Leaking oil from jug
HomesteadSlide
Post by HomesteadSlide »
Bought my first boat a month ago, been out to camp one time and when I got back I noticed some oil residue on the rudders. Parked it in the yard and cleaned the entire engine, 2 days later I have oil coming from a jug running down the case and falling on the half deck, I got the correct wrenches and made sure all bolts were torqued to spec but they weren’t loose. The motor is an 0-360 lycoming with 25 hours on it after rebuild. Looking for some advice on whether to let it eat or have it looked at !
11' Franny Taylor O-360 sled
:old_glory: :florida:
Union till the day I die !
Hambone79
Re: Leaking oil from jug
Post by Hambone79 »
Where from jug could be valve cover , could be the o-ring on the jug to block , could be a cylinder separating
Sent from my iPhone using Southern Airboat
Mossy Cypress
Post by Mossy Cypress »
My old boat with a 180 had a head separating which was causing a slow leak as you describe. I replaced the cylinder and that leak was gone, but that oil on the rudders was always there and just kept the bugs from sticking.....lol..
Gary S
Post by Gary S »
Did it just start doing it? Did you take it out before with no oil problems?
HomesteadSlide
It’s where it bolts to the block, I’ve only taken it out one time and when I got home noticed drops on the half deck. I just bought the boat.
Gary S
Post by Gary S »
Sounds like whoever built it missed the o ring.
HomesteadSlide
That's what I'm hoping, an easy fix.
Gary S
Post by Gary S »
Maybe maybe not. Sent my phone number to private number. Call me i'm in homestead too.
boostedigo540
Post by boostedigo540 »
Could be the case o ring around the through bolt inside of the case
Post by kwanjangnihm »
not familiar with the O-360 but be sure it is venting ok and not building pressure in the crankcase
HomesteadSlide
Its definitely venting, it leaks even when just sitting in the yard. I'm thinking its the O-ring to the block
