Over 350 HP ??
Over 350 HP ??
Postby kwanjangnihm » Fri May 20, 2016 3:38 pm
saw this while checking parts on ebay :scratch:
Brand new rebuilt Lycoming 0540. With high compression positions and cam from Schmidt. Only 3 hrs on motor. Motor is wrapped in 3M carbon Very strong motor!!!
Specs: Lycoming 0540
Compres: 13:11:1
Cam:from Schmidt ava.
Magnetos: Bendix mags x2
Carb is still yellow tagged!!
Well over stock 350hp!!!!'
http://www.ebay.com/itm/Lycoming-0540-m ... Jr&vxp=mtr
keebo
Re: Over 350 HP ??
Postby keebo » Fri May 20, 2016 6:43 pm
With a 150 shot maybe...
:old_glory: :florida: :GA:
krazymatt
Re: Over 350 HP ??
Postby krazymatt » Mon Jun 06, 2016 1:08 pm
I saw this also. It is a good looking motor. Where he get the 13:1 Pistons? Use the 11 or 12:1 from angle valve cylinder in the str8 valve?
jeepinocala1111
Re: Over 350 HP ??
Postby jeepinocala1111 » Mon Jun 06, 2016 2:02 pm
Yeah nice rebuild look at the corrosion around the neck of the airfilter.
Re: Over 350 HP ??
Postby kwanjangnihm » Mon Jun 06, 2016 2:10 pm
was hoping one of the engine builders would have some input on this build...... :scratch:
glades cat
Re: Over 350 HP ??
Postby glades cat » Mon Jun 06, 2016 3:13 pm
Wow. 13:1 is approaching diesel compression. :shock: That is a lot of squeeze.
mwood7800
Re: Over 350 HP ??
Postby mwood7800 » Mon Jun 06, 2016 4:23 pm
Didn't sell so Now relisted for 13k
I sent him an email, he said the motor was built by Gray Armstrong. Pistons came from schmidt avaition and the cam from up north.
jeepinocala1111
Re: Over 350 HP ??
Postby jeepinocala1111 » Mon Jun 06, 2016 7:55 pm
glades cat wrote:Wow. 13:1 is approaching diesel compression. :shock: That is a lot of squeeze.
I bet that's why it is for sale. Unless racing why the heck would you try and run that compression in the everyday running?
terrible ted
Re: Over 350 HP ??
Postby terrible ted » Mon Jun 06, 2016 8:35 pm
So at what rpm is 350 hp.
My motor was rated at 315 at 3200. It has also been uped to 10:1 now and that's high enough
mwood7800
Re: Over 350 HP ??
Postby mwood7800 » Mon Jun 06, 2016 9:15 pm
So who is gary. Armstrong?
B-White
Re: Over 350 HP ??
Postby B-White » Tue Jun 07, 2016 5:01 am
mwood7800 wrote:So who is gary. Armstrong?
GKA540 on here.....one of the best at building AC engines.
Devil in the Bottle 83 ProMod
Marsh Master Step
Carbon Fiber Rudders by:HAMMERHEAD AVIATION.com
Prop is NOTHING BUT A WHIRLWIND!!!
RAZORX
trailerdon
Re: Over 350 HP ??
Postby trailerdon » Tue Jun 07, 2016 6:54 am
Pm Gary Armstrong and ask him directly. If that is his build I would think he could give you the actual details.
JT540
Re: Over 350 HP ??
Postby JT540 » Tue Jun 07, 2016 7:20 am
lol. well I was gonna stay out of this one but I built that motor. it is nothing of what he says. the motor is a small main wide deck straight valve that I rebuilt with a phase 3 cam and 9 to 1 pistons. the guy bought it from me I delivered it to Okeechobee and the guy was supposed to bring it back for me to do the startup once mounted never did. he took it to gary for a carb issue and gary put a nos carb that he had on it and last I heard it had been sunk twice. they may have done something to it since then cause the pushrod tubes were black but I don't think gary has done it or he would have called me to let me know. I think the guy is full of shit all the way around.
JCGator
Re: Over 350 HP ??
Postby JCGator » Tue Jun 07, 2016 10:14 am
Gotta love Southern Airboat to bring out the truth! New airboaters looking for a boat/engine should take note of this... this i pretty common that the HP, builder, specs, etc in the description are all BS! :violent1:
10'6" Taylor Hull. Lycoming 170 hp - O-320 w/ 480 AV jugs
Re: Over 350 HP ??
Postby Deano » Tue Jun 07, 2016 11:43 am
JCGator wrote:Gotta love Southern Airboat to bring out the truth! New airboaters looking for a boat/engine should take note of this... this i pretty common that the HP, builder, specs, etc in the description are all BS! :violent1:
x2 This premise can NOT be over stated :!:
This is not the first time and likely will not be the last. If you don't take the time to exploit the knowledge, expertise and helpfulness that exists right here, you've probably done yourself a disservice. This is just another example that supports my premise that there is reason that some stuff is for sale on ebay and craigslist instead of being listed here. :idea:
Caveat emptor !
terrible ted
Re: Over 350 HP ??
Postby terrible ted » Tue Jun 07, 2016 8:40 pm
like they say the prof is in the prop. My motor will only spin a 74 wispertip to 3000 set on the 13 mark with the seam of the blade. 350hp should spin more
aherr520
Re: Over 350 HP ??
Postby aherr520 » Wed Jun 08, 2016 10:09 pm
JT540 wrote:lol. well I was gonna stay out of this one but I built that motor. it is nothing of what he says. the motor is a small main wide deck straight valve that I rebuilt with a phase 3 cam and 9 to 1 pistons. the guy bought it from me I delivered it to Okeechobee and the guy was supposed to bring it back for me to do the startup once mounted never did. he took it to gary for a carb issue and gary put a nos carb that he had on it and last I heard it had been sunk twice. they may have done something to it since then cause the pushrod tubes were black but I don't think gary has done it or he would have called me to let me know. I think the guy is full of **** all the way around.
so it doesn't have 350hp how much does it have :dontknow:
aaof member
JT540
Re: Over 350 HP ??
Postby JT540 » Thu Jun 09, 2016 6:26 am
if I had a dyno I could tell you! but I don't so all I can do is guestimate. they way that its built with only 9 to 1 pistons and cam is should be around 265 you don't gain much hp from just that little bump in compression but you gain snap and throttle response.
