502 power VS torque
Re: 502 power VS torque
Post by Slidin Gator »
Ladyblackwater,
Thanks, I can sum up my experience with big block gas motors as "0", so I am not going to argue over where the motor wants to live. This is good input, but think about this. The primary reason that I leaned to the high HP motor with the tall gear is because it wins on prop torque, but it is by no means a huge difference. I also thought about the area under the torque curve, where the high HP, high gear looks to flatten out nicely at the low end. But that could definitely be bad data from the Four Wheeler guys, they don't care too much about low end torque, they just want to sling mud (at least my son does)! So if the torque falls off a lot on the low end, that would also change my mind.
Now also note that the side by side comparison shows torque at the prop peaking at significantly different RPM's, in fact the high Hp with 2.88 peaks around 1,800 prop RPM while the torque motor on a 2.88 peaks around 1250 RPM and then falls like a rock. So my thinking was putting the torque band into a reasonable area for the prop to perform. Reading between the lines of what you are saying is that the 502 is not going to survive constantly turning in the 4,500 to 5,500 RPM range? I can certainly buy into that.
Moving to the lower gear ratio will definitely change the equation such that the Torque motor and lower gear will turn the prop in the sweet spot. I will re-run the curves tomorrow night for ratios from 2.12, 2.37 and 2.55 to kick the tires on. Ultimately, to make a final decision it would be good for NOLA to get with the engine builder and see if he can get torque curves for the options that the builder is confident in meeting. I can then plug them in and we can kick the tires.
2.37
CarMotorBarge
Post by CarMotorBarge »
Slidin Gator wrote:I have had time to look into some 502 build option specs. In particular the following two web sites have dyno test data for different build configurations:
http://www.fourwheeler.com/how-to/engin ... r-buildup/
http://www.chevrolet.com/performance/crate-engines
The Four Wheeler link shows results from several builds, including a high RPM, High HP version. The following graph shows torque curves for these builds plus the Chevy crate motor specs:
Out of these options, the 2 torque curves that look like they have the most potential are the Chevy Crate ZZ502 and the Four Wheeler 502 Version 3A build. For comparison, the ZZ502 would be a “Torque” motor build and the Version 3A would be a “Horsepower” build. The interesting thing that I note is that the “Horsepower” build actually makes a little more torque than the “Torque” build, plus it makes that torque at a lot higher RPM, so it makes a lot more power.
If anyone has any other input on torque curves for this engine, please add them to the thread.
I applied 3 different gear ratio options to these two engine options, the 2.12 Nola has, a 2.68 and a 2.88 ratio. I also used a 90% efficiency reduction factor on the gear box. This is just a guess on my part and I am open to any input on what a good figure to use here would be. Some of the discussions I have seen on this subject said that gear box efficiency varies a lot and is hard to predict, but that should be part of the discussion.
This 21 foot boat application needs to throw the largest diameter prop possible. So this will need an 82” (or even bigger) prop with a maximum RPM in the range of 2,300 to 2,500, but you can run them slower, particularly with more blades, as others have noted here.
The first thing that this makes clear is that the 502 does not make the kind of torque or power that everyone has said this application needs. So it is going to be tough to make this 21 footer run dry. Looking at these curves, it looks like the 2.12 ratio box on hand is not enough gear to turn a big prop.
From my view, the 2.88 ratio and a high Hp build looks like the best, or probably only way to go, especially given the desire to run dry (because it is an airboat after all, it needs to run dry). That puts the motor operating above 4,000 RPM for most of the time, so make sure the heads and valve train gets the attention that it needs.
One note of caution, none of these sources provided torque data in the lower RPM region and the HP motor curve show the torque going flat below 4,500 RPM. If that is the case, then it is as close to perfect for the application as possible, but I wonder if these are really valid figures. Since this boat will be marginal at best on ground, it is going to need as much torque as possible off the line to get started on ground.
The end result is a big prop, turning at or below 2,000 RPM and a motor that operates in the 4,500+ RPM range. Talk to the motor builder and see what they have to say about maintaining good torque (~ 500 ft-lbs) below 4,500 RPM. If you have to sacrifice some top end torque to keep the low end flat, that would be a tradeoff to consider.
One last point, do note that the “Torque” curve is a factory crate spec engine while the “HP” curve is an aftermarket tuned unit. If this motor can be built to make substantially more torque down low, the above should be re-accessed.
How about some input to solve this riddle.
This is very useful info. Can you also post the HSP curves? I think this will help the discussion. Thanks.
CarMotorBarge
ladyblackwater wrote:Slidin Gator that is great information. I will say you are one guy with a bunch of great knowledge. The only thing I seen that won't work is the 2.88 gear. The boat is to big for a gear that big. The prop will spin to slow for the rpm's of a big block and size of the boat . I can tell you the big boats and big blocks don't like big gear ratios. He can run a 2.55 if he really wants but his best option is a 2.37. The 2.12 will work if that's what he has to work with. He will just have to put a prop that matches with the motor and gear ratio. If he went with a 2.88 ratio he would have to turn the motor no slower than 3400 rpm to get the prop in the range to push enough air. Now 3400 rpm is with a perfect set up and great running boat, this doesnt happen to often. I'm willing to bet that if he did choose the 2.88 ratio that his cruise rpm's would be nothing lower than 3600-3800 rpm, most likley close to the 3800 rpm. Every prop has to turn a minimum speed (RPM) to get it to perform correctly. This is something I've played with a lot and have learned a lot about.
Lets assume that super wide blades are going to be used. The max RPM for S blades is 2100 RPMs according to Sensenich. I am willing to bet that super wide blades from other manufacturers will be similar. Here are 3 of the common gear ratios and the engine RPMs:
1. With a 2.12, this means that the engine can only turn 4,452 RPMs (2100 x 2.12). This is not the correct ratio for this prop because you can't get the engine RPMs high enough.
2. With a 2.38, the engine can only turn 4,998 RPMs (2100 x 2.38). This might be OK, but I am willing to bet there won't be much pitch in a prop this big (especially a 4 blade S).
3. With a 2.55, the engine can turn 5,355 RPMs (2100 x 2.55). Assuming that the engine increases HSP from 5000 to 5400, the 2.55 gear ratio will allow more pitch to be put into the prop. The 2.55 will make more thrust and the additional pitch will help lower the cruise RPMs.
I would agree that the 2.38 would most likely cruise at lower RPMs than the 2.55, but this doesn't mean that the 2.55 uses more fuel or is harder on the engine. I would expect the 2.55 to get very similar fuel mileage as the 2.38 and be easier on the engine because there will be less load on the motor. RPM is not the only variable to look at when determining how long an engine will last.
I have a 4 blade 83.5" R on my 5 person boat. Recently I went from a 2.68 to a 2.88 gear. I was turning 5300 RPMs pitched at 12 degrees with the 2.68 and 5800 pitched at 13 degrees with the 2.88. I am getting the same fuel mileage between the 2 ratios despite the 2.88 gear cruising 200 to 300 RPMs higher. Also I have added pitch and additional prop RPM with the 2.88.
So why do I bring this up. My point is don't assume that higher engine RPMs means worse fuel economy. There are multiple factors such as BSFC, engine RPM (parasitic drag), and AFR. Also if you can add pitch, this will help improve the efficiency of the prop while cruising. The Water Walker concept boat with the variable pitch capability showed this.
CMB asked:
Man, you are going to make me have to get back onto my soap box, and I don't want to do all that typing. I'd rather draw curves in the sand at a cabbage head, or in a bar on cocktail napkins. NOLA tripped over this ant pile, he didn't know it was there! I took a big boot to it on purpose to settle the issue, at least some. It’s just like the first day of prison, when you know you are going to be in for a while, you pick out the biggest guy you can and pick a fight. If you survive the first minute the guards will pull you apart and you get some respect…
But seriously, the HP curves are irrelevant once we start looking at torque and RPM supplied at the prop. If you check out the Chevy crate engine link they have torque/hp curves for all the options. The 4 wheeler link just has the data listed, which is actually easier to work with:
Here is the ZZ502 "Torque" motor curve right off Chevy's website:
Here is a curve for the high RPM “Horsepower” motor.
Now note this point. I originally leaned towards the high “HP” engine strictly because it made more torque, regardless of RPM. Looking at the numbers again, the “Torque” motor makes 580 ft-lbs and the “HP” motor makes 594. So it is not really that much difference and I am inclined to believe that a tuned up Torque motor can probably make a good bit more torque, which would tweak the conversation. I am looking for as much torque with the widest operating band, then tune the gear and prop to match.
If you look back at the prop torque vs. speed curves for the 2 motors, note that the prop RPM is lower at max torque. If boat width and prop choices were unlimited, I would put as much gear as I can find and 90-100” (or whatever) 2 blade prop on the torque motor. The bigger prop turning slower at the same torque will way out push the smaller prop turning faster at the same torque. But there are limits in play, like being able to legally haul the boat on the road.
I do have experience running ground, but as I said last night, I have no experience with big block engines. So it would be good to have the RPM argument now and get that over with! But forget about Hp for the argument, strictly economy and reliability. I am inclined to defer to the guys that know and run the platform for advice on where the motor will survive, different platforms do different things.
Let’s get this part over with so we can optimize the configuration.
Post by Deano »
IMO, the fact remains that 2.12 gear isn't enough to attain the end he is after. He needs at least a 2.3x and maybe more.
Given the power required, he will be FAR better off with that 502 being a 540; again given his intent in the original post.
A 502 - 2.12 combo can rock a 16 maybe 17 ft. boat; a 21' boat, not so much. Dry ?
A 540 - 2.3x combo has a FAR better chance of doing what he is wanting to do.
ladyblackwater wrote:It's all going to depend on how you set it up and what you want to do with the boat. You will definitely need to run a 2.37 ratio or smaller and a good Superwide prop. If you are looking to do a lot of dry ground running and with a load you are looking at needing 700+ hp and close to 800 torque.
What will live a happier, longer life making that kind of power? A 502 or a 540?
I don't know that your graphing the 540-2.3x combo would show how large the difference would really be, but if your methodology is correct it should. Such a graph would be far more relevant and usable as what you have so far hasn't much addressed running dry.
In either case, the difference will be very readily noticeable if he stops 30 yards from the water.
Deano wrote:IMO, the fact remains that 2.12 gear isn't enough to attain the end he is after. He needs at least a 2.3x and maybe more.
10-4 Deano, I agree with everything that you say. I had a bit of tunnel vision and focused strictly on the 502 because that is the original posted question. I have plenty of doubt that the 502 is going to be enough for the intended use too. I am trying to keep the number of variables investigated at once to a minimum, otherwise it gets way too confusing to follow. The interesting thing is that the LS platform makes close to the same torque over the same RPM band as the 502 3A as posted above.
Reading between the lines of NOLA's original post, he asked if he should build the motor for low end torque or high end Hp. A 540 bore and stroke certainly adds cost to the build, but perhaps that is in the budget, and the 540 would definitely be a better example of a "Torque" motor for this application. NOLA should weigh in.
When I get more time I will search for some 540 numbers. If anyone has a torque curve to send me it would save some time for sure.
Just a quick search gave me this:
http://www.shafiroff.com/chevy-crate-en ... street.php
Horsepower 715 @ 6200 RPM
Torque 665 @ 4500 RPM
Bore & Stroke 4.500 x 4.250
Compression Ratio 10.5 to 1
Fuel Requirement 92 Octane
Changing the gear ratios on my spreadsheet is easy. Adding a different motor takes the time.
Here is the same 502 comparison, but with the 3 gear ratios being discussed now.
CarMotorBarge
Slidin Gator wrote:Changing the gear ratios on my spreadsheet is easy. Adding a different motor takes the time.
Based on this graph of the 2.12, 2.37, and 2.55 gears, which engine and gear ratio will make the most thrust and at what RPM (engine or prop)?
OneBFC
Post by OneBFC »
Well, I will just leave this here and you guys can finish figuring out what's going on from there. This is the Version 3 pt II 502 from the above examples. I mean, you can see that you make more thrust with 545 lbs of torque than you do with 594 lbs of torque. I think it's pretty darn clear what matters?
Red = hp
Blue = Torque
Yellow = Propeller Thrust
Here's a link to an actual spread sheet too so you can input any numbers you want.
https://docs.google.com/spreadsheets/d/ ... sp=sharing
-Russ
CarMotorBarge
OneBFC wrote:Well, I will just leave this here and you guys can finish figuring out what's going on from there. This is the Version 3 pt II 502 from the above examples. I mean, you can see that you make more thrust with 545 lbs of torque than you do with 594 lbs of torque. I think it's pretty darn clear what matters?
Red = hp
Blue = Torque
I can't believe it. The max thrust doesn't occur where the max torque is. Maybe that is why I asked for the HSP curves earlier. :stirpot: :stirpot: :stirpot: :stirpot:
What does that form say?
THEORETICAL
OneBFC
Post by OneBFC »
Wait, are you saying that the above graph is wrong somehow? Please explain?
I made this graph and I also provided access to see exactly how I made it. Feel free to find the flaw in it somewhere so I can correct it. The only thing I will give a nod to is the fact that the thrust numbers represent absolute best case and are not attainable due to cage wire, engine placement, etc.
That doesn't change one bit the fact that max thrust will occur at max hp and not max torque. Period.
This isn't designed to say "build a zero torque engine and you'll be fine." I'm not saying that at all. I'm just saying that HP > Torque when it comes to making useful thrust and when building or sourcing an engine, you need to make HP a priority because you can always size a gear reduction to make it work (within reason).
Realize that a Turbine engine like the kind used on some airplanes that spins 30,000 RPM and makes almost 2300 hp is only making 400lbft of torque. Can those engineers be so wrong?
Which curve is the thrust cruve following? HP or TQ?
Help me understand why you think my advice is wrong.
-Russ
Prototype
Post by Prototype »
One,
I didn't have time to read everything but it sounds like your trying to graph a premo rig from the numbers? How can a 0540 put a whoop ass on a built stroker? How can that also be reversed?
Ultimately I'd say your searching for a number or formula that hasn't been found yet.
Tune your boat and prop to max motor torque and find it's a dog. Not the average dog, but a fat princess dog that loves being feed a lot.
Considering your footer doing 85 on dry land, I wonder what your asking?
OneBFC
Post by OneBFC »
ladyblackwater wrote:OneBFC where are you getting your data for this graph. Also what Gear ratio and what prop are you using? It takes way more information than what you are giving to believe your graph.
I took the 502 engine data from a post in this thread just a few posts ago.....
I have measured the thrust my boat makes on a thrust tester. I also know how much power it makes at a given RPM while thrust testing at the same time due to the information the GM ECU provides. This allows you to determine a formula for HP to Thrust (For my boat of course) and I have applied a simplified version of that to the above graph. The actual exact thrust output is not all that important however to this discussion. What's important is the relationship of HP to Thrust. It follows HP, not TQ. Propellers need power to make thrust.
You can clearly see that the 502 engine in that graph makes 545 lbft torque at 4500 and it also makes that same torque at 6500. The difference is that the POWER of the engine at 6500 is considerably higher than when it's at 4500 and therefore it makes more thrust. Torque doesn't dictate what your thrust will be...
you could bolt a really inefficient warp drive propeller onto that engine and it would make less total thrust per hp compared to a good modern blade setup, but it will STILL mirror the HP curve and NOT the Torque curve.
I don't know what else to give you guys for proof. What exactly do you not believe here?
Maybe I should just quit trying to point out the obvious. It just really pains me to see people getting pointed in a suboptimal direction so I'm trying to either convince the Torque hold outs that maybe they should rethink things, OR, have someone show me the error of my own ways with some kind of proof beyond, "My 540BBC wooped that 8000000hp LSTT boat's but, 540BBC rules!" Because, frankly, that doesn't mean a darn thing to anyone due to all of the differences between the boat bulids. I need to see some kind of math, theory, thrust test results backed by matching dyno numbers, etc.
It would be helpful if you doubt that HP is what matters if you could post some actual information to support that instead of "I don't believe you" type responses. Tell me where I am wrong. PROVE it.
Here's an AC engine dyno I could dig up.....where do you think max Thrust occurs on this engine? (EDIT: THIS GRAPH HAS SEPARATE AXIS FOR TORQUE SO THE HP AND TQ VALUES DON'T CROSS AT A STANDAED 5250 AND CAN CAUSE CONFUSION
Prototype wrote:One,
Mouse: I am not asking anything, I'm making the case that Torque is not the primary engine attribute you want to chase if you are looking to make the best thrust possible.
-Russ
Any prop thrust experts on here?
Is there any data on the size of the thrust column ?
Do some blade designs produce a narrow column of air at a higher velocity ?
Do other blade designs produce a wide column at a lower velocity but with greater volume or CFM mass ?
Think of a .223 vs 45-70 that old 45-70 don't have pretty energy numbers but in real world killing will blow you off your feet.
CarMotorBarge
Slidin Gator wrote: Here is the ZZ502 "Torque" motor curve right off Chevy's website:
So I am going to tell everybody to throw away any torque curves you see from a dyno sheet. :shock: To be honest, they are causing more trouble and confusion in the airboat world and it is better to just throw them in the trash.
However, you definitely want to keep the HSP curves from the dyno sheets. You can actually get some useful info about how to setup an airboat for a particular engine. 8) Here is what the HSP curve from a dyno sheet can tell you:
1. The HSP curve tells you what RPM to turn the engine at WOT to achieve the maximum amount of thrust. Maximum thrust is achieved where maximum HSP is located. Look at the 502 Deluxe HSP curve above. This engine should be turned at 5200 RPMs to get the maximum thrust. The 502 3A motor should be turned at 6200 RPMs to make the maximum thrust.
2. The HSP curve can be used to determine what ratio you should use for a particular engine and prop. Lets assume that we want to turn a prop 2000 RPMs at WOT. The 502 Deluxe engine above will use a 2.55 ratio (2000 x 2.55 = 5100). 5100 engine RPMs is close to the max HSP generated at 5200. The 502 3A engine will require a 2.88 gear (2000 x 2.88 = 5760). For this engine and max prop RPM it would be nice to have a ratio between 2.88 and 3.26, but there isn't.
3. The HSP curve also be used to compare the low end torque between 2 different engines. All you have to do is overlay the HSP curve of engine 1 on top of the HSP of engine 2. If an engine is making more HSP at a given RPM, it is also making more torque.
Out of the 3 items above, a torque curve will only tell you item 3 (comparing torque between 2 engines). You can not derive items 1 and 2 from a torque sheet. That is why you throw the torque curves in the trash and keep the HSP curves. :stirpot: :stirpot: :stirpot: :stirpot: :stirpot: :stirpot:
Run a crate 502 at 6,000 on an airboat for an extended period and you will be buying a box of diapers to mop up the oil in your bilge !
My real world observation is they must side load pistons because they tend to use oil a lot as they wear.
CarMotorBarge
Slidin Gator wrote: Image
These engine torque curves and prop shaft torque to prop RPM curves need to be thrown in the trash also. :shock: The engine torque curves need to be replaced with HSP curves so you can determine engine RPM WOT and gear ratio.
The prop shaft torque to prop RPM curves also don't provide anything useful. What RPM will the prop make the most thrust at? I don't think it is where the maximum prop shaft torque is generated. :shock: Is a 2.88 ratio always better than a 2.68 and 2.12 ratio because it makes more prop shaft torque? I doubt that is true. The fundamental problem is that this chart contains no prop data. It is just engine torque multiplied by gear ratio with torque loss taken out for the gearbox. This chart would be useful if it was overlayed onto the thrust and required torque curves for an actual prop (for example the thrust and required torque curves for the 4 blade R thrust tested on Water Thunder's thrust tester earlier in this thread).
CarMotorBarge
SWAMPHUNTER45 wrote:Run a crate 502 at 6,000 on an airboat for an extended period and you will be buying a box of diapers to mop up the oil in your bilge !
No one is saying to run the 502 3A at 6000 RPMs for an extended time. Depending on the boat setup (hull design, weight, passengers, etc.), the 502 3A would cruise in the 2500 to 4000 range. 6000 would only be required occasionally to get out of a sticky spot on the hill. Also the 502 Deluxe is only ran at 5200 RPMs because of the HSP curve.
I would worry about the valve train reliability before the side loading on the pistons. You see substantially more valve train issues than bottom end issues on an airboat.
loudmouse
Post by loudmouse »
If you want a torque monster of an engine, build it for 5800/6000 rpm. For pump gas, 10.5 to 1, a big head, preferably no smaller than 345cc, depends on CID, a big valve, a low overlap cam with high lift to match head, a dual plane intake with long runners and a 1050 4150 carb. The longer the stroke the more torque it will make. Put a 2.37 box with 4 blade JX for when you get that beast on a plane ur cruz rpms will be lower and fuel consumption will also be lower. After all that money spent, ur stock 502 with 10 or 11 lbs of boost will be a lot stronger everywhere in the rpm band and probably for less money with efi.
Built and Tuned by Me
OneBFC
Post by OneBFC »
ladyblackwater wrote:Ding Ding Ding that shows your graph is only a major guess. You can NOT use your motor, gearbox and prop combination for your data because he is not wanting and can not use your combination. You are comparing Apple's to Oranges again. You do know that your thrust data you got from your prop at said Rpm's is NOT the same with every prop company and gearbox ratio?
There is no guessing with the data I provided. I physically tested and recorded data which was then put into a spreadsheet to obtain a formula. It is as far from an apples to oranges comparison as you can get.
All we have from YOU is a constant repeating opinion with no data at all to back up your claims.
So, until you can prove with supporting information that Power is not the factor that determines thrust, then you should seriously reconsider your point of view.
You do realise that all text books on this subject will say the same thing I am? I have provided, several times, links to that material for reference as well.
You should read it and here is just one, non text book, reference that is a pita to read, but, provides actual real information.
http://web.mit.edu/16.unified/www/SPRIN ... rpower.pdf
Here is an easier resource:
https://en.m.wikipedia.org/wiki/Thrust
If you still don't believe it after that, well, I guess we didn't go to the moon in the 60's either?
-Russ
OneBFC
Post by OneBFC »
ladyblackwater wrote:This will be nothing but a back and forth thing because some people just don't get it. :banghead:
Yep, you better look in the mirror there.
ladyblackwater wrote:a 1000Hp around 6500+ Rpm motor with very little torque would have been a better choice than my 750+Hp with 750+ torque at 5400 rpm :angry5: :banghead:
Why don't you show us a dyno for these two motors you are talking about? I'd like to see a 1000hp 500+ inch displacement engine that produces "very little torque" as compared to the same displacement engine at 750hp at around the RPMs you mentioned.
This last post of yours is, again, all opinion and zero data.
-Russ
OneBFC
Post by OneBFC »
ladyblackwater wrote:OneBFC I'm just going off what you are saying. You are the one saying that it's all about HP and don't worry about Torque. I'll post my numbers up later when I get a minute to post them.
Sounds good, I look forward to seeing it.
while we wait for that, here's some interesting dyno sheets from two 632 engines. Which engine will make more useful thrust when attached to a propeller?
Engine A
Engine B
Engine B web page (LOTS of good info): https://www.skipwhiteperformance.com/ca ... ine_86022/
-Russ
loudmouse
Post by loudmouse »
This from a person who has a very good knowledge of building engines and what is takes parts wise to achieve the goal we're after whether it be a airboat, a 4800lb drag truck, or a 2000lb dragster, if ur torque on a sbc/bbc is close to the hp u are choking the engine for air!!!! That my friend is what 99% of all engine builders do......... Would you rather have an engine that produces 750lb torque and 750 hp or would you rather have 750lb torque and 850hp? :dontknow: :violent1: Same amount of money spent and both at very similar rpm. :stirpot: :stirpot:
