Looking to get some more power. Any suggestions?
Bloodybayou
Post by Bloodybayou » Tue Sep 29, 2015 2:02 pm
Hey fellas, I'm very new to airboats. I bought my 17' alumatech about a month ago. It's got a 350 small block in it. My boat is rigged up for Bowfishing so I can run some charters on the side. I'm noticing that with 5+ people she's having a tough time getting on plane. Peddle to the floor she's only running 5400 RPMs. Any suggestions or advice would be helpful thanks!
mojoe
Re: Looking to get some more power. Any suggestions?
Post by mojoe » Tue Sep 29, 2015 6:46 pm
A 17' boat with 5 guys loaded for bowfishing is a lot to ask of a small block.
Easiest way to make it perform better would be to leave the 2 biggest guys home :slap:
Mark 7:9
skinny99
Post by skinny99 » Tue Sep 29, 2015 8:01 pm
There is no replacement for displacement! Need some bore and stroke in that girl.
dodobird
Post by dodobird » Tue Sep 29, 2015 8:03 pm
17' boat 5 ppl a small block and all the bowfishing crap on it id say shes doin great ......... :thumbleft: :florida:
13' laser 360sbc oxdrive 2.68 .... 80" 3 blade whispertip ex :florida:
SteveReid
Site Supporter - VII
Post by SteveReid » Tue Sep 29, 2015 8:12 pm
dodobird wrote:17' boat 5 ppl a small block and all the bowfishing crap on it id say shes doin great ......... :thumbleft: :florida:
Agree!!
jeepinocala1111
Post by jeepinocala1111 » Tue Sep 29, 2015 8:20 pm
Give more specs do you have a reduction drive what's the motor stock? Prop?
Post by SWAMPHUNTER45 » Tue Sep 29, 2015 8:36 pm
That is a chore for a big inch engine.
Bloodybayou
Post by Bloodybayou » Tue Sep 29, 2015 9:57 pm
Do yall think adding any performance parts would help? Like maybe a super charger or something. I don't know what the gears are but it's a 3 blande carbon fiber prop
Bloodybayou
Post by Bloodybayou » Tue Sep 29, 2015 9:58 pm
1
Chaseh
Post by Chaseh » Tue Sep 29, 2015 10:08 pm
I run an 18x8 with a mild BBC, 1/2" poly and 3 row seating. I have run 9 people regularly, a 100 lb dog, 2 loaded coolers, and 40 gals and maxed out about 45mph. Dry she is very temperamental though. Cruises around 4-4200rpms at 26mph or so
dodobird
Post by dodobird » Tue Sep 29, 2015 11:04 pm
look on the beltbox on the right side lower bottom should be few numbers............might go with wider blades find out what the numbers are and post them that's a lot of boat u have there might beable to go with the R blades using ur hub might help some MAYBE..... :florida:
Post by SWAMPHUNTER45 » Wed Sep 30, 2015 7:17 am
I dont see a cheap upgrade.
A Paxton / Vortec style supercharger would be the path I would explore if everything else can support it. They are the compact units that are a blow thru design you see in Summit and Jegs.
Ronaldregan
Post by Ronaldregan » Wed Sep 30, 2015 8:57 am
That it will even move with 5 men and all that weight on front is a wonder,.Weight on front is a killer, had a 454 bb on 15/8 with simlar bow fishing rig,got stuck often, tool the rig off the front and it was a whole lot better.
14/8 alumitech wt 418 ,2.67/1 4blade 83in. R's
