What is this hole on the accessories case on a 220 just below the tach cable?
TDezso
Postby TDezso » Wed Jan 11, 2017 7:59 pm
What is it for, is it a vent, is it supposed to be covered, and can I tap it and plug it?
diesel250rr
Re: What is this hole on the accessories case on a 220 just below the tach cable?
Postby diesel250rr » Wed Jan 11, 2017 8:40 pm
Mine has a bolt
TDezso
Postby TDezso » Wed Jan 11, 2017 9:05 pm
That's really weird. This motor has run a long time with that hole open. I'm gonna rap it and plug it. Thanks for the pictures.
diesel250rr
Postby diesel250rr » Wed Jan 11, 2017 9:06 pm
No problem you could pull one of your upper bolts and find the thread size
TDezso
Postby TDezso » Wed Jan 11, 2017 9:55 pm
I tapped it to a 5/16x18 and pulled an unused stud from the acc case and ran it in with some rtv.
Postby John Fenner » Thu Jan 12, 2017 8:48 am
That is a bolt hole for the oil pump, 1/4-20 x1-1/4" long.
TDezso
Postby TDezso » Thu Jan 12, 2017 12:11 pm
It wasn't threaded. Just a machined hole.
Postby John Fenner » Thu Jan 12, 2017 12:45 pm
Then the bolt is broken off in the oil pump housing.
TDezso
Postby TDezso » Thu Jan 12, 2017 1:57 pm
Easiest way to get to it? How many bolts hold the pump in? I can't find any info on the pump.
