Starting point on pitch
Airboat propeller discussion.
Shippee123
Post by Shippee123 » Thu Jun 29, 2017 9:09 pm
Switching out props and I waited to late to call Whirlwind today. I have a 74 inch stump puller on my stock BBC direct drive. I could only put 6 degrees in it and get about 2950 out of it. Pushes boat ok but has been loud cause it is set too flat.
I just got a 70 in super snapper back that I had let a friend use. Does anyone have an idea of a good starting point to set it at. I don't have a tach on the boat, so i cant just play with it. Was figuring about 16 degrees just because of it being narrower and 4 inches shorter .
Any info I appreciate
Art
br,lc,LA
Re: Starting point on pitch
Post by br,lc,LA » Thu Jun 29, 2017 9:29 pm
Is it a 3bld 70 or a 2bld.... 3 bld id say 16-18 but two blade you may wanna start at 20+
I spin a 68 SS 3bld at 13deg with 180hp
454 HO makes about 300HP at 3000rpm
12x7'6" American Airboat
1.4L GM Ecotec - Stock Turbo
2:1 Century Ecotec Drive
80" 2-bld WW Stump Puller
Shippee123
Post by Shippee123 » Thu Jun 29, 2017 9:38 pm
2 blade
406 JAMIE
Post by 406 JAMIE » Fri Jun 30, 2017 8:18 am
i always started at half mark on hub did a strap down test hit on the trailer to see where i was and that let me know to add/take away pitch.hope that helps.y all besafe. :rebel:
hill
Post by hill » Fri Jun 30, 2017 3:16 pm
A tach would be a good investment to start with . lmo
If a bullfrog had a hip pocket he,d carry a pistol to shoot black snakes.
JAMES
Post by JAMES » Sat Jul 15, 2017 9:37 pm
hill wrote:A tach would be a good investment to start with . lmo
Serious yea good advice i woukdent run it with out
Post by Deano » Wed Jul 26, 2017 9:46 am
x 3
Return to “Prop Talk”
