power issues on 400 smb direct drive
papasmurf
Postby papasmurf » Mon Sep 21, 2015 8:51 pm
I have a 400 smb direct drive with a 600 Edelbrock carb with rv cam and a new 6 blad warp prop. I am only pushing about 2000 rpms. Just wanting to know if i need to change my carb or what else i could do to get 3000 rpms.
keebo
Re: power issues on 400 smb direct drive
Postby keebo » Mon Sep 21, 2015 9:12 pm
What's the length of prop, smart sense would say adjust the prop to where you can turn the 3 k. Sounds like just to much prop to me.
:old_glory: :florida: :GA:
Olf Art
Postby Olf Art » Tue Sep 22, 2015 1:55 pm
keebo wrote:What's the length of prop, smart sense would say adjust the prop to where you can turn the 3 k. Sounds like just to much prop to me.
Yup. Use the prop as your rev-limiter. Six blades may be too much prop for a DD.
papasmurf
Postby papasmurf » Tue Sep 22, 2015 2:00 pm
It's a 77in from tip to tip. Ok thanks guys.Do I need to take two blade off yall think and just make it 4 blad?? Or just play with the pitch
SthrnStyle3
Postby SthrnStyle3 » Tue Sep 22, 2015 2:20 pm
I'd say both.. Try it as a 4 blade and set the pitch to your desired rpm's. A 77in 6 blade is way too much prop IMO..
scottyroll
Postby scottyroll » Tue Sep 22, 2015 2:56 pm
Six blades at that length is too much.
Also, I've heard that a 4 blade could cause harmonic problems for the crank if not set up in a bow-tie pattern but that was in regards to aircraft.
Not quite sure if there would be a difference but wanted to share.
Try and get at least 6degrees of pitch in each blade or else it won't perform efficiently.
:Scotty-Roll:
FLAwless
papasmurf
Postby papasmurf » Tue Sep 22, 2015 8:45 pm
Ok do they make a tool to check ur pitch with. If so where can I order from??
glades cat
Postby glades cat » Tue Sep 22, 2015 9:26 pm
Postby Deano » Tue Sep 22, 2015 9:36 pm
This is the one I have, and use that little guy all over the place.
http://www.ebay.com/itm/iGAGING-DIGITAL-ANGLE-CUBE-ELECTRONIC-LEVEL-SENSOR-BEVEL-GAUGE-TRIPLE-MAGNETIC-/281221180493?hash=item417a16ac4d
Warp dive makes a protractor for that purpose, but I can't imagine it being as versatile.
There are many that will work, but something at least similar is what I would get.
Postby Deano » Tue Sep 22, 2015 9:38 pm
And there's more confirmation I need to learn to search and type faster. :lol: :lol:
papasmurf
Postby papasmurf » Tue Sep 22, 2015 10:08 pm
Ok thanks guy
papasmurf
Postby papasmurf » Thu Sep 24, 2015 6:56 pm
Do you guys thing i need to cut my prop done to 73" or 72" to make the motor push the boat good?????
Olf Art
Postby Olf Art » Fri Sep 25, 2015 12:44 am
Don't go cuttin on the prop ..... take two blades off of it and try it as a 'bow tie' arrangement first.
Cutting on props can raise a whole new set of problems.
Stay in touch ..... we'll get you there.
ALLRED520
Postby ALLRED520 » Fri Sep 25, 2015 9:07 am
A buddy of mine a 72in 5 blade and spins it 3k all day same power plant you have i would agree with the other guys to much prop i think my buddy is run 7-9 degrees on his warp
ALLRED520
Postby ALLRED520 » Fri Sep 25, 2015 9:32 am
Sorry for the grammar i hate these new phones
papasmurf
Postby papasmurf » Wed Sep 30, 2015 4:34 pm
ok guys took two blades off and changed the pitch some. Boat run alot better but only got 2400rpm. Im going to try and run the boat some this weekend and change the pitch some more. Or do i need to leave it alone and stay where im at. the prop has a lot adjustment where the props can move in to a 72'' i think i have not tired it yet.
papasmurf
Postby papasmurf » Wed Sep 30, 2015 4:37 pm
And Where do i need to place the pitch gauge at on the props????
Gangreen
Postby Gangreen » Wed Sep 30, 2015 6:14 pm
6 blades is not too much. It is alot but can be adjusted and ran. Try 7 degrees it should get you 2800 ish. If not you engine could looking at. My brother is spinning a 6 blade 72 inch at 2800 at a tight 7 degrees on a 383.
Olf Art
Postby Olf Art » Wed Sep 30, 2015 6:20 pm
Gangreen wrote:6 blades is not too much. It is alot but can be adjusted and ran. Try 7 degrees it should get you 2800 ish. If not you engine could looking at. My brother is spinning a 6 blade 72 inch at 2800 at a tight 7 degrees on a 383.
Yessir, but this man is trying to spin a fan that's 77 inches in dia. HUGE difference!
Gangreen
Postby Gangreen » Thu Oct 01, 2015 8:34 pm
2.5 inches is not that big of a difference since my brother is running a 383 to a 400. I have ran alot of direct drives with warps. He should be able to bring the pitch down to 6 and run fine. If not the engine has problems or short of horsepower.
Olf Art
Postby Olf Art » Thu Oct 01, 2015 9:49 pm
Gangreen wrote: I have ran alot of direct drives with warps. He should be able to bring the pitch down to 6 and run fine. If not the engine has problems or short of horsepower.
Gangreen, I'm beginning to think it might be a tuning problem also.
Papasmurf, are you running a vacuum line on your distributor? How much timing advance are you seeing at 2,400 rpm?
papasmurf
Postby papasmurf » Fri Oct 02, 2015 7:08 am
Yes I have vacuum line hooked up. And on timing is advanced 10 degrees. The 400 is bone stock rv cam, 600 carb, and aftermarket stock distributor.
papasmurf
Postby papasmurf » Fri Oct 02, 2015 7:18 am
Do put the pitch gauge on the tip of the blads or in middle of the blads.??????
Davie GSO480
Postby Davie GSO480 » Fri Oct 02, 2015 1:55 pm
First get the engine level...VERY important ...........use the prop plate. as reference...
Then measure in like 1 inch, put blue tape at the 1 inch mark,,,,,,measure each blade the same, 1 inch in from end.
Take a pitch reading........so you know where you are at now.
each degree will make about 200 rpm's or so diff......
so if your at say 11 deg take 2 deg out,,,less pitch=turn 400 more....thats + or -......you will have to see for your application.
Proud member of the Airboat Association of Florida.
A Miami Landmark sense 1951
http://www.aaof.com
Olf Art
Postby Olf Art » Fri Oct 02, 2015 2:00 pm
papasmurf wrote:Yes I have vacuum line hooked up. And on timing is advanced 10 degrees. The 400 is bone stock rv cam, 600 carb, and aftermarket stock distributor.
OK, we might have hit on something important here. Remove the vacuum line to the distributor and plug both ends where it connects. Now, with the engine running, advance the distributor to 25-28 degrees and see what your rpm increases to. If it does, then this may be a timing issue that's easily fixed. Just a thought .... try it before you re-pitch anything, and if it does increase, don't rev it past 3,000 rpm for now.
