GO480 SIRIUS BLADES??
Airboat propeller discussion.
getpickeled
Post by getpickeled »
Just finished my GO480 295hp. I bought a 2 blade power plus during the build and come to find out the blades were shortened. I was under the impression the prop was going to be an over all 78" but since the blades are cut down its on 74" and now motor is WAY under propped! So my question is.... I found a 80" 3 blade sirius, sould i attempt to run it as a 3 blade? Or should i look for a short 2 blade hub and run it as a 78" 2 blade?????
ptr34
Re: GO480 SIRIUS BLADES??
Post by ptr34 »
Three-blade 80 inch drop is perfect for that boat
tons videos on YouTube ptr34
Post by Deano »
ptr34 wrote:Three-blade 80 inch drop is perfect for that boat
x 2 Image
nebraskaairboater
Post by nebraskaairboater »
Isn't the Sirius a super wide blade? That GO480 must have monster torque. My Caddy with 2 to 1 only turns the 2 blade S prop set at #2 to 4200 rpm WOT.
Dan Porter, Jr.
Fremont, NE
ptr34
Post by ptr34 »
Yeah suirs or sw is to much. R style blade be better
farmboy
Post by farmboy »
My opinion a 3-blade Sirius is to much for a GO... A 2 blade 78" would probably work good.
SQD
Post by SQD »
From the thrust testing we have done, that engine should perform best with a Whirlwind three blade 78" stump puller or whisper tip 2.0 or the same blade configuration in other brand props you may chose to purchase. For more info. you can call Simpson Quality Designs at 772-563-0435 & ask for Dave.
Post by Deano »
My bad . . . somehow I read that and saw GSO rather than GO. :oops:
Didn't even realize that until I started to point out that even a
healthy Caddy ain't gonna out torque a supercharged AC motor.
Two blade would likely be the better option.
Post by Deano »
ptr34
Post by ptr34 »
2 blade will work . But i have tested all the props and a r sytle blade is the best. 2 blade will give u alot of torque roll
bbstimey
Post by bbstimey »
3 R blades 80" pushes like a beast
14'x8' JB hull w/Stingered GO-480 w/ electronic ignition and 3 blade 80" R
getpickeled
thanks for all the replies gents. So I did buy the Sirius because I feel I got a good deal, installed it yesterday and took it out for a few hours in the cold last night. My motor does turn the prop 340 at about the 1 mark setting but it has so much torque roll that if I keep my foot in it it would definitely sink the boat. Not sure where to go from here. might look for a sort hub and try to run it as a 2 blade 78. anyone interested in a 3 blade hub?? haha
Post by kwanjangnihm »
get with Andrew at WW - you can trade for some falcons and try them
bbstimey you wouldn't need all that power if ya stayed outta that thick sh*t! :toothy7:
Andrew McD
Post by Andrew McD »
What did you do with the hub from the 2 blade power plus? Might try just sticking 2 in their and see how she does. We may be able to get rid of some of the torque roll with falcons but hull style/shape may have something to do with. What kind of boat are you running?
Water Walker Props, Inc.
(863) 676-PROP
getpickeled
I still have the hub from the power plus. it's a med. I plan on trying that set up next and if that still isn't rightI plan o looking for a short hub to try it as a 78" I'm running my go480 on a 2005 12x7 Hamant
BUSHHOG85
Post by BUSHHOG85 »
That hull was a hand full with the 520 on it! shorter prop may help but imo you need more boat..I bet that bitch will scream on the hill though :shock:
SC 480 13x7'6 HAMANT
520 13' RICOCHET
Return to “Prop Talk”
