BALLASTIC GEAR BOX?
gatorfrog2
BALLASTIC GEAR BOX?
Post by gatorfrog2 » Thu Aug 11, 2016 8:46 am
Questions? We recently went with a 2.68 BALLASTIC gear box on a 383 Stroker from Whites performance. 550hp. +/- it's swinging a 82" 3-blade R at the 2.5 mark. Performers Great!!!......BUT
Recently after the first scheduled oil change we are getting sum "NOISE" Clancking / CHURPING etc. seems to only be after box is HEATED UP!!... Running for awhile. We do have the ALL CARBON blades an I know they are a litl noisier but this noise is coming from the box not the engine or the blades. Tried to contact seller but number no longer exist. Contacted d manufacturer an they said they are having sum problems in that department. I'm wondering do we send box back an get it checked out before WARRANTY runs OUT!!?.... Or run it till it BLOWS!!??;0. I'm affriad if there's Un nessasary tolerance / vibration issues it may affect engine bearings etc. HELP!!?? Thanks in advance.
Lycoming 0320H 3/4 alum. Custom deckover 69" Narrow Whispertip w/ SuperSlick2000
406 JAMIE
Re: BALLASTIC GEAR BOX?
Post by 406 JAMIE » Thu Aug 11, 2016 9:01 am
yes do send back sir mite cause bad vibrations and lead to maybe a bottomend problem.hope this helps y all besafe :rebel: :toothy7:
DynaMarine
Post by DynaMarine » Thu Aug 11, 2016 9:04 am
By all means send that sucker in and we'd be glad to take a look at it and see if it's a gear issue or what. Give me a shout any time and I'd be glad to help!
Shane
direct: 785.424.4478
shop: 785.218.9449
Shane Lavalette
President/Owner
DynaMarine Performance Boats
785.218.9449
www.dyna-marine.com
shane@dyna-marine.com
Post by Deano » Thu Aug 11, 2016 9:19 am
In spite of the fact that I've not run a Ballistic box yet, I'm really glad to see such a prompt response. :salute:
Even before I finished reading that, I was thinking how uncharacteristic that sounded. :wink:
Des Moines Boater
Post by Des Moines Boater » Thu Aug 11, 2016 9:45 am
Shane, I called all the numbers and still no response back. I'm not having any issues with the box but I don' think the gear ratio is correct for my ride. I have mine pitched at the 3 mark and I still have to turn 3600 rpm to cruise over 30 mph. I don't think the prop is turning fast enough. At 3600 rpm the prop is only turning 1300 rpm. I wonder if a 2.5 or 2.3 would be a better set up for me.
Wow!!! fast response. Thanks for the answers.
13' 6 Lazer, 383 SBC 425 hp, 2.7 Ballistic, 3 blade 80 NGR
DynaMarine
Post by DynaMarine » Thu Aug 11, 2016 10:05 am
I seen the "888" toll free number was listed in a lot of the signatures and what not, that number doesn't work.
If anyone needs to get a hold of me please use this number and leave a message if someone doesn't answer. 785.218.9449
Tim - Let me know what you see for results with a little more pitch in that prop. If it's still not the desired cruise RPM we can look at a lower ratio.
Thank you!
Shane Lavalette
President/Owner
785.218.9449
www.dyna-marine.com
Post by SWAMPHUNTER45 » Thu Aug 11, 2016 10:24 am
X2 FREAKING impressive vendor respons :salute: e !!!!!
digginfool
Post by digginfool » Thu Aug 11, 2016 12:09 pm
SWAMPHUNTER45 wrote:X2 FREAKING impressive vendor respons :salute: e !!!!!
No doubt. Shane is the real deal; truly cares about his business and, most importantly, his customers. I have never had him not call me back for even the most minor issues/questions. If others in this industry had the same mindset, I would have a different motor than I currently do. JS
josh_2562
Post by josh_2562 » Thu Aug 11, 2016 2:49 pm
Shane also helped me out with questions I had about my stinger gearbox. If I ever need a new box I will be giving him a call
gatorfrog2
Post by gatorfrog2 » Thu Aug 11, 2016 10:45 pm
10-4. Thanks for QUICK response etc.i believe we will be dismantling from engine prop,etc soon an shipping back for check UP! Just in case before "duck season " starts. Don't wanna breakdown where we go :shock: :violent1: :slap: :florida: :thumbleft: hope to get all the bugs worked out before we run her HARD AGIAN. Thanks in advance. Shane is da man!! :salute:
warrior-p
Post by warrior-p » Mon Jan 02, 2017 1:05 pm
I got a 2.3 ballistic I am considering selling
18 x 8 TEXOMA AIRBOAT, ZZ540 engine, 2.38 BALLISTIC DRIVE and an 82" 4 blade Whirlwind Whispertip EX prop
Waterthunder
Post by Waterthunder » Tue Jan 17, 2017 5:56 pm
To be honest if you are
you need to free up your boat unless its 18ft and hauling 6 people them are not good performing numbers.
THE PROOF IS IN THE PROP!
http://waterthunder.com/
321-508-5316
junglecat
Post by junglecat » Thu Feb 09, 2017 12:14 pm
Is that skinny or deep water? In deep water I turn around 3000 to cruise at 30mph , in skinny a lot less .
Larry Smith built 427 SBC
2.68 Ox Box
82" 3 blade R
supersnake60
Post by supersnake60 » Thu Feb 09, 2017 6:03 pm
my boat turn 80 inch at 2600 and 30 mph in deep or skinny water it 14 foot boat and 8 blades excalliber at 20 deg at 5700
supersnake60
Post by supersnake60 » Fri Feb 10, 2017 9:50 pm
guy check hull bottom and you may have cup if hull not flat my need more rpm get up plan or you have a heavy boat
