AIRBOAT RETRACTABLE BIMINI TOP
kwowens1963
Post by kwowens1963 » Mon Aug 29, 2016 6:49 pm
I have seen several airboats with retractable bimini tops on them where they lay up against the cage when not in use, I am looking to install a good one on my airboat, anybody have any suggestions on a good one that will fit my 96 inch wide beam boat
thanks,
Kerry :texas:
2012 15x8 GTO 383 Stroker, 3 blade sensenich
"Don't Stop Believin"
RRAA #007
BRAB #54
bonecollector
Re: AIRBOAT RETRACTABLE BIMINI TOP
Post by bonecollector » Mon Aug 29, 2016 7:40 pm
Jason at soft shell canvas in Debary does all mine he does great work and he is mobile
Sensenich, Ox Drive gear box dealer 386-279-3712
Rich Andrews
Post by Rich Andrews » Mon Aug 29, 2016 8:07 pm
if your going to custom make one, make it so it goes forward and backward for a whole lotta reasons. Youll thank me later
BGREEN427
Post by BGREEN427 » Mon Aug 29, 2016 8:11 pm
Why backwards?
glades cat
Post by glades cat » Tue Aug 30, 2016 7:26 am
A custom built top can fold down easily forward inside your grass rake for storage and thick riding or back towards the cage when not needed.
http://www.southernairboat.com/photopos ... op/cat/500
Duece
Post by Duece » Tue Aug 30, 2016 10:06 am
Rich Andrews wrote:if your going to custom make one, make it so it goes forward and backward for a whole lotta reasons. Youll thank me later
Yeah Rich, why both ways?
Duece
"Welcome to the Dark Side..."
kwowens1963
Post by kwowens1963 » Tue Aug 30, 2016 12:48 pm
thats makes sense, good info indeed
RRAA #007
BRAB #54
Rich Andrews
Post by Rich Andrews » Tue Aug 30, 2016 2:40 pm
Ever try to squeeze under that bridge Deuce? Couple times i've had to drop my cover to the ft so I could fit under it
Another unless your flag mounts behind all the bimini top, your gonna need to make adjustments one way or another.
If your stuck sitting in one area because you cant fire up and the sun drops down in ft of you, you can drop your top down and keep the sun off you. I also have used mine as a hunting blind in front of me.
Unless your going to wrap it up nicely in the cover every time u use it which I never do.. when pulling the rig down the road, just drop it forward and it wont flap in the breeze and wear out the material! You would be amazed at what the cage wire will do if its not all tied down and flapping against it.
I also suggest that you use D Clips to O rings(metal) sewn to straps on the seat structure and cage to secure the top. Most of the hardware on Bimini tops is junk and it will break.
Minor stuff but functional nonetheless
ringneck
Post by ringneck » Wed Aug 31, 2016 8:38 am
I run salt water bays, marsh, big lakes, rivers, and dry stuff with brush.
Stainless bows and hardware are heavy but very strong. i'm guessing mine
weighs over 60 lbs. but I have never had any of it break or tear off.
Well worth the expense if you plan on full day trips in the hot sun.
On some really nasty cold rainy days I have even parked my rig on dry ground
and hog hunted in comfort.
:texas:
16x8 AIRRANGER RHINO, LEVATATOR 450, CH3, WHIRLWIND 3B-80
Aircraft hand prop tractor, half guard old school survivor
Post by kwanjangnihm » Wed Aug 31, 2016 3:22 pm
Duece wrote: why both ways?
don't act like you didn't know CM guys go both ways!! :stirpot: :toothy7: :stirpot: :toothy7:
Rich Andrews
Post by Rich Andrews » Wed Aug 31, 2016 3:53 pm
i thought only guys with bent rudder sticks did :lol:
kwowens1963
Post by kwowens1963 » Wed Aug 31, 2016 4:28 pm
Any certain dealers for these tops in the Texas area, I dont want to buy a POS the first time around
KO
RRAA #007
BRAB #54
Duece
Post by Duece » Thu Sep 01, 2016 11:01 am
Lol, I couldn't get under most bridges with mine anyways! I don't know why, but I've always wanted one that laid forward for some reason, but I could see the merit it having it go both ways. They are proud of those SOB's! I've had 2 quotes and they are expen$ive!!!
Love the bent rudder stick comment!
Duece
fhp6
Post by fhp6 » Thu Sep 01, 2016 11:25 am
Duece wrote:Lol, I couldn't get under most bridges with mine anyways! I don't know why, but I've always wanted one that laid forward for some reason, but I could see the merit it having it go both ways. They are proud of those SOB's! I've had 2 quotes and they are expen$ive!!!
Duece
Like you I was shopping for a bimini top until I started getting quotes. WOW! So I went with the option of mounting a nice pole holder and bought a 9' patio umbrella. Works really well when the sun or rain is a factor.
:old_glory: FHP6
Citrus County Airboat Alliance (Member)
"USMC"
:florida:
406 JAMIE
Post by 406 JAMIE » Thu Sep 01, 2016 11:58 am
Duece
X2 i too did same thing worked really well thise days in lake fishing.
Cooter69
Post by Cooter69 » Thu Sep 01, 2016 2:54 pm
Here's a pic of mine, it will go down under grass rake or you can lay it up on the cage.
Cooter
Crazy Cooter
USMC
14 " Seminole SS rigging with 0540 Angle valve 6 blade warp drive.
GTO Airboats
Post by GTO Airboats » Fri Sep 02, 2016 5:42 pm
We offer quality Bimini tops that are built to last if you have any questions please call us at (352)401-9070
mwood7800
Post by mwood7800 » Mon Sep 12, 2016 9:17 am
I tried a Bimini too, it really intensified the prop noise, enough that I wouldn't even put it up while underway. Went back to an umbrella.
