Airboat for floundering POC
Diver01
Post by Diver01 »
New member here and new to air boating.
I have been running an 18ft Jon boat with an outboard and 13hp fan motor for floundering in the port O’Connor area. I feel very limited at times as to where I can and can’t go. So naturally I’m looking into an airboat.
I have 2 boats to go look at in South LA, one is a 14ft Fiberglass polly bottom with a DD caddy 502 the other is a 14ft glass poly bottom with a 383 vortex and a 2:1 gear box 3 blade carbon blade.
My question is how well will this style of boat perform for floundering and how good of a boat will it be in the POC area.
Thanks Gents!
:texas: 18x8 Diamondback deck over 454 wharp drive 8 blade
br,lc,LA
Re: Airboat for floundering POC
Post by br,lc,LA »
TX and LA folks do not frequent here much anymore... I check in time to time to talk with the Ecotec guys...
https://www.facebook.com/groups/5105542 ... oup_header
12x7'6" American Airboat
2:1 Century Ecotec Drive
2-bld Whisper Tip 72
Diver01
Post by Diver01 »
Thank you
Post by Slidin Gator »
Search and get in touch with screen name FlounderPounder. He is new to airboating, but his screen name says it all. He is in your area I believe.
It's been years since I have been there, but Matagorda Bay is a fairly open piece of water that can see some decent chop to deal with. I don't think you guys have a lot of dry running to do. 14 foot is pretty small for an open water boat, particularly one with a heavy caddy motor.
I would be looking for a bigger boat for those rough water crossings, but you definitely want to touch base with more locals.
Post by Deano »
No such thing as a 502 Caddy, never was. I thought that fabricated rumor had finally died in the early '90s.
Obviously the seller knows little about the engine. I would hold anything he told me suspect, at least pending verification.
Return to “Texas Airboaters”
