Ls3 tunning
Lawmitera
Ls3 tunning
Postby Lawmitera » Fri Jan 27, 2017 2:40 pm
I have a new boat with an ls3 in it. I'm using the mass air flow sensor and my boat builder thinks we should remove it and retune the computer. Is this a good idea.
CarMotorBarge
Re: Ls3 tunning
Postby CarMotorBarge » Sat Jan 28, 2017 4:50 am
I have a couple of questions to help answer your question:
1. Which EFI are you using?
2. Have you made any mods to the stock LS3?
3. What problems are you having that is making your boat builder think the MAF sensor should be removed?
4. What is going to be used to replace the functionality of the MAF sensor?
Thanks.
419 CI Horsepower Barn LS3 with 2.68 Rotator soft drive swinging 4 blade 83.5" R
Member of Seminole Airboat Club
Users browsing this forum: No registered users and 7 guests
