220 bogs and loses power at wide open throttle.
TDezso
Postby TDezso » Sat Mar 18, 2017 10:52 pm
Having a problem with my motor bogging and losing power at wot. It's a Holley 500 with 76 jets. It also seems to run rough around 2000rpm.
blackpowderscout
Re: 220 bogs and loses power at wide open throttle.
Postby blackpowderscout » Sun Mar 19, 2017 2:24 am
Is your fuel pump keeping up with the demand? Maybe an obstruction on the screen or in the lines somewhere?
"Friends don't let friends hunt with inlines."
NRA Life
Traditional Blackpowder Hunting? http://traditionalblackpowderhunting.com/
TDezso
Postby TDezso » Sun Mar 19, 2017 10:45 am
It's like to much fuel. My manual pump keeps up. I only use the electric to prime the system.
GMAC 76
Postby GMAC 76 » Sun Mar 19, 2017 10:49 am
check your points gap......and coil may be weak
Postby Deano » Sun Mar 19, 2017 11:17 am
GMAC 76 wrote:check your points gap......and coil may be weak
x2
Beyond that, the general consensus seems to be #74 jets . . .
http://southernairboat.com/phpBB3/search.php?keywords=%2B220+%2BHolley+%2B500+%2Bjets&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
TDezso
Postby TDezso » Sun Mar 19, 2017 11:42 am
Researching it, I could have a wrong size power valve. I'm going to check vacuum and see what size valve I need and order it and some #74 just. Just to start with a fresh setup that I know is right for my engine.
Postby Deano » Sun Mar 19, 2017 12:21 pm
Sounds like the prudent thing to do, and a safe bet to me.
I always like adding to the "Well, I know it's not that" list. :)
Swamp Thang
Postby Swamp Thang » Sun Mar 19, 2017 2:43 pm
I had a very similar issue recently with my GPU, disconnected the fuel line between the electric pump and the mechanical pump to check the pressure coming out of the elec. pump and there was almost no pressure.... so off to the auto parts store I go with receipt in hand for a warranty exchange, get back home and install the new one. Hit the fuel pump switch with the fuel line in the clear bottle before I hook it back up and still almost no flow... WTF? :scratch: :scratch: scratch my head a couple of times and start checking the lines & fittings back to the fuel tank, didn't take long to track it down. Ended up being a little corrosion on the spring in the check valve fitting at the top of the tank, removed the ball & spring....Problem solved :D
TDezso
Postby TDezso » Sun Mar 19, 2017 3:05 pm
Swamp Thang wrote:I had a very similar issue recently with my GPU, disconnected the fuel line between the electric pump and the mechanical pump to check the pressure coming out of the elec. pump and there was almost no pressure.... so off to the auto parts store I go with receipt in hand for a warranty exchange, get back home and install the new one. Hit the fuel pump switch with the fuel line in the clear bottle before I hook it back up and still almost no flow... WTF? :scratch: :scratch: scratch my head a couple of times and start checking the lines & fittings back to the fuel tank, didn't take long to track it down. Ended up being a little corrosion on the spring in the check valve fitting at the top of the tank, removed the ball & spring....Problem solved :D
I chased that same problem when I first got the boat. The pick up tube was to close to the bottom of the tank and would starve the engine. This problem I never lose pressure on the gauge.
Postby John Fenner » Mon Mar 20, 2017 1:38 pm
Pull fuel inlet adapter off the bowl, remove sintered bronze filter and spring and throw them away. If none present then be sure of tank vent clear of debris, also depending on electric pump type, it may or may not allow full free flow when off, and it may have a screen that is clogged.
TDezso
Postby TDezso » Mon Mar 20, 2017 1:42 pm
I don't lose fuel pressure. The gauge stays at 5-6psi the whole time. It's like it is flooding out and clears up when I get off throttle.
Postby John Fenner » Mon Mar 20, 2017 3:43 pm
Is the gauge in the bowl, post sintered filter? Nope.
Postby Deano » Mon Mar 20, 2017 4:10 pm
Have you run it, bogged it out and shut it down in one motion, and then read the plugs? Doing so should confirm or deny your flooding theory. It sounds like, and odds would seem better it isn't getting enough gas.
Are you sure the float level is set correctly? Sure your gauge is accurate?
Holleys are designed to run with 7 psi. I have a buddy that had a 350 w/650 Holley that argued his 5 1/2 lbs disallowed for any fuel pump issues. After trying everything else (to include a carb), he finally replaced the pump, got 7 lbs and that was the end of his problem. You have more cubic inches than he did.
Pressure really doesn't mean anything if you don't have volume to go with it. Do you have sufficiently sized fuel line that's in good shape? If the inside of an old line is collapsing, it will not pass the required volume.
I would first do what John suggested and then use no filter(s), one pump, good line and pull it from half a five gallon can. If it runs OK like that, you can add things back one at a time until you have the problem. If not, try the other pump.
I had one that acted like that and it ended up being the filter in the tank was crapped up. Now I start there and disallow for that first.
TDezso
Postby TDezso » Mon Mar 20, 2017 6:38 pm
John Fenner wrote:Is the gauge in the bowl, post sintered filter? Nope.
Gauge is last thing before the bowl.
TDezso
Postby TDezso » Mon Mar 20, 2017 7:00 pm
Deano wrote:Have you run it, bogged it out and shut it down in one motion, and then read the plugs? Doing so should confirm or deny your flooding theory. It sounds like, and odds would seem better it isn't getting enough gas.
I haven't had a chance to get it out to get it to bog and pull the plugs. All fuel lines are new and 3/8" and I have no filter in the tank. I am only at 5.5psi with one or both pumps. The manual pump is a Plymouth pump that people were running on here and the electric is a solid state pump of some kind. I do not know the brand. It's run from tank, electric, filter, manual, gauge, then carb. Also fuel bowl level is set just below sight plug sitting level.
glades cat
Postby glades cat » Mon Mar 20, 2017 7:06 pm
6.5 power valve.
TDezso
Postby TDezso » Mon Mar 20, 2017 7:14 pm
glades cat wrote:6.5 power valve.
I believe it is a 6.5 valve that was in the rebuild kit. Going by what Holley says to select the correct valve I should be running an 8.5. I have 19in of vacuum at idle when warm. Is it different for aircraft engines? I also read people are putting block off valves in.
TDezso
Postby TDezso » Mon Mar 20, 2017 7:20 pm
Might be a 4.5. Also it bogs if I stab the throttle from idle.
peanutbutter kid
Postby peanutbutter kid » Mon Mar 20, 2017 8:08 pm
i've had the electric pump clog up when u don't have a filter between the tank and pump .. on my gpu i run tank, water separator, manual pump, another filter and to 500 holley....
TDezso
Postby TDezso » Mon Mar 20, 2017 8:13 pm
What's a good pump on a budget? I see carters around $60. What model?
diamondback0320
Postby diamondback0320 » Mon Mar 20, 2017 8:59 pm
i used to swear by carter pumps until year b4 last...mine took a dump after who knows how many years it was on this boat..replaced with a new 1 & it didn't last 6mthns.. talked to a few mechanics & was told carters are being made overseas now just like everything else..ended up buying the gold series facet & has been on the boat bout a year with no problems whatsoever
TDezso
Postby TDezso » Mon Mar 20, 2017 9:25 pm
diamondback0320 wrote:i used to swear by carter pumps until year b4 last...mine took a dump after who knows how many years it was on this boat..replaced with a new 1 & it didn't last 6mthns.. talked to a few mechanics & was told carters are being made overseas now just like everything else..ended up buying the gold series facet & has been on the boat bout a year with no problems whatsoever
What model facet did you go with?
diamondback0320
Postby diamondback0320 » Tue Mar 21, 2017 12:28 am
not sure what part# it is I'll look in the morning
diamondback0320
Postby diamondback0320 » Tue Mar 21, 2017 10:12 am
facet 40007 is the 1 i bought for my lycoming
TDezso
Postby TDezso » Tue Mar 21, 2017 10:17 am
diamondback0320 wrote:facet 40007 is the 1 i bought for my lycoming
What does it run for pressure? Says max is 5.5psi
