Experinced opinions on poly replacement
undicided
Post by undicided » Mon Jan 09, 2017 6:54 pm
I have to change the poly on my alumitech. Existing poly is screwed off with a few nuts where needed. Question is, do those of you that change out poly weld the old holes and drill new or reuse existing holes maybe installing a larger diameter screw.
pontoon outlaw
Re: Experinced opinions on poly replacement
Post by pontoon outlaw » Mon Jan 09, 2017 7:55 pm
:cheers: did mine twice and have used same holes both times, of course some were stripped out then I put a nut on it... of course everybody said it wouldn't work ha ha I run the Hill like a raped ape..
Lwells
Post by Lwells » Mon Jan 09, 2017 7:58 pm
I wonder why no one uses aircraft rivets?
bkmail
Post by bkmail » Tue Jan 10, 2017 12:48 am
Fill in the old holes first.
Straighten out the hull
Weld up anything needing attention
Lay on new poly and start securing
Bk
barhopper
Post by barhopper » Tue Jan 10, 2017 6:37 pm
If you elect to fill the holes make sure you chase them first. I've seen some welds pop out of non cleaned holes. I personally use the existing holes with brass nylocks and washers. It does take two people to do it.
techelp3215436655
Post by techelp3215436655 » Tue Jan 10, 2017 9:24 pm
I wrote an article on installing polymer correctly you could call air boating magazine for the article or 321-543-6655 airboatdave@gmail.com
AirRanger
Post by AirRanger » Tue Jan 10, 2017 11:27 pm
pontoon outlaw wrote::cheers: did mine twice and have used same holes both times, of course some were stripped out then I put a nut on it... of course everybody said it wouldn't work ha ha I run the Hill like a raped ape..
X2
bkmail
Post by bkmail » Wed Jan 11, 2017 3:01 am
Don't forget to taper the edges on the poly.
Bk
fhp6
Post by fhp6 » Wed Jan 11, 2017 9:35 am
Out of curiosity, what tool or tools work best to taper the poly once installed?
:old_glory: FHP6
Citrus County Airboat Alliance (Member)
"USMC"
:florida:
undicided
Post by undicided » Wed Jan 11, 2017 12:38 pm
Thanks for the input. Looks like ill be cleaning, welding, drilling, countersinking and drinking beer in a couple weeks (its an unspoken rule that beer must be drank while working on Airboats). Thanks for the input.
swamper2
Post by swamper2 » Fri Jan 13, 2017 6:57 am
fhp6 wrote:Out of curiosity, what tool or tools work best to taper the poly once installed?
electric hand held plane works best for me
fhp6
Post by fhp6 » Fri Jan 13, 2017 9:09 am
Thank you!
:old_glory: FHP6
"USMC"
:florida:
nebraskaairboater
Post by nebraskaairboater » Fri Jan 13, 2017 9:24 am
When I replaced the poly on my aluminum hull I reused the existing holes with no problems. I did use nylock nuts and washers though.
Dan Porter, Jr.
Fremont, NE
bkmail
Post by bkmail » Fri Jan 13, 2017 12:22 pm
Exactly.
Or cut it with a circular saw set at an angle.
Bk
