Prop & Gear Box Ratio Recommendations
PistolPete
Post by PistolPete » Fri Dec 14, 2018 11:39 pm
My Son is putting a 14x 8 Alumitec boat together using a Gen 5 6.2l l86 Direct engine 420 hp 460 tq. stock. He wants to be able to run dry ground without any chance of getting stuck, would also like it to run top end about 60 -65 mph. What we were thinking after talking to water walker was 80" 3 blade falcon or Maximus 2.55 OX Box.
CarMotorBarge
Re: Prop & Gear Box Ratio Recommendations
Post by CarMotorBarge » Sat Dec 15, 2018 1:56 am
Ignore the torque curve on that dyno sheet. It tells you nothing useful when selecting gear ratio and prop. It just confuses people. The HSP curve tells you everything you need to know. I would run WOT at 5400 to 5600 RPM given that dyno sheet. Just have to experiment and find the setting you like.
Do you plan to do any performance upgrades in the future to the engine? What are you using for headers?
If you are planning performance upgrades that will cause the max HSP to occur at a higher RPM, you might want to consider a 2.68.
The Maximus blades are hard to beat when it comes to push on the hill. You should also be able to do 60 to 65 if the boat runs free enough.
Post by SWAMPHUNTER45 » Sat Dec 15, 2018 9:49 am
If that is a take out or crate engine what are you planning to do with the ECM ?
PistolPete
Post by PistolPete » Sat Dec 15, 2018 3:02 pm
Take out 26k have it programmed for stand alone and tuned
Post by SWAMPHUNTER45 » Sat Dec 15, 2018 10:43 pm
That tune is important for sure.
Post pics as you build her
PistolPete
Post by PistolPete » Sun Dec 16, 2018 10:02 pm
Ok this is what we are starting with a never used 2008 14 x 8 Alumitec boat. Got the motor Friday started ordering the parts we will need. we are going to make some changes to seating height.
Post by SWAMPHUNTER45 » Mon Dec 17, 2018 7:24 am
A new boat that sat unused for 10 years, that's a barn find!
