LS and 6 blade prop
JPerkins323
Postby JPerkins323 » Tue Aug 11, 2015 1:44 am
Thanks merc racing we'll be partying at the camp in no time!
"BUZZ KILL"
JPerkins323
Postby JPerkins323 » Sun Aug 23, 2015 9:51 pm
Well almost ready to put the wire on the cage. Mounted the seats yesterday and finished up all the brackets for the nav lights. Drilled out some washers and braised them to the cage and mounted marine live well lights for the nav lights. There a little by of a learning curve for me but it's going good just taking it slow. Now I need to make a battery box. Trying to decide how to mount it. Any body have some pictures of there battery boxes?
"BUZZ KILL"
JPerkins323
Postby JPerkins323 » Sun Nov 01, 2015 8:15 pm
Finally off to powder coating!
"BUZZ KILL"
stroked470
Postby stroked470 » Sun Nov 01, 2015 8:51 pm
Looks real good
JPerkins323
Postby JPerkins323 » Wed Nov 11, 2015 8:08 am
Waiting for metal to come in for my hull, and the cage is still at powder coating so I'm at a stop for now. I've had this idea in my mind for a while so I decided to order some cork handles that were ment for fishing rode builders, and got some Paracord. It's my second wrap. First one was horrendous. Lol. But it keeps me entertained until all my stuff comes in.
"BUZZ KILL"
Full Rut
Postby Full Rut » Wed Nov 11, 2015 8:13 am
Like the handle BAD ASS
14ft DB 2ft Rake 3/4 Deck Alum. Riggn 502BB 2.37Rota Sens. Fat Daddy
JPerkins323
Postby JPerkins323 » Thu Nov 12, 2015 7:14 am
Back from powder coating
"BUZZ KILL"
JPerkins323
Postby JPerkins323 » Thu Dec 17, 2015 8:54 am
Exhaust back from Hot Shots ceramic coatings.... Turned out good. As always I can't help but go a little overboard on this rebuild. Now if I can just get my hull painted I can finally start putting everything back together.
"BUZZ KILL"
JohnnyBravo
Postby JohnnyBravo » Sat Dec 19, 2015 9:09 am
Looking good!
FlaGatorSlayer
Postby FlaGatorSlayer » Sun Dec 20, 2015 7:52 pm
Very nice work. I like that cork handle idea. I was thinking about cutting up some alum. on the lathe with the radius cutter.
:old_glory: :florida: :rebel:
JPerkins323
Postby JPerkins323 » Mon Feb 01, 2016 9:34 am
Nothing like fresh steel flex. Inside is all ready painted and one I finish bucking a few rivets, hopefully I'll get it out for outside paint this week. After that it's just assembly.
"BUZZ KILL"
JPerkins323
Postby JPerkins323 » Mon Feb 01, 2016 9:35 am
"BUZZ KILL"
Arcticshooter
Postby Arcticshooter » Mon Feb 01, 2016 2:54 pm
digginfool wrote:Even better us BoeShield, if you can find it.
X2 for BoeShield. Corrosion X is also an excellent choice.
It has always amazed me that WD-40 is still so widely recognized as the "good stuff"
Fact is...It is not a lubricant it is a solvent. Tested a bunch of stuff on a lubricity tester several years ago in aviation school.
Basically it is an electric motor with a hardened wheel and a hardened wear plate on a torque wrench lever arm.
Turn it on, note the load, and measure the amp draw to keep the motor turning, and the squeal that a poor lube would make was deafening.
So we would squirt the bearing area, lean on the wrench, read the amp load, listen to the squeal or lack of, to determine the quality of the lube.
We ran that thing with a 20-30lb load and shot it with a CONSTANT stream of WD-40 right at the friction point and all it did was Smoke, SCREAM and bring the motor to a final friction induced halt!!!
One tiny squirt of LPS 2 and the thing started moving, went silent, and after hanging my 160lbs on the wrench still couldn't slow it down or get more than a minimal amp load.
Only reason for this long explanation was to explain myself better than to simply say..."WD-40 Sucks!"
Arcticshooter
Postby Arcticshooter » Mon Feb 01, 2016 3:00 pm
Rebuild is coming together nicely!!
JPerkins323
Postby JPerkins323 » Mon Feb 01, 2016 9:58 pm
Lol Thanks arcticshooter I didn't know that. I do love boeshield. I cover my 0540 in it and I cover my outboard on my hewes with it as well. Best stuff in the world.
"BUZZ KILL"
JPerkins323
Postby JPerkins323 » Mon Feb 22, 2016 10:33 pm
Paint is finally done!
"BUZZ KILL"
Users browsing this forum: No registered users and 13 guests
