0 420 i think
Warden
0 420 i think
Post by Warden »
hello, i have a panther (ice rescue boat ) im new at this , its got a continental 0 420 i think ( 6 cyl , holley 2BBL on top ) it has no oil cooler , i am looking for advise and direction on what would be the best oil cooler set up for this and how it gets plumbed in ,,, the boat is a tank its all T-6 6061 with .200' hull and 7mm extruded T stringers plus truss bridging and Braces ,,, to my surprise it runs dry loaded , 100 hours total on engine , im cooking the oil and using way too much oil ! the build sheet says oil cooler delete " i guess for the frigid weather but its been near 100F here and im affraid of killing the engine if i didnt already !
any help or advise would be appreciated ,, this shit is the most fun you can have with your clothes on ! thank you , warden 845 901 1820
BobBrack
Re: 0 420 i think
Post by BobBrack »
https://www.amazon.com/Hayden-Automotiv ... way&sr=8-4
This is what most of us here in florida use. You probably have an O-470 continental. I dont think they make a 420. If you post a pic of the engine we can tell you what you have.
rowdy1
Re: 0 420 i think
Post by rowdy1 »
If you have a carburetor on top it sounds like you have a 470 ground power unit. Here is a mount and cooler set up I just installed on my 520 aircraft engine. I purchased a 4 foot box break from Northern tool, this is my first official project, it took me about three hours. The cooler is a MishiMoto that I bought off of eBay, it’s built like an aluminum radiator. Getting the cooler within 4 inches of the propeller really helped on airflow and drop my oil temp by about 20°
Warden
Re: 0 420 i think
Post by Warden »
it is a ground power , so i guess 470 ,,i will post pics asap... so where am i plumbing the oil in and out of ? very nice job with your northern tools there BTW ! i got a shit ton of all kinds of coolers (heat exchangers ) off the race cars , perhaps im over thinking this conti ? my oil pressure is bad hot, comes back when cool ... almost seems like a sump issue ,,, the pan seems wrong for this application ...sump is in front opposite prop and when im bow up i can see the gauge flutter ,,, this boat was some rich guys snow machine so im thinking he was not bow up much ,,, i have allot of hills and lots of stuff to climb over , do i need to change the pan or dry sump this engine or can they live in stock trim ? thanks so much for the input and pics ! w
rowdy1
Re: 0 420 i think
Post by rowdy1 »
Someone will have to help me on this one but I think there is a plug on either side of the block behind the flywheel. I have never seen a GPU that was dry sumped. That oil pan is so big you could almost turn it on its side and still pick up oil!
swamp_fever
Re: 0 420 i think
Post by swamp_fever »
need some pics for sure but if the carb is on top of the motor its a gpu 0470
Warden
Re: 0 420 i think
Post by Warden »
here is a pic of engine and boat
Juandi
Re: 0 420 i think
Post by Juandi »
it is a 220 gpu. nice to know it runs dry, must be a very strong engine. I run my gpu with an oil cooler and pressure and temp stays good.
94 panther hull
Io520 conversion
GO GATORS
:florida:
Seadrift
Re: 0 420 i think
Post by Seadrift »
It's been 20 years sense I run a PE-150 but if I remember correct the plug to the oil galley should be just behind your motor mount plate, on the prop end slight below the push tubes. I don't remember if I had a restricting fitting on there or not. Plenty of people still run them, so it shouldn't be hard to find one to look at. Good luck
2000 Combee 18' / TIO 541 Don't laff, it takes me there and brings me back.
KRS62
Re: 0 420 i think
Post by KRS62 »
Thanks for sharing that link. I was just.searching for an oil cooler. This one looks like the Hayden that you posted. Would y'all agree?
Sent from my SM-G965U using Southern Airboat mobile app powered by Tapatalk
BobBrack
Re: 0 420 i think
Post by BobBrack »
Thats a hayden!
