BBC to SBC swap
pkooken
BBC to SBC swap
Post by pkooken »
I recently locked my 454 up on my boat and I'm thinking of swapping to a SBC. My question is; if I have a 95 4 bolt main that's been bored .40 over and I want to put Vortec heads and a VooDoo cam with Duration 256/262, Lift .454/.468, Dual plane intake, and a Holley 750 on top, what kind of power should I expect?
speedymoe128
Re: BBC to SBC swap
Post by speedymoe128 »
there is no replacement for displacement is the way I always look at it
scottyroll
Re: BBC to SBC swap
Post by scottyroll »
I think you'd be close to about 400 HP.
750 carb may be too much.
:Scotty-Roll:
FLAwless
odcjohn
Re: BBC to SBC swap
Post by odcjohn »
wont have even close to torque the bbc had unless you build a 383
RJC5778
Re: BBC to SBC swap
Post by RJC5778 »
whats the severity of the "lock up"?
scottyroll
Re: BBC to SBC swap
Lots of factors missing from your overall setup but the 454 is heavy piece.
If you don't have a bunch of blades and it's not necessary to have big HP then the small block should suit you just fine.
:Scotty-Roll:
FLAwless
Rich Andrews
Re: BBC to SBC swap
Post by Rich Andrews »
310.5 HP if U go to a double pumper.. I think :wink:
Re: BBC to SBC swap
Post by Deano »
Curious, no one asked about the other unknown parameters. :scratch:
Not sure how to guesstimate HP without knowing engine size and expected RPM ?
For all we know, it could be a DD; there is nothing mentioned otherwise. If not, what ratio ?
Seems like having only partial cam specs, leaves the bigger, more relevant variables unknown.
crowhater
Re: BBC to SBC swap
Post by crowhater »
All the go fast parts in the world will not substitute for CI, torque is what you want. There is nothing wrong with a small block, I personally love SBC. I would strongly recommend if you are going to use a SBC that you spend money on whats really important and purchase a stroker kit. You can get a low budget 383 stroker kit off ebay for $700. That's a new crank rods pistons, rings, etc, etc.
http://www.ebay.com/itm/SBC-383-Stroker ... Ug&vxp=mtr
check out Jegs or Summit also
http://www.jegs.com/p/Eagle/Eagle-Chevy ... 3/10002/-1
speedymoe128
Re: BBC to SBC swap
if I was gonna build a stoker I would stroke a 400 more ci if you are set on running a sbc
