Oil cooler and lines
Austin h
Postby Austin h » Fri Jul 15, 2016 4:09 pm
Any suggestions on where to get oil cooler and lines putting it in an o-470r
hogdoggin
Re: Oil cooler and lines
Postby hogdoggin » Fri Jul 15, 2016 4:14 pm
Any hydraulic shop should be able to make them. Also I believe Napa auto parts can make them but I think they are a little more than most hydraulic shops.
Austin h
Postby Austin h » Fri Jul 15, 2016 6:38 pm
How about where to get an oil cooler?
goldhunter_2
Postby goldhunter_2 » Fri Jul 15, 2016 6:45 pm
allot of people get the transmission cooler from local auto parts store but if you find a think GPU cooler it will do better job but either will work
:rebel:
hogdoggin
Postby hogdoggin » Fri Jul 15, 2016 7:18 pm
This is what I have used on many different boats works well. And most every airboat shop stocks them.
https://m.summitracing.com/parts/hda-1260
Also just something to think about if you find a used one you don't know if it's been on a motor that's wore out and has had metal run through it or if it's been on a motor that has blown up before. That's one of the reasons I've never used a gpu cooler. Oil coolers aren't cheap but it's also the life of your motor. They can be flushed out. And probably be fine I'm just not going to do that on my engine. Oil cooler is cheap compared to a engine.
rowdy1
Postby rowdy1 » Fri Jul 15, 2016 9:22 pm
Go on the Hayden website and get the part # for the size you want, then go to Amazon and buy it. That's the cheapest I found. I then bought the fittings from NAPA, installed the cooler and measured for hoses. NAPA built the hoses as well. About $200 total.
diamondback0320
Postby diamondback0320 » Sat Jul 16, 2016 2:22 pm
Ecor industries in Melbourne off wickham Rd can make any lines needed usually while you wait if their not too busy & very reasonable
Last edited by diamondback0320 on Sat Jul 16, 2016 2:23 pm, edited 1 time in total.
diamondback0320
Postby diamondback0320 » Sun Jul 17, 2016 10:08 am
Oops guess ecor industries is a pest control,maybe it's ecor hydraulic off wickham Rd across from harbour freight don't remember name of that rd
Austin h
Postby Austin h » Sun Jul 17, 2016 12:08 pm
Thank you. Any suggestions on how many layers the oil cooler should have? It's on an o470.
diamondback0320
Postby diamondback0320 » Sun Jul 17, 2016 12:13 pm
Not really sure on size but I run what appears to be 1 of the Hayden's mentioned above..open that link above..mine is a 4cyl which is probably overkill on my boat but I see 6cyl motors running same 1 or even smaller..my temp always runs 180 unless I run it hard on the dry & then never above 190
goldhunter_2
Postby goldhunter_2 » Sun Jul 17, 2016 4:07 pm
diamondback0320 wrote:mine is a 4cyl which is probably overkill on my boat
there is no such thing as overkill when your talking about cooling your airboats motor
:rebel:
goldhunter_2
Postby goldhunter_2 » Sun Jul 17, 2016 4:13 pm
Austin h wrote:Thank you. Any suggestions on how many layers the oil cooler should have? It's on an o470.
Those thin coolers (about 1" I think) the others are telling you to buy "new" will work ok, lots of people use them and they only run 10-15 degrees hotter when your pushing the boat hard
:rebel:
Moritz
Postby Moritz » Sun Jul 17, 2016 5:43 pm
Go to trade a plane web site and look up aircraft salvage yards call them and you can get one. Just make sure it is not from a failed engine. You want a serviceable one or get one and send it to pacific oil coolers and have them clean and flush it out
GeeLeDouche
Postby GeeLeDouche » Wed Jul 27, 2016 5:35 pm
I have a GPU oil cooler that would be overkill for your motor. I was going to put it on my 470-L but never got around to it. I'll make you a good deal on it if your interested.
text me 801-991-0577
1648"M (& floatation pods) "Lowe" modified V Jon boat with a 31hp mudbuddy hyperdrive.
jeepinocala1111
Postby jeepinocala1111 » Wed Jul 27, 2016 6:20 pm
Just wanted to throw in a little reminder you need to use large lines do not try small lines.
Users browsing this forum: Google [Bot] and 3 guests
