Holley 750 double pumper jetting
Basin_Runner355
Postby Basin_Runner355 » Thu Dec 14, 2017 5:36 am
I bought a used Holley 750 double pumper it’s been sitting on a a shelf for a while so I’m going to put a rebuild kit in it so I know it’s fresh was wondering if somebody could tell me what jets should be in it it’s going on a bone stock zz4 with a 2:1 belt reduction he said don’t remember what motor it came off off cause he has like 20 Work boats so while it’s apart I wanna check make sure I have the right jets in it so I don’t have to tear it down again
14ft diamond back mild zz4 355sbc pushin 410 hp 430 TQ 2:1 belt drive reduction with a 78 water walker falcons pitched at 5200
swamper2
Re: Holley 750 double pumper jetting
Postby swamper2 » Fri Dec 15, 2017 8:19 am
http://www.innovatemotorsports.com/prod ... l_plus.php
To do it right spend a few bucks and buy one of these and take the guess work out . In the long run it will save you time and money plus a peace of mind
Basin_Runner355
Postby Basin_Runner355 » Sun Dec 17, 2017 7:57 pm
How it works you have to put a fitting on your headers or in the flex pipe
jeepinocala1111
Postby jeepinocala1111 » Sun Dec 17, 2017 8:39 pm
Basin_Runner355 wrote:How it works you have to put a fitting on your headers or in the flex pipe
I run the double one on each side it works great you can be sure everything it running correctly I welded the bungs just before the mufflers on the muffler inlet flange. I like it but know many people who do not use them and do just fine.
Basin_Runner355
Postby Basin_Runner355 » Mon Dec 18, 2017 6:03 am
Well my mechanic don’t really work on small boats and he has some made for 3.5 and 4 inch pipe that he hooks on the ends and tunes it off his computer but he don’t have any made for 3 inch yet
Basin_Runner355
Postby Basin_Runner355 » Mon Dec 18, 2017 6:05 am
And all I have is headers and the flux pipe goes straight out the back no mufflers
swamper2
Postby swamper2 » Mon Dec 18, 2017 7:25 am
you have to weld the bungs on the end of the headers before the flex pipe. the flex pipe leaks oxygen and will give you false readings. Read the install manual in the Innovate web site I sent you
swamper2
Postby swamper2 » Sun Dec 24, 2017 9:41 am
JAMES
Postby JAMES » Mon Jan 01, 2018 8:08 pm
Save your money on that gauge send the carburetor to a specialist S&S carburetor is in my opinion is one of the best send it to
Users browsing this forum: No registered users and 12 guests
