Sensenich or warp?
Airboat propeller discussion.
airboater67
Sensenich or warp?
Post by airboater67 » Thu Feb 09, 2017 9:54 pm
I'm sure this has been discussed a million times, but just want opinions. 3 blade sensenich or 6 blade warp drive. 285hp IO-520 on 13' hamant. No racing, like push and a little snap. Been running a gpu with 5 blade warp since 95. Just seeing what's out there now. Yes the warp is still pushing, never had an issue other than the noise. Thanks !
Olf Art
Re: Sensenich or warp?
Post by Olf Art » Thu Feb 09, 2017 10:28 pm
Do yourself and the rest of us a favor ...... call Don at Sensenich in Plant City, Fl. He'll hook you up.
goldhunter_2
Post by goldhunter_2 » Fri Feb 10, 2017 1:22 am
Sensenich
:rebel:
blackpowderscout
Post by blackpowderscout » Fri Feb 10, 2017 1:57 am
Sensenich
"Friends don't let friends hunt with inlines."
NRA Life
Traditional Blackpowder Hunting? http://traditionalblackpowderhunting.com/
digginfool
Post by digginfool » Fri Feb 10, 2017 6:23 am
If you want great push, you have to consider the Excalibur. It really is an awesome prop. In full disclosure, I've got one for sale. ;)
Post by Deano » Fri Feb 10, 2017 11:05 am
Olf Art wrote:Do yourself and the rest of us a favor ...... call Don at Sensenich in Plant City, Fl. He'll hook you up.
x 2
digginfool wrote:If you want great push, you have to consider the Excalibur. It really is an awesome prop. In full disclosure, I've got one for sale. ;)
Diggin' is far from the only one to make this observation. Perhaps a better poll would be Sensenich or Whirlwind.
http://southernairboat.com/phpBB3/viewt ... 4&p=609751
Sidejobs sure liked his, and he was running some pretty healthy junk. :lol:
The warp drive doesn't seem to collect votes when you want push and exclude racing. :|
fletchster76
Post by fletchster76 » Fri Feb 10, 2017 12:10 pm
Use to run a 72" 5 blade warp on a 285hp 520. Hated the sound and the sticky green grass would hang it up. Rapped up quick but just didn't have the low end needed to get moving if there was any resistance. Now I'm running a 72" NGH 3 blade on a 300hp 520, same hull/rigging. I spin it up to 2900 and it's a beast. Granted it's 15 more HP but now has plenty of snap, tops out in the 50's, and will go anywhere I have needed to go with 4 adults and a cooler. Only thing I've ever contemplated is going to a NGQ blade but I don't think I would see enough of a difference. I hear good things about the excaliber and razor set ups but not enough for me to contemplate changing. Just my 2 cents.
14’ Viking, 520 conversion, 72" 3 blade ngh
CarMotorBarge
Post by CarMotorBarge » Fri Feb 10, 2017 2:24 pm
I have seen thrust data showing a Whirlwind wide blade prop producing more thrust than the Excalibur. If you want the best possible static thrust, you need to go with a wider blade.
airboater67
Post by airboater67 » Sat Feb 11, 2017 1:28 am
Thanks , sounds like sensenich to me. I was leaning towards that anyway.
rowdy1
Post by rowdy1 » Tue Feb 14, 2017 7:04 pm
Put a 2 blade 72'' NGQ on it. ( 12'' wide, wing tip) I have a 285ph 520 on a 13' rivermaster w/ poly. It is set on 2.5 and at 2850 on the trailer. Its super responsive and will go anywhere. Stays on a plane at 1700 rpm with 3 people and a cooler in deep water.
Return to “Prop Talk”
