Replacing poly on an aluminum hull.
SthrnStyle3
Postby SthrnStyle3 » Thu Oct 01, 2015 3:10 pm
Just wondering what y'all's opinions are on whether I should weld up the old holes and re-drill new ones or re-use the old holes and nut and bolt it..? If I get the holes welded up (depends on if a buddy will do it or not), I can thread the bolts into the hull and won't require any nuts. It'll also make it a one person job. If I re-use the old holes, it'll then be a two person job and I'll have to buy nuts. What's y'all's opinion??
barhopper
Re: Replacing poly on an aluminum hull.
Postby barhopper » Thu Oct 01, 2015 6:09 pm
I just got done putting poly on two weekends ago. I used the old holes with nuts and washers. That was the fourth time I've done it on two different boats. When I got the hull I have now it was screwed on. I continually was jerking them out. I run rough rocks and oysters. I don't have near the problem with jerking them out I did with the screwed in ones. If you do weld the holes up make sure you chase the hole a little bigger and grind around it. I know someone who's boat leaks bad through welded up holes. The stainless and aluminum cause a corrosion in the hole. I'm trying brass nylocks this time. I didn't have one that galled while installing.
swampsquatch09
Postby swampsquatch09 » Fri Oct 02, 2015 3:20 pm
It might sound time consuming but after threading the bolt through the hole with a 7/32 drill bit dab neversieze on each bolt, I was gaulding about 1 one 5 when I started tighting but after the neversieze I ran everyone one of them up with a drill then tighten without a problem.
:texas:
GladesAirboat
Postby GladesAirboat » Sat Oct 03, 2015 7:03 pm
When using the stainless bolts and nylock nuts if you use a impact it will gauld, try a battery drill instead. The impact action will gauld the threads, the smooth tightening of the drill works better.
14'6" X 7'6" Diamond Back, ZZ502,
2-1 Century Drive 3 Blade 80" Power Shift
12 Hamant 0360 68" Sensinich
Glades Airboat & Buggy Association
Home of the Muck Boyz
pontoon outlaw
Postby pontoon outlaw » Sat Oct 03, 2015 9:42 pm
:scratch: I just used the same holes, they are already threaded :violent1: drill a smaller hole in the Poly then put the screw in and it threads the poly, no leaks and just nut and washer the slim few that didn't tighten :cheers: I've done mine twice the same way :usa:
Users browsing this forum: No registered users and 18 guests
