I'm Building 2 Stossel Boats with High Torque Motors
Re: I'm Building 2 Stossel Boats with High Torque Motors
Post by Slidin Gator »
John Fenner wrote:You will not regret the stossel hull, all were built with 7075 T-6 as any real boat should be, great hulls with many out there for over 30 years, welded hulls are way overrated but folks still buy them, not sure why.
Both of these hulls are over 30 years old, kinda says it all.
Seven3 wrote:No brainer on going 7075. I’m no hull builder, but I’ve wondered why more people aren’t building their 7075 hulls out of .125. I did some research two years ago before I ordered my new hull, compared weight figures from multiple suppliers, and figured that a 13x7’2 hull made of .125 only weighs about 40 pounds heavier than a .100 hull. Unless you’re building a racer, 40 pounds is just nominal and well-worth the increased hull strength.
Both of these hulls are 0.100 7075 and are pretty bullet proof. The damage on the red hull comes from 2 collisions with solid rock and will get resolved. One time I was searching the tall grass for a headstone my dad's buddy placed for his favorite dog, well I found it! :slap: .125 would be double the strength for sure, but I'm not sure it would handle these impacts either. 40 pounds is 40 pounds I can't haul, I think these hulls show that 0.100 is pretty damn durable.
Everything is a compromise.
Post by John Fenner »
.100" will give, .125" will tend to crack if hit hard enough.
John Fenner wrote:
Mon Sep 16, 2019 12:14 pm
Thanks John! Unless you are running a rock (or paper), it's gonna loose to a rock, how it responds is important for sure.
Last week was a write off, too much wind. This week was perfect. The rigging is now black for sure.
Dirtman
Post by Dirtman »
Do you remember about how much paint it took to get your cage wire covered?
Dirtman wrote:
Sat Sep 28, 2019 12:29 pm
I used about 1-1/2 gallons total of the black for rigging and wire. I think it took 1 to 1-1/2 quarts for the wire. Of course a bulk of it went to the wind.
She is coming along. Got the bell crank steering like I like it with more rudder travel than needed, until it's needed anyway.
I went to West Marine looking for a high volume bilge pump and impulse bought the automatic Rule 2000 GPH unit. I keep saying that West Marine, Home Depot, Lowes etc. should have a $200 door ante, settle up at the register. It would keep out some of the riff raff, you ain't getting out of there for less than $200 any way.
I have had great success with the smaller 500 GPH automatic units, they keep the hull dry all the time, they just are not big enough for those Oh Shick moments. I was thinking one of the smaller auto units plus a big pump on a manual switch but I couldn't pass up an opportunity to keep things simple, one pump does all, no float switch. The automatic units turn on every 2-3 minutes, if they don't sense enough current from pumping, they shut back off immediately. If the pump is sucking water the unit senses higher amperage draw and stay's on until dry, no worries about it raining all night or running down the battery, plus no issues with clogged float switches. I have never had one of the auto Rule units fail yet, I have had a lot of float switch issues in the past.
Gary S
Post by Gary S »
Why didn't you put wire on the cage?
Wire is made and will go on last. We just decided to go with tie wraps versus welding it on.
OneBFC
Post by OneBFC »
Slidin Gator wrote:
Thu Oct 03, 2019 9:07 am
Only way to go imo. I did same thing. No way will ever go back to welding or metal tie straps. Regular old 50lb black zip ties work great.
About 150 to 200 of them 😂
-Russ
Snapper man
Post by Snapper man »
Great build, beautiful boat
Snapper man
Man that was some awesome play by play, thank you i enjoyed it.can’t :old_glory: wait to hook up with you and go riding in the marsh. Always loved those hulls and still leaning that way in the near future, just hard to part with my Seminole hull that still rides great. Great going through your journey thanks again and hope to see ya soon.
Cool pump
Boat is looking great
I was working on ordering gauges. I put a meter to the fuel level sending unit to confirm the resistance range and got infinity. Pulled the sender.
At least now I know where that nut and screw in the fuel tank came from. Gonna switch to metal to metal locked screws in the fuel tank.
Didn't get much done this past month, work has gotten in the way of my hobbies, it's an issue I need to deal with.
Gary asked earlier about cage wire, here is a fit up. It's the last thing to tie wrap down. This wire was built under the concept of minimum welding, lot's of other ways to do it.
Rooting around in my parts box for my Lean/Rich cable brackets and I found an un-opened UPS envelope from JEGS. Why TF did I order 8x 1/4 NPT x 3/8 Hose barb, 45 degree, Aluminum fittings? Seriously, I don't even own 8 things with a fuel routing issue :scratch:
Found the bracket system after a lot of searching. Gauge panel ready for paint too.
Set up the throttle cable, ready for weld up. Hate to burn the paint on the engine stand, but I got more and I'm not drilling my engine stand if I can help it.
Got the lean out cable bracket set up. Red Loctite on the 1/4-20 screw into the female threaded boss on the pan.
Bought the bracket, rod end and lean out cable from Aircraft Spruce a couple of years ago. Used a chunk of Aluminum and a long screw to match it all up. Bracket pivots so the lean out cable operates smooth through out the stroke. The cable will get another zip tie to a frame as a back up vs. going through the prop.
Time to hook up the fuel lines. Crap, new cage is in a different place than old cage.
Looks like I knew I was gonna need a 45 degree fitting, now if I can figure out where the other 7 are supposed to go :scratch:
Here's the set up. The electric pump circuit is normally closed, motor normally runs on the mechanical fuel pump alone. Electric pump is used for pump up first thing in the am and offline back up otherwise. All runs through the water separator and on to the Mechanical pump.
Ghost is alive.
Last edited by Slidin Gator on Mon Dec 02, 2019 11:24 pm, edited 2 times in total.
Post by kwanjangnihm »
Looks great SG!! :thumbleft: :salute: :rebel:
OneBFC
Post by OneBFC »
Looks good. Love the rudder!
:cheers: :salute:
-Russ
Thanks, it’s been some long nights this week to finish, But we got her in the rear view mirror now, might even get some run time in this afternoon. Have been planning to paint the rudder gray eventually, but the green is already starting to grow on me.
SG did you decide to go back to the other shroud? I remember the photo of the newer, larger shroud and you had it mounted. :scratch:
My vote is to keep the rudder as is! :thumbleft:
The bigger shroud is not ready, that’s on the list of stuff left to do. Not working the engine too hard this week, so far so good. Rudder trim was perfect off the trailer. She is running on the nose a bit. Seating is more forward vs the old setup and less weight on the stern. New mounts raised the engine and prop, but still needs some tweaking. The nose definitely stays down at WOT now!
Hardtail
Post by Hardtail »
Hi Slidin Gator, Hope you had a wonderful Thanksgiving, Great build thread, looks like you had fun with getting it right, let me know if you are riding in South end some time, would like to see your new build in action, and ride with you, we just got back from Minnesota Deer hunting, we got 3 nice 8 pointers, fuel injection worked great, was cold this year, (-2* one morning) kind of tore up my franny hull with the frozen ground, after reading your thread, I think I should be look for a Stossel hull with Polymer for the Northern Climate, Send me a Text if your riding down this way, FYI We are having a Birthday Party for Charlie's Airboat on December 7th at AAOF, your invited to come celebrate with us, we always have plenty to eat.
You celebrate your boat’s birthday too? I guess anything for a party. Guess I have to start planning a 1 year old party for Ghost, Nov. 21, 2020 :lol:
I’m probably gonna be pounding some ground on the 7th. That’s my immediate plan for hull tuning, see if she flattens out and frees up some before making any other changes.
The last time I weighed the rig was 2016, it was 2,940 lbs. Hit the scales on the way home from burning Diesel & AV fuel all week. 2,700 lb boat & trailer full of fuel, extra 5 and slimmed down tool kit. So roughly my original goal of a 250 lb diet.
Here are some more pics of the finish build.
Dig way back in the thread and you will see the rudder damage I inflicted in the yard. I went with the Nascar Gorrilla tape solution.
